Rocket Man
SCCM 2012 Power management reports
Have set up the reports service point and followed the guidelines and all reports have populated the console. The initial problem was that when I went to create a custom report it gave an error about reports builder 2.0 was not installed. I changed the registry key to use 3.0 reports builder and all was fine after this.
The downside to creating reports in SCCM 2012 is that to create a report it actually has to use the reports builder console, completely different from SCCM 2007R3 reporting.
I also noticed that when running the built in power management reports the currency is US$ and can not be changed, is there any reason for this?
Does a registry key have to be altered for this also.
Rocket Man
