dani3l Posted June 15, 2012 Report post Posted June 15, 2012 Hi, i have installed the SCCM Client to our test machines (with the sccm console) and the installation works fine (ccmsetup.log shows no error). But i got the problem that the sccm console says that von this machine the sccm client isnt installed (waited about 12 Hours) and i dont know why. In Addition the problem appears too when i install the sccm client with a osd tasksequence. In both cases the SCCM Client is installed on the machine, but i only have 2 actions availabe (machine & user policy retrieval...) and i have no idea why this happend. Have someone an idea? Regards, dani3l Quote Share this post Link to post Share on other sites More sharing options...
synwiz Posted June 15, 2012 Report post Posted June 15, 2012 "C:\Windows\CCM\Logs" on the client is where you want to start looking: * check "LocationServices.log" - See whether it is picking up a Site Code or Not.And check any errors. * check "ccmexec.log" - for any issues or errors. this is also a very good source of info http://support.microsoft.com/kb/925282, although it says 2007, the principles remain the same. another good source is http://wmug.co.uk/wmug/b/eskonr/archive/2010/11/16/smssccm_2d00_clients_2d00_installation_2d00_troubleshooting_2d00_check_2d00_list.aspx Quote Share this post Link to post Share on other sites More sharing options...
dani3l Posted June 18, 2012 Report post Posted June 18, 2012 This logs says nothing, but last friday i found an error message on the server, which says that the sccm cant connect to the machine wmi. I checked this and i only connect to the machine wmi with the hostname and not with the ip adresse. I removed the SCCM Client from the Tasksequence and installed the machine againagaint... and then i can connect to the machine wmi with the ip. I think this isn't normal because when i install the sccm after the task sequence, it works fine and the client appears in the sccm console. Have someone a solution for this problem? Quote Share this post Link to post Share on other sites More sharing options...
