amitpatel08
Issue with Build and Capture Windows 7 SP1 x64 on VM machine
Hi
I have installed SCCM 2012 on Windows 2008 R2. I am trying to Build and Capture Windows 7 SP1 x64 on a VMWARE Virtual machine. I am using a task sequence. I used the guide on this site posted by anyweb. I am getting to the grapical portion of the setup and i am getting the error below:
Task Sequence has failed with the error code: 0x80004005
Has anyone got any ideas on why this might be happening. Seems like there is nothing on this around the web for SCCM 2012.
Any help would be greatly appreciated. Also i cannot seem to find the smsts.log log file anywhere. I searched the entire HD and cannot find it. Please help
Hi
Please find attached below the SMSTS.log file. Also this error happens during the Setup Windows and Configuration Manager.
Any ideas?
<p><![LOG[LOGGING: Finalize process ID set to 724]LOG]!><time="13:36:47.937+480" date="06-16-2012" component="TSBootShell" context="" type="1" thread="728" file="tslogging.cpp:1495">
<![LOG[==============================[ TSBootShell.exe ]==============================]LOG]!><time="13:36:47.937+480" date="06-16-2012" component="TSBootShell" context="" type="1" thread="728" file="bootshell.cpp:956">
<![LOG[succeeded loading resource DLL 'X:\sms\bin\x64\1033\TSRES.DLL']LOG]!><time="13:36:47.937+480" date="06-16-2012" component="TSBootShell" context="" type="1" thread="728" file="util.cpp:910">
<![LOG[Debug shell is enabled]LOG]!><time="13:36:47.937+480" date="06-16-2012" component="TSBootShell" context="" type="1" thread="728" file="bootshell.cpp:967">
<![LOG[Waiting for PNP initialization...]LOG]!><time="13:36:48.093+480" date="06-16-2012" component="TSBootShell" context="" type="1" thread="736" file="bootshell.cpp:60">
<![LOG[booted from network (PXE)]LOG]!><time="13:36:48.093+480" date="06-16-2012" component="TSBootShell" context="" type="1" thread="736" file="configpath.cpp:198">
<![LOG[Found config path X:\sms\data\]LOG]!><time="13:36:48.093+480" date="06-16-2012" component="TSBootShell" context="" type="1" thread="736" file="bootshell.cpp:545">
<![LOG[booting from removable media, not restoring bootloaders on hard drive]LOG]!><time="13:36:48.093+480" date="06-16-2012" component="TSBootShell" context="" type="1" thread="736" file="bootshell.cpp:556">
<![LOG[Executing command line: wpeinit.exe -winpe]LOG]!><time="13:36:48.093+480" date="06-16-2012" component="TSBootShell" context="" type="1" thread="736" file="bootshell.cpp:761">
<![LOG[The command completed successfully.]LOG]!><time="13:36:55.109+480" date="06-16-2012" component="TSBootShell" context="" type="1" thread="736" file="bootshell.cpp:843">
<![LOG[starting DNS client service.]LOG]!><time="13:36:55.109+480" date="06-16-2012" component="TSBootShell" context="" type="1" thread="736" file="bootshell.cpp:589">
<![LOG[Executing command line: X:\sms\bin\x64\TsmBootstrap.exe /env:WinPE /configpath:X:\sms\data\]LOG]!><time="13:36:55.609+480" date="06-16-2012" component="TSBootShell" context="" type="1" thread="736" file="bootshell.cpp:761">
<![LOG[The command completed successfully.]LOG]!><time="13:36:55.609+480" date="06-16-2012" component="TSBootShell" context="" type="1" thread="736" file="bootshell.cpp:843">
<![LOG[==============================[ TSMBootStrap.exe ]==============================]LOG]!><time="13:36:55.718+480" date="06-16-2012" component="TSMBootstrap" context="" type="1" thread="280" file="tsmbootstrap.cpp:966">
<![LOG[Command line: X:\sms\bin\x64\TsmBootstrap.exe /env:WinPE /configpath:X:\sms\data\]LOG]!><time="13:36:55.718+480" date="06-16-2012" component="TSMBootstrap" context="" type="0" thread="280" file="tsmbootstrap.cpp:967">
<![LOG[succeeded loading resource DLL 'X:\sms\bin\x64\1033\TSRES.DLL']LOG]!><time="13:36:55.718+480" date="06-16-2012" component="TSMBootstrap" context="" type="1" thread="280" file="util.cpp:910">
<![LOG[succeeded loading resource DLL 'X:\sms\bin\x64\TSRESNLC.DLL']LOG]!><time="13:36:55.718+480" date="06-16-2012" component="TSMBootstrap" context="" type="1" thread="280" file="resourceutils.cpp:152">
<![LOG[PXE Boot with Root = X:\]LOG]!><time="13:36:55.734+480" date="06-16-2012" component="TSMBootstrap" context="" type="1" thread="280" file="tsmbootstrap.cpp:899">
<![LOG[Executing from PXE in WinPE]LOG]!><time="13:36:55.750+480" date="06-16-2012" component="TSMBootstrap" context="" type="0" thread="280" file="tsmbootstrap.cpp:914">
<![LOG[Loading TsPxe.dll from X:\sms\bin\x64\TsPxe.dll]LOG]!><time="13:36:55.750+480" date="06-16-2012" component="TSMBootstrap" context="" type="0" thread="280" file="tsmbootstraputil.cpp:1274">
<![LOG[TsPxe.dll loaded]LOG]!><time="13:36:55.750+480" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tsmbootstraputil.cpp:1284">
<![LOG[Device has PXE booted]LOG]!><time="13:36:55.750+480" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspxe.cpp:122">
<![LOG[Variable Path: \SMSTemp\2012.06.16.11.34.39.0001.{4088131A-B44A-4620-862E-A990105543B3}.boot.var]LOG]!><time="13:36:55.750+480" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspxe.cpp:134">
<![LOG[Variable Key Len: 69]LOG]!><time="13:36:55.750+480" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspxe.cpp:141">
<![LOG[succesfully added firewall rule for Tftp]LOG]!><time="13:36:55.781+480" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="fwopen.cpp:123">
<![LOG[Executing: X:\sms\bin\x64\smstftp.exe -i 192.168.1.98 get \SMSTemp\2012.06.16.11.34.39.0001.{4088131A-B44A-4620-862E-A990105543B3}.boot.var X:\sms\data\variables.dat]LOG]!><time="13:36:55.781+480" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspxe.cpp:177">
<![LOG[Command line for extension .exe is "%1" %*]LOG]!><time="13:36:55.890+480" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="commandline.cpp:228">
<![LOG[set command line: "X:\sms\bin\x64\smstftp.exe" -i 192.168.1.98 get \SMSTemp\2012.06.16.11.34.39.0001.{4088131A-B44A-4620-862E-A990105543B3}.boot.var X:\sms\data\variables.dat]LOG]!><time="13:36:55.890+480" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="commandline.cpp:705">
<![LOG[Executing command line: "X:\sms\bin\x64\smstftp.exe" -i 192.168.1.98 get \SMSTemp\2012.06.16.11.34.39.0001.{4088131A-B44A-4620-862E-A990105543B3}.boot.var X:\sms\data\variables.dat]LOG]!><time="13:36:55.890+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="commandline.cpp:801">
<![LOG[Process completed with exit code 0]LOG]!><time="13:36:55.984+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="commandline.cpp:1098">
<![LOG[succesfully removed firewall rule for Tftp]LOG]!><time="13:36:56.000+480" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="fwopen.cpp:146">
<![LOG[successfully downloaded pxe variable file.]LOG]!><time="13:36:56.000+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tspxe.cpp:187">
<![LOG[we are booted using PXE]LOG]!><time="13:36:56.000+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsmediawizardcontrol.cpp:2551">
<![LOG[we are booted using PXE and we use a generated password]LOG]!><time="13:36:56.000+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsmediawizardcontrol.cpp:2556">
<![LOG[Loading Media Variables from "X:\sms\data\variables.dat"]LOG]!><time="13:36:56.000+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsremovablemedia.cpp:322">
<![LOG[CryptDecrypt (hKey, 0, 1, 0, pData, &dwDecryptedLen), HRESULT=80090005 (e:\nts_sccm_release\sms\framework\smscrypt\windes.cpp,150)]LOG]!><time="13:36:56.000+480" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="windes.cpp:150">
<![LOG[sMS::Crypto::DES::DecryptBuffer( (BYTE*)pszPassword, (DWORD)(wcslen(pszPassword)*sizeof(WCHAR)), encryptedBuffer.getBuffer(), (DWORD)encryptedBuffer.size(), pbDecryptedBuffer, dwDecryptedBufferSize ), HRESULT=80090005 (e:\nts_sccm_release\sms\framework\tscore\tsremovablemedia.cpp,387)]LOG]!><time="13:36:56.000+480" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tsremovablemedia.cpp:387">
<![LOG[Verifying media password.]LOG]!><time="13:36:56.000+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsmediawizardcontrol.cpp:270">
<![LOG[Found network adapter "Intel® PRO/1000 MT Network Connection" with IP Address 192.168.1.201.]LOG]!><time="13:36:56.031+480" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tsmbootstraputil.cpp:426">
<![LOG[Loading Media Variables from "X:\sms\data\variables.dat"]LOG]!><time="13:36:56.031+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsremovablemedia.cpp:322">
<![LOG[CryptDecrypt (hKey, 0, 1, 0, pData, &dwDecryptedLen), HRESULT=80090005 (e:\nts_sccm_release\sms\framework\smscrypt\windes.cpp,150)]LOG]!><time="13:36:56.031+480" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="windes.cpp:150">
<![LOG[sMS::Crypto::DES::DecryptBuffer( (BYTE*)pszPassword, (DWORD)(wcslen(pszPassword)*sizeof(WCHAR)), encryptedBuffer.getBuffer(), (DWORD)encryptedBuffer.size(), pbDecryptedBuffer, dwDecryptedBufferSize ), HRESULT=80090005 (e:\nts_sccm_release\sms\framework\tscore\tsremovablemedia.cpp,387)]LOG]!><time="13:36:56.031+480" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tsremovablemedia.cpp:387">
<![LOG[Entering TSMediaWizardControl::GetPolicy.]LOG]!><time="13:36:56.031+480" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tsmediawizardcontrol.cpp:511">
<![LOG[Environment scope "Global\{51A016B6-F0DE-4752-B97C-54E6F386A912}" successfully created]LOG]!><time="13:36:56.031+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="environmentscope.cpp:305">
<![LOG[Environment scope "Global\{BA3A3900-CA6D-4ac1-8C28-5073AFC22B03}" successfully created]LOG]!><time="13:36:56.031+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="environmentscope.cpp:305">
<![LOG[setting LogMaxSize to 1000000]LOG]!><time="13:36:56.031+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsmediawizardcontrol.cpp:539">
<![LOG[setting LogMaxHistory to 1]LOG]!><time="13:36:56.031+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsmediawizardcontrol.cpp:540">
<![LOG[setting LogLevel to 0]LOG]!><time="13:36:56.031+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsmediawizardcontrol.cpp:541">
<![LOG[setting LogEnabled to 1]LOG]!><time="13:36:56.031+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsmediawizardcontrol.cpp:542">
<![LOG[setting LogDebug to 1]LOG]!><time="13:36:56.031+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsmediawizardcontrol.cpp:543">
<![LOG[Loading variables from the Task Sequencing Removable Media.]LOG]!><time="13:36:56.218+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsmediawizardcontrol.cpp:563">
<![LOG[Loading Media Variables from "X:\sms\data\variables.dat"]LOG]!><time="13:36:56.218+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsremovablemedia.cpp:322">
<![LOG[setting SMSTSMP TS environment variable]LOG]!><time="13:36:56.218+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsmediawizardcontrol.cpp:580">
<![LOG[setting _SMSMediaGuid TS environment variable]LOG]!><time="13:36:56.218+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsmediawizardcontrol.cpp:580">
<![LOG[setting _SMSTSBootMediaPackageID TS environment variable]LOG]!><time="13:36:56.218+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsmediawizardcontrol.cpp:580">
<![LOG[setting _SMSTSHTTPPort TS environment variable]LOG]!><time="13:36:56.218+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsmediawizardcontrol.cpp:580">
<![LOG[setting _SMSTSHTTPSPort TS environment variable]LOG]!><time="13:36:56.218+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsmediawizardcontrol.cpp:580">
<![LOG[setting _SMSTSIISSSLState TS environment variable]LOG]!><time="13:36:56.218+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsmediawizardcontrol.cpp:580">
<![LOG[setting _SMSTSLaunchMode TS environment variable]LOG]!><time="13:36:56.218+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsmediawizardcontrol.cpp:580">
<![LOG[setting _SMSTSMediaPFX TS environment variable]LOG]!><time="13:36:56.218+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsmediawizardcontrol.cpp:580">
<![LOG[setting _SMSTSPublicRootKey TS environment variable]LOG]!><time="13:36:56.218+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsmediawizardcontrol.cpp:580">
<![LOG[setting _SMSTSSiteCode TS environment variable]LOG]!><time="13:36:56.218+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsmediawizardcontrol.cpp:580">
<![LOG[setting _SMSTSSiteSigningCertificate TS environment variable]LOG]!><time="13:36:56.218+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsmediawizardcontrol.cpp:580">
<![LOG[setting _SMSTSUseFirstCert TS environment variable]LOG]!><time="13:36:56.218+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsmediawizardcontrol.cpp:580">
<![LOG[setting _SMSTSx64UnknownMachineGUID TS environment variable]LOG]!><time="13:36:56.218+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsmediawizardcontrol.cpp:580">
<![LOG[setting _SMSTSx86UnknownMachineGUID TS environment variable]LOG]!><time="13:36:56.218+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsmediawizardcontrol.cpp:580">
<![LOG[Root CA Public Certs=]LOG]!><time="13:36:56.218+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsmediawizardcontrol.cpp:591">
<![LOG[Missing root CA environment variable from variables file]LOG]!><time="13:36:56.218+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsmediawizardcontrol.cpp:597">
<![LOG[Custom hook from X:\\TSConfig.INI is ]LOG]!><time="13:36:56.218+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsmediawizardcontrol.cpp:646">
<![LOG[No hook is found to be executed before downloading policy]LOG]!><time="13:36:56.218+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsmediawizardcontrol.cpp:670">
<![LOG[Authenticator from the environment is empty.]LOG]!><time="13:36:56.234+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsmediawizardcontrol.cpp:809">
<![LOG[Need to create Authenticator Info using PFX]LOG]!><time="13:36:56.234+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsmediawizardcontrol.cpp:821">
<![LOG[set media certificate in transport]LOG]!><time="13:36:56.281+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="libsmsmessaging.cpp:9220">
<![LOG[set authenticator in transport]LOG]!><time="13:36:56.281+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="libsmsmessaging.cpp:7592">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: ECH-SCCM-01.HOME.COM:80 GET /SMS_MP/.sms_aut?MPKEYINFORMATION]LOG]!><time="13:36:56.296+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="libsmsmessaging.cpp:8422">
<![LOG[Request was succesful.]LOG]!><time="13:36:56.328+480" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="libsmsmessaging.cpp:8758">
<![LOG[Default CSP is Microsoft Enhanced RSA and AES Cryptographic Provider]LOG]!><time="13:36:56.328+480" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="libcrypt.cpp:1592">
<![LOG[Default CSP Type is 24]LOG]!><time="13:36:56.328+480" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="libcrypt.cpp:1593">
<![LOG[New settings:]LOG]!><time="13:36:56.328+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsmediawizardcontrol.cpp:892">
<![LOG[ site=HOM,HOM, MP=http://ECH-SCCM-01.HOME.COM, ports: http=80,https=443]LOG]!><time="13:36:56.328+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsmediawizardcontrol.cpp:893">
<![LOG[ certificates are received from MP.]LOG]!><time="13:36:56.328+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsmediawizardcontrol.cpp:898">
<![LOG[Getting MP time information]LOG]!><time="13:36:56.343+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsmediawizardcontrol.cpp:985">
<![LOG[set authenticator in transport]LOG]!><time="13:36:56.343+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="libsmsmessaging.cpp:7592">
<![LOG[Requesting client identity]LOG]!><time="13:36:56.359+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="libsmsmessaging.cpp:5615">
<![LOG[setting message signatures.]LOG]!><time="13:36:56.359+480" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="libsmsmessaging.cpp:1292">
<![LOG[setting the authenticator.]LOG]!><time="13:36:56.375+480" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="libsmsmessaging.cpp:1322">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: ECH-SCCM-01.HOME.COM:80 CCM_POST /ccm_system/request]LOG]!><time="13:36:56.375+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="libsmsmessaging.cpp:8422">
<![LOG[Request was succesful.]LOG]!><time="13:36:56.390+480" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="libsmsmessaging.cpp:8758">
<![LOG[Decompressing reply body.]LOG]!><time="13:36:56.390+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="libsmsmessaging.cpp:2361">
<![LOG[::DecompressBuffer(65536)]LOG]!><time="13:36:56.390+480" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="ccmzlib.cpp:736">
<![LOG[Decompression (zlib) succeeded: original size 422, uncompressed size 2496.]LOG]!><time="13:36:56.390+480" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="ccmzlib.cpp:647">
<![LOG[-60 -60]LOG]!><time="13:36:56.390+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="libsmsmessaging.cpp:5797">
<![LOG[server time zone info: 0, , [0 10 0 5 2 0 0 0], 0, , [0 3 0 5 1 0 0 0], -60]LOG]!><time="13:36:56.390+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="libsmsmessaging.cpp:5870">
<![LOG[Client Identity: ]LOG]!><time="13:36:56.390+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="libsmsmessaging.cpp:5981">
<![LOG[Netbios name: ]LOG]!><time="13:36:56.390+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="libsmsmessaging.cpp:5997">
<![LOG[Current time: 2012-06-16 21:36:56.390 TZ:Pacific Standard Time Bias:0480]LOG]!><time="13:36:56.390+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsmediawizardcontrol.cpp:1052">
<![LOG[Current time zone info: 480, Pacific Standard Time, [0 0 0 0 0 0 0 0], 0, , [0 0 0 0 0 0 0 0], 0]LOG]!><time="13:36:56.390+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsmediawizardcontrol.cpp:1056">
<![LOG[Adjusting the system time: -32400.095 seconds]LOG]!><time="13:36:56.390+480" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsmediawizardcontrol.cpp:1084">
<![LOG[Time zone info set to: 0, , [0 10 0 5 2 0 0 0], 0, , [0 3 0 5 1 0 0 0], -60]LOG]!><time="22:36:56.390-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsmediawizardcontrol.cpp:1094">
<![LOG[New time: 2012-06-16 12:36:56.294]LOG]!><time="13:36:56.294-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsmediawizardcontrol.cpp:1134">
<![LOG[Current time: 2012-06-16 12:36:56.294 TZ: Bias:0000]LOG]!><time="13:36:56.294-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsmediawizardcontrol.cpp:1140">
<![LOG[Downloading policy from LOG]!><time="13:36:56.497-60"http://ECH-SCCM-01.HOME.COM.]LOG]!><time="13:36:56.497-60/a"]http://ECH-SCCM-01.HOME.COM.]LOG]!><time="13:36:56.497-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:786">
<![LOG[ Setting Ports = 80,443.]LOG]!><time="13:36:56.497-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:789">
<![LOG[ Setting CRL = false.]LOG]!><time="13:36:56.497-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:792">
<![LOG[ Setting Server Certificates.]LOG]!><time="13:36:56.497-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:809">
<![LOG[set authenticator in transport]LOG]!><time="13:36:56.497-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="libsmsmessaging.cpp:7592">
<![LOG[ Setting Media Certificate.]LOG]!><time="13:36:56.497-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:817">
<![LOG[Preparing Client Identity Request.]LOG]!><time="13:36:56.512-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:570">
<![LOG[ Setting transport.]LOG]!><time="13:36:56.512-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:573">
<![LOG[ Setting SourceID = 08b0eb54-23d2-44c5-b67f-df2694960de2.]LOG]!><time="13:36:56.512-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:577">
<![LOG[ Setting site code = HOM.]LOG]!><time="13:36:56.512-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:582">
<![LOG[ Setting SMBIOS GUID = 919E0642-B7BF-EA18-15C3-BF429CE3408B.]LOG]!><time="13:36:56.919-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:606">
<![LOG[ Adding MAC Address 00:50:56:86:00:02.]LOG]!><time="13:36:56.950-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:625">
<![LOG[Executing Client Identity Request.]LOG]!><time="13:36:56.950-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:633">
<![LOG[Requesting client identity]LOG]!><time="13:36:56.950-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="libsmsmessaging.cpp:5615">
<![LOG[setting message signatures.]LOG]!><time="13:36:56.950-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="libsmsmessaging.cpp:1292">
<![LOG[setting the authenticator.]LOG]!><time="13:36:56.950-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="libsmsmessaging.cpp:1322">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: ECH-SCCM-01.HOME.COM:80 CCM_POST /ccm_system/request]LOG]!><time="13:36:56.950-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="libsmsmessaging.cpp:8422">
<![LOG[Request was succesful.]LOG]!><time="13:36:56.965-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="libsmsmessaging.cpp:8758">
<![LOG[Decompressing reply body.]LOG]!><time="13:36:56.965-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="libsmsmessaging.cpp:2361">
<![LOG[::DecompressBuffer(65536)]LOG]!><time="13:36:56.965-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="ccmzlib.cpp:736">
<![LOG[Decompression (zlib) succeeded: original size 580, uncompressed size 2920.]LOG]!><time="13:36:56.965-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="ccmzlib.cpp:647">
<![LOG[-60 -60]LOG]!><time="13:36:56.965-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="libsmsmessaging.cpp:5797">
<![LOG[server time zone info: 0, , [0 10 0 5 2 0 0 0], 0, , [0 3 0 5 1 0 0 0], -60]LOG]!><time="13:36:56.965-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="libsmsmessaging.cpp:5870">
<![LOG[Client Identity: GUID:0E35F46D-665F-444C-9AB2-DE329D1540A7]LOG]!><time="13:36:56.965-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="libsmsmessaging.cpp:5981">
<![LOG[Netbios name: WinTest]LOG]!><time="13:36:56.965-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="libsmsmessaging.cpp:5997">
<![LOG[Client GUID = GUID:0E35F46D-665F-444C-9AB2-DE329D1540A7, Netbios name = WinTest, State = Known]LOG]!><time="13:36:56.965-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:653">
<![LOG[Preparing Policy Assignment Request.]LOG]!><time="13:36:57.153-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:900">
<![LOG[ Setting transport.]LOG]!><time="13:36:57.153-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:901">
<![LOG[ Setting site code = HOM.]LOG]!><time="13:36:57.153-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:904">
<![LOG[ Setting client ID = GUID:0E35F46D-665F-444C-9AB2-DE329D1540A7.]LOG]!><time="13:36:57.153-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:906">
<![LOG[ Setting site signing Certificate.]LOG]!><time="13:36:57.153-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:911">
<![LOG[setting SiteSigningCertificateContext]LOG]!><time="13:36:57.153-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="libsmsmessaging.cpp:2511">
<![LOG[Executing Policy Assignment Request.]LOG]!><time="13:36:57.153-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:924">
<![LOG[sending RequestAssignments]LOG]!><time="13:36:57.153-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="libsmsmessaging.cpp:2788">
<![LOG[setting message signatures.]LOG]!><time="13:36:57.153-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="libsmsmessaging.cpp:1292">
<![LOG[setting the authenticator.]LOG]!><time="13:36:57.153-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="libsmsmessaging.cpp:1322">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: ECH-SCCM-01.HOME.COM:80 CCM_POST /ccm_system/request]LOG]!><time="13:36:57.153-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="libsmsmessaging.cpp:8422">
<![LOG[Request was succesful.]LOG]!><time="13:36:57.200-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="libsmsmessaging.cpp:8758">
<![LOG[Decompressing reply body.]LOG]!><time="13:36:57.200-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="libsmsmessaging.cpp:2361">
<![LOG[::DecompressBuffer(65536)]LOG]!><time="13:36:57.200-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="ccmzlib.cpp:736">
<![LOG[Decompression (zlib) succeeded: original size 26992, uncompressed size 127796.]LOG]!><time="13:36:57.200-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="ccmzlib.cpp:647">
<![LOG[Request client ID: GUID:0E35F46D-665F-444C-9AB2-DE329D1540A7]LOG]!><time="13:36:57.200-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="libsmsmessaging.cpp:2842">
<![LOG[Response client ID: GUID:0E35F46D-665F-444C-9AB2-DE329D1540A7]LOG]!><time="13:36:57.200-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="libsmsmessaging.cpp:2843">
<![LOG[Retrieving Policy Assignments:]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:929">
<![LOG[ Processing Policy Assignment {4289019d-a692-4c19-b677-c8c50e31a712}.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment {ef8caf4a-1171-47e6-bff3-871dc012009d}.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment {7c46e128-6bc7-469c-a29f-8ea79038e783}.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment {6eea2e30-3c8f-4a9d-a0ed-d697f47da873}.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment {bfd33448-e45a-4cc6-a9ac-df71c41a79f7}.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment {8515f7bb-14ba-445d-8c4d-14a037759719}.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment {c9d35b56-695b-4564-969f-9be78a50626f}.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment {1fb6a4d9-9681-4d96-9b25-625330c409b2}.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment {b0feef7d-0c8d-45d2-9be4-39bf554bf061}.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment {07ddd8ad-6bc3-440a-9cb1-7bc97a8cddd4}.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment {0bcca186-dff4-4830-aa07-f062aa6fc5ab}.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment {cb417811-f013-454f-a861-4aa9307d2237}.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment {06d8a740-3ffe-4dde-bee7-9a200cf2e4fe}.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment {8c892d8b-71e8-43fa-b7e0-459f78aa57a8}.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment {5ae4de1b-de35-40eb-a214-f061d8a3d0a2}.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment {3cf0bb33-ec6c-457a-ac2a-0776b53a5565}.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment {581841f2-9727-4d91-bdb2-818d49f2c88f}.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment {bc4b79c6-c0f5-435e-b2a3-dfc244df0dff}.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment {469f0815-74cc-46e3-9abe-bc53714f71ab}.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment {5feabd41-6273-444e-a882-4f7542b9c04e}.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment {019eacfc-ad8d-41d7-9d5e-8124baeb0866}.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment {192a9d8b-ab42-4fe2-9b53-b0dbbd349c82}.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment {9b085711-efb3-47a7-8373-23ff888dd1c8}.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment {996168ad-72ff-41f0-91ff-ed33ad7cf022}.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment {fcafdb92-836b-425d-b615-c5e1e7a9aea7}.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment {2d4b46e9-fe47-4514-b8fb-f293c7af0be9}.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment {5ec87510-d268-4fb5-908b-2ebb3bee6ff6}.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment {4c06f626-0f88-41b8-afce-a5ee944041d0}.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment HOM20001-HOM00006-3B5BFFE2.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment {D6AD1B4C-64C9-4B7A-A4AC-F4E01B9E09F5}.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment Windows/All_Windows_Client_Server/VI/VS.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment ScopeId_3F53CAEB-4131-41AD-B755-929FA7F36C7D/RequiredApplication_fe94a94c-8c5a-41b8-98d8-29191741eab3/VI/VS.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment {6646A4C5-D86D-46DE-88B7-33CBBF4EA797}.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment ScopeId_3F53CAEB-4131-41AD-B755-929FA7F36C7D/RequiredApplication_3e76083b-679e-42f1-abaa-32df1fa6c3fe/VI/VS.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment HOM20004-HOM00010-6F6BCC28.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment DEP-HOM20004-HOM00004-6F6BCC28.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment DEP-HOM20004-HOM00005-6F6BCC28.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment DEP-HOM20004-HOM0000F-6F6BCC28.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment HOM20007-HOM00012-6F6BCC28.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment DEP-HOM20007-HOM00004-6F6BCC28.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment DEP-HOM20007-HOM00005-6F6BCC28.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment DEP-HOM20007-HOM0000F-6F6BCC28.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment HOM2000C-HOM00015-6F6BCC28.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment DEP-HOM2000C-HOM00004-6F6BCC28.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment DEP-HOM2000C-HOM0000C-6F6BCC28.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[ Processing Policy Assignment DEP-HOM2000C-HOM00014-6F6BCC28.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:938">
<![LOG[successfully read 46 policy assignments.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:952">
<![LOG[Downloading policy body HOM20004-HOM00010-6F6BCC28.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tspolicy.cpp:1992">
<![LOG[Preparing Policy Body Request.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:1995">
<![LOG[ Setting transport.]LOG]!><time="13:36:57.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:1996">
<![LOG[ Setting policy location = LOG]!><time="13:36:57.215-60"http://<mp>/SMS_MP/.sms_pol?HOM20004-HOM00010-6F6BCC28.1_00.]LOG]!><time="13:36:57.215-60/a"]HTTP://<MP>/SMS_MP/.SMS_POL?HOM20004-HOM00010-6F6BCC28.1_00]LOG]!><time="13:36:57.247-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="libsmsmessaging.cpp:4806">
<![LOG[Response ID: HOM20004-HOM00010-6F6BCC28]LOG]!><time="13:36:57.247-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="libsmsmessaging.cpp:4807">
<![LOG[Reading Policy Body.]LOG]!><time="13:36:57.262-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:2023">
<![LOG[Parsing Policy Body.]LOG]!><time="13:36:57.262-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:2030">
<![LOG[Downloading policy body HOM20007-HOM00012-6F6BCC28.]LOG]!><time="13:36:57.262-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tspolicy.cpp:1992">
<![LOG[Preparing Policy Body Request.]LOG]!><time="13:36:57.262-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:1995">
<![LOG[ Setting transport.]LOG]!><time="13:36:57.262-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:1996">
<![LOG[ Setting policy location = LOG]!><time="13:36:57.262-60"http://<mp>/SMS_MP/.sms_pol?HOM20007-HOM00012-6F6BCC28.1_00.]LOG]!><time="13:36:57.262-60/a"]HTTP://<MP>/SMS_MP/.SMS_POL?HOM20007-HOM00012-6F6BCC28.1_00]LOG]!><time="13:36:57.294-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="libsmsmessaging.cpp:4806">
<![LOG[Response ID: HOM20007-HOM00012-6F6BCC28]LOG]!><time="13:36:57.294-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="libsmsmessaging.cpp:4807">
<![LOG[Reading Policy Body.]LOG]!><time="13:36:57.294-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:2023">
<![LOG[Parsing Policy Body.]LOG]!><time="13:36:57.294-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:2030">
<![LOG[Downloading policy body HOM2000C-HOM00015-6F6BCC28.]LOG]!><time="13:36:57.294-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tspolicy.cpp:1992">
<![LOG[Preparing Policy Body Request.]LOG]!><time="13:36:57.294-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:1995">
<![LOG[ Setting transport.]LOG]!><time="13:36:57.294-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:1996">
<![LOG[ Setting policy location = LOG]!><time="13:36:57.294-60"http://<mp>/SMS_MP/.sms_pol?HOM2000C-HOM00015-6F6BCC28.1_00.]LOG]!><time="13:36:57.294-60/a"]HTTP://<MP>/SMS_MP/.SMS_POL?HOM2000C-HOM00015-6F6BCC28.1_00]LOG]!><time="13:36:57.340-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="libsmsmessaging.cpp:4806">
<![LOG[Response ID: HOM2000C-HOM00015-6F6BCC28]LOG]!><time="13:36:57.340-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="libsmsmessaging.cpp:4807">
<![LOG[Reading Policy Body.]LOG]!><time="13:36:57.340-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:2023">
<![LOG[Parsing Policy Body.]LOG]!><time="13:36:57.340-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:2030">
<![LOG[This Task sequence is set for DownloadOnDemand]LOG]!><time="13:36:57.340-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tspolicy.cpp:3079">
<![LOG[This Task sequence is set for DownloadOnDemand]LOG]!><time="13:36:57.356-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tspolicy.cpp:3079">
<![LOG[Retrieving collection variable policy.]LOG]!><time="13:36:57.356-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tspolicy.cpp:1460">
<![LOG[Found 0 collection variables.]LOG]!><time="13:36:57.356-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:1468">
<![LOG[Retrieving machine variable policy.]LOG]!><time="13:36:57.356-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tspolicy.cpp:1479">
<![LOG[Found 0 machine variables.]LOG]!><time="13:36:57.356-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tspolicy.cpp:1487">
<![LOG[setting machine/collection variables in the task sequencing environment.]LOG]!><time="13:36:57.356-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="utils.cpp:138">
<![LOG[Exiting TSMediaWizardControl::GetPolicy.]LOG]!><time="13:36:57.356-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tsmediawizardcontrol.cpp:1335">
<![LOG[Running Wizard in Interactive mode]LOG]!><time="13:36:57.356-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsmediawizardcontrol.cpp:2386">
<![LOG[Loading Media Variables from "X:\sms\data\variables.dat"]LOG]!><time="13:36:57.356-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsremovablemedia.cpp:322">
<![LOG[CryptDecrypt (hKey, 0, 1, 0, pData, &dwDecryptedLen), HRESULT=80090005 (e:\nts_sccm_release\sms\framework\smscrypt\windes.cpp,150)]LOG]!><time="13:36:57.356-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="windes.cpp:150">
<![LOG[sMS::Crypto::DES::DecryptBuffer( (BYTE*)pszPassword, (DWORD)(wcslen(pszPassword)*sizeof(WCHAR)), encryptedBuffer.getBuffer(), (DWORD)encryptedBuffer.size(), pbDecryptedBuffer, dwDecryptedBufferSize ), HRESULT=80090005 (e:\nts_sccm_release\sms\framework\tscore\tsremovablemedia.cpp,387)]LOG]!><time="13:36:57.356-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tsremovablemedia.cpp:387">
<![LOG[Activating Welcome Page.]LOG]!><time="13:36:57.356-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tsmediawelcomepage.cpp:131">
<![LOG[Loading bitmap]LOG]!><time="13:36:57.372-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsmbootstrap.cpp:1065">
<![LOG[WelcomePage::OnWizardNext()]LOG]!><time="13:37:18.825-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tsmediawelcomepage.cpp:340">
<![LOG[Loading Media Variables from "X:\sms\data\variables.dat"]LOG]!><time="13:37:18.825-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsremovablemedia.cpp:322">
<![LOG[CryptDecrypt (hKey, 0, 1, 0, pData, &dwDecryptedLen), HRESULT=80090005 (e:\nts_sccm_release\sms\framework\smscrypt\windes.cpp,150)]LOG]!><time="13:37:18.825-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="windes.cpp:150">
<![LOG[sMS::Crypto::DES::DecryptBuffer( (BYTE*)pszPassword, (DWORD)(wcslen(pszPassword)*sizeof(WCHAR)), encryptedBuffer.getBuffer(), (DWORD)encryptedBuffer.size(), pbDecryptedBuffer, dwDecryptedBufferSize ), HRESULT=80090005 (e:\nts_sccm_release\sms\framework\tscore\tsremovablemedia.cpp,387)]LOG]!><time="13:37:18.825-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tsremovablemedia.cpp:387">
<![LOG[skipping Confirmation Page.]LOG]!><time="13:37:18.825-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tsmediaconfirmationpage.cpp:170">
<![LOG[Activating Task Sequence Selection Page.]LOG]!><time="13:37:18.825-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tsmediataskselectionpage.cpp:112">
<![LOG[TaskSelectionPage::OnWizardNext()]LOG]!><time="13:37:19.809-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tsmediataskselectionpage.cpp:137">
<![LOG[skipping Variables Selection Page.]LOG]!><time="13:37:19.809-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tsmediavariablesselectionpage.cpp:155">
<![LOG[Activating Resolve Progress Page.]LOG]!><time="13:37:19.809-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tsmediaresolveprogresspage.cpp:76">
<![LOG[ResolveProgressPage::OnWizardNext()]LOG]!><time="13:37:19.809-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="280" file="tsmediaresolveprogresspage.cpp:113">
<![LOG[spawned thread 196 to resolve task sequence dependencies.]LOG]!><time="13:37:19.809-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="280" file="tsmediaresolveprogresspage.cpp:142">
<![LOG[No content source files for selected task sequence.]LOG]!><time="13:37:19.809-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="tspolicy.cpp:3316">
<![LOG[Getting policy for CCM_SoftwareDistribution[AdvertID=HOM2000C", PackageID="HOM00004", ProgramID="*]]LOG]!><time="13:37:19.809-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:2379">
<![LOG[Downloading policy body DEP-HOM2000C-HOM00004-6F6BCC28.]LOG]!><time="13:37:19.809-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="tspolicy.cpp:1992">
<![LOG[Preparing Policy Body Request.]LOG]!><time="13:37:19.809-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:1995">
<![LOG[ Setting transport.]LOG]!><time="13:37:19.809-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:1996">
<![LOG[ Setting policy location = LOG]!><time="13:37:19.809-60"http://<mp>/SMS_MP/.sms_pol?DEP-HOM2000C-HOM00004-6F6BCC28.1_00.]LOG]!><time="13:37:19.809-60/a"]HTTP://<MP>/SMS_MP/.SMS_POL?DEP-HOM2000C-HOM00004-6F6BCC28.1_00]LOG]!><time="13:37:19.825-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="libsmsmessaging.cpp:4806">
<![LOG[Response ID: DEP-HOM2000C-HOM00004-6F6BCC28]LOG]!><time="13:37:19.825-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="libsmsmessaging.cpp:4807">
<![LOG[Reading Policy Body.]LOG]!><time="13:37:19.825-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:2023">
<![LOG[Parsing Policy Body.]LOG]!><time="13:37:19.825-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:2030">
<![LOG[Getting content hash value for reference package HOM00004 from policy]LOG]!><time="13:37:19.825-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="tspolicy.cpp:2455">
<![LOG[successfully resolved policy for HOM00004.]LOG]!><time="13:37:19.825-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:2510">
<![LOG[Resolving content location for HOM00004]LOG]!><time="13:37:19.825-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:2527">
<![LOG[Getting network access account.]LOG]!><time="13:37:19.825-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:1788">
<![LOG[Downloading policy body {bc4b79c6-c0f5-435e-b2a3-dfc244df0dff}.]LOG]!><time="13:37:19.840-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="tspolicy.cpp:1992">
<![LOG[Preparing Policy Body Request.]LOG]!><time="13:37:19.840-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:1995">
<![LOG[ Setting transport.]LOG]!><time="13:37:19.840-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:1996">
<![LOG[ Setting policy location = LOG]!><time="13:37:19.840-60"http://<mp>/SMS_MP/.sms_pol?{bc4b79c6-c0f5-435e-b2a3-dfc244df0dff}.2_00.]LOG]!><time="13:37:19.840-60/a"]HTTP://<MP>/SMS_MP/.SMS_POL?{BC4B79C6-C0F5-435E-B2A3-DFC244DF0DFF}.2_00]LOG]!><time="13:37:19.856-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="libsmsmessaging.cpp:4806">
<![LOG[Response ID: {BC4B79C6-C0F5-435E-B2A3-DFC244DF0DFF}]LOG]!><time="13:37:19.856-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="libsmsmessaging.cpp:4807">
<![LOG[Reading Policy Body.]LOG]!><time="13:37:19.856-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:2023">
<![LOG[Parsing Policy Body.]LOG]!><time="13:37:19.856-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:2030">
<![LOG[Found NetworkAccessUsername/NetworkAccessPassword from NAAConfig CCM_NetworkAccessAccount]LOG]!><time="13:37:19.856-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="tspolicy.cpp:1702">
<![LOG[Network Access Account has a non-empty value]LOG]!><time="13:37:19.856-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="tspolicy.cpp:1734">
<![LOG[Getting local network information.]LOG]!><time="13:37:19.856-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="resolvesource.cpp:1988">
<![LOG[DhcpGetOriginalSubnetMask entry point is supported.]LOG]!><time="13:37:19.856-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="ccmiputil.cpp:117">
<![LOG[begin checking Alternate Network Configuration]LOG]!><time="13:37:19.856-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="ccmiputil.cpp:1069">
<![LOG[spNamespace.Open(sNamespacePath), HRESULT=8004100e (e:\nts_sccm_release\sms\framework\ccmutillib\ccmiputil.cpp,1083)]LOG]!><time="13:37:19.856-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="ccmiputil.cpp:1083">
<![LOG[Finished checking Alternate Network Configuration]LOG]!><time="13:37:19.856-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="ccmiputil.cpp:1146">
<![LOG[Adapter {5020B3E0-A910-43FA-965B-14BC01B0DD9C} is DHCP enabled. Checking quarantine status.]LOG]!><time="13:37:19.856-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="ccmiputil.cpp:416">
<![LOG[Content location request:]LOG]!><time="13:37:19.872-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="resolvesource.cpp:1993">
<![LOG[ Package : HOM00004.3]LOG]!><time="13:37:19.872-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="resolvesource.cpp:1994">
<![LOG[ Client : GUID:0E35F46D-665F-444C-9AB2-DE329D1540A7]LOG]!><time="13:37:19.872-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="resolvesource.cpp:1995">
<![LOG[ Local : 1]LOG]!><time="13:37:19.872-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="resolvesource.cpp:1996">
<![LOG[ Remote : 0]LOG]!><time="13:37:19.872-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="resolvesource.cpp:1997">
<![LOG[ Internet: 0]LOG]!><time="13:37:19.872-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="resolvesource.cpp:1998">
<![LOG[sending RequestContentLocations for HOM00004]LOG]!><time="13:37:19.872-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="libsmsmessaging.cpp:3459">
<![LOG[setting message signatures.]LOG]!><time="13:37:19.887-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="libsmsmessaging.cpp:1292">
<![LOG[setting the authenticator.]LOG]!><time="13:37:19.887-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="libsmsmessaging.cpp:1322">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: ECH-SCCM-01.HOME.COM:80 CCM_POST /ccm_system/request]LOG]!><time="13:37:19.887-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="libsmsmessaging.cpp:8422">
<![LOG[Request was succesful.]LOG]!><time="13:37:19.919-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="libsmsmessaging.cpp:8758">
<![LOG[Decompressing reply body.]LOG]!><time="13:37:19.919-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="libsmsmessaging.cpp:2361">
<![LOG[::DecompressBuffer(65536)]LOG]!><time="13:37:19.919-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="ccmzlib.cpp:736">
<![LOG[Decompression (zlib) succeeded: original size 530, uncompressed size 1618.]LOG]!><time="13:37:19.919-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="ccmzlib.cpp:647">
<![LOG[Location Reply: <ContentLocationReply SchemaVersion=1.00"><ContentInfo PackageFlags="1056"/><Sites><Site><MPSite SiteCode="HOM" MasterSiteCode="HOM" SiteLocality="LOCAL" IISPreferedPort="80" IISSSLPreferedPort="443"/><LocationRecords><LocationRecord><URL Name="http://ECH-SCCM-01.HOME.COM/SMS_DP_SMSPKG$/HOM00004" Signature="http://ECH-SCCM-01.HOME.COM/SMS_DP_SMSPKG$/HOM00004]LOG]!><time="13:37:19.919-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="resolvesource.cpp:2114">
<![LOG[Prioritized locations:]LOG]!><time="13:37:19.919-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="resolvesource.cpp:2143">
<![LOG[ LOG]!><time="13:37:19.919-60"http://ECH-SCCM-01.HOME.COM/SMS_DP_SMSPKG$/HOM00004]LOG]!><time="13:37:19.919-60/a"]http://ECH-SCCM-01.HOME.COM/SMS_DP_SMSPKG$/HOM00004]LOG]!><time="13:37:19.919-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:2612">
<![LOG[Getting policy for CCM_SoftwareDistribution[AdvertID=HOM2000C", PackageID="HOM0000C", ProgramID="*]]LOG]!><time="13:37:19.919-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:2379">
<![LOG[Downloading policy body DEP-HOM2000C-HOM0000C-6F6BCC28.]LOG]!><time="13:37:19.919-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="tspolicy.cpp:1992">
<![LOG[Preparing Policy Body Request.]LOG]!><time="13:37:19.919-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:1995">
<![LOG[ Setting transport.]LOG]!><time="13:37:19.919-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:1996">
<![LOG[ Setting policy location = LOG]!><time="13:37:19.919-60"http://<mp>/SMS_MP/.sms_pol?DEP-HOM2000C-HOM0000C-6F6BCC28.1_00.]LOG]!><time="13:37:19.919-60/a"]HTTP://<MP>/SMS_MP/.SMS_POL?DEP-HOM2000C-HOM0000C-6F6BCC28.1_00]LOG]!><time="13:37:19.934-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="libsmsmessaging.cpp:4806">
<![LOG[Response ID: DEP-HOM2000C-HOM0000C-6F6BCC28]LOG]!><time="13:37:19.934-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="libsmsmessaging.cpp:4807">
<![LOG[Reading Policy Body.]LOG]!><time="13:37:19.950-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:2023">
<![LOG[Parsing Policy Body.]LOG]!><time="13:37:19.950-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:2030">
<![LOG[Getting content hash value for reference package HOM0000C from policy]LOG]!><time="13:37:19.950-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="tspolicy.cpp:2455">
<![LOG[successfully resolved policy for HOM0000C.]LOG]!><time="13:37:19.950-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:2510">
<![LOG[Resolving content location for HOM0000C]LOG]!><time="13:37:19.950-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:2527">
<![LOG[Getting network access account.]LOG]!><time="13:37:19.950-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:1788">
<![LOG[Found NetworkAccessUsername/NetworkAccessPassword from NAAConfig CCM_NetworkAccessAccount]LOG]!><time="13:37:19.950-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="tspolicy.cpp:1702">
<![LOG[Network Access Account has a non-empty value]LOG]!><time="13:37:19.950-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="tspolicy.cpp:1734">
<![LOG[Getting local network information.]LOG]!><time="13:37:19.950-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="resolvesource.cpp:1988">
<![LOG[DHCP entry points already initialized.]LOG]!><time="13:37:19.950-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="ccmiputil.cpp:75">
<![LOG[begin checking Alternate Network Configuration]LOG]!><time="13:37:19.950-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="ccmiputil.cpp:1069">
<![LOG[spNamespace.Open(sNamespacePath), HRESULT=8004100e (e:\nts_sccm_release\sms\framework\ccmutillib\ccmiputil.cpp,1083)]LOG]!><time="13:37:19.950-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="ccmiputil.cpp:1083">
<![LOG[Finished checking Alternate Network Configuration]LOG]!><time="13:37:19.950-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="ccmiputil.cpp:1146">
<![LOG[Adapter {5020B3E0-A910-43FA-965B-14BC01B0DD9C} is DHCP enabled. Checking quarantine status.]LOG]!><time="13:37:19.950-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="ccmiputil.cpp:416">
<![LOG[Content location request:]LOG]!><time="13:37:19.950-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="resolvesource.cpp:1993">
<![LOG[ Package : HOM0000C.1]LOG]!><time="13:37:19.950-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="resolvesource.cpp:1994">
<![LOG[ Client : GUID:0E35F46D-665F-444C-9AB2-DE329D1540A7]LOG]!><time="13:37:19.950-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="resolvesource.cpp:1995">
<![LOG[ Local : 1]LOG]!><time="13:37:19.950-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="resolvesource.cpp:1996">
<![LOG[ Remote : 0]LOG]!><time="13:37:19.950-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="resolvesource.cpp:1997">
<![LOG[ Internet: 0]LOG]!><time="13:37:19.950-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="resolvesource.cpp:1998">
<![LOG[sending RequestContentLocations for HOM0000C]LOG]!><time="13:37:19.950-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="libsmsmessaging.cpp:3459">
<![LOG[setting message signatures.]LOG]!><time="13:37:19.965-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="libsmsmessaging.cpp:1292">
<![LOG[setting the authenticator.]LOG]!><time="13:37:19.965-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="libsmsmessaging.cpp:1322">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: ECH-SCCM-01.HOME.COM:80 CCM_POST /ccm_system/request]LOG]!><time="13:37:19.965-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="libsmsmessaging.cpp:8422">
<![LOG[Request was succesful.]LOG]!><time="13:37:19.997-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="libsmsmessaging.cpp:8758">
<![LOG[Decompressing reply body.]LOG]!><time="13:37:19.997-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="libsmsmessaging.cpp:2361">
<![LOG[::DecompressBuffer(65536)]LOG]!><time="13:37:19.997-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="ccmzlib.cpp:736">
<![LOG[Decompression (zlib) succeeded: original size 530, uncompressed size 1626.]LOG]!><time="13:37:19.997-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="ccmzlib.cpp:647">
<![LOG[Location Reply: <ContentLocationReply SchemaVersion=1.00"><ContentInfo PackageFlags="16777216"/><Sites><Site><MPSite SiteCode="HOM" MasterSiteCode="HOM" SiteLocality="LOCAL" IISPreferedPort="80" IISSSLPreferedPort="443"/><LocationRecords><LocationRecord><URL Name="http://ECH-SCCM-01.HOME.COM/SMS_DP_SMSPKG$/HOM0000C" Signature="http://ECH-SCCM-01.HOME.COM/SMS_DP_SMSPKG$/HOM0000C]LOG]!><time="13:37:19.997-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="resolvesource.cpp:2114">
<![LOG[Prioritized locations:]LOG]!><time="13:37:19.997-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="resolvesource.cpp:2143">
<![LOG[ LOG]!><time="13:37:19.997-60"http://ECH-SCCM-01.HOME.COM/SMS_DP_SMSPKG$/HOM0000C]LOG]!><time="13:37:19.997-60/a"]http://ECH-SCCM-01.HOME.COM/SMS_DP_SMSPKG$/HOM0000C]LOG]!><time="13:37:19.997-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:2612">
<![LOG[Getting policy for CCM_SoftwareDistribution[AdvertID=HOM2000C", PackageID="HOM00014", ProgramID="*]]LOG]!><time="13:37:19.997-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:2379">
<![LOG[Downloading policy body DEP-HOM2000C-HOM00014-6F6BCC28.]LOG]!><time="13:37:19.997-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="tspolicy.cpp:1992">
<![LOG[Preparing Policy Body Request.]LOG]!><time="13:37:19.997-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:1995">
<![LOG[ Setting transport.]LOG]!><time="13:37:19.997-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:1996">
<![LOG[ Setting policy location = LOG]!><time="13:37:19.997-60"http://<mp>/SMS_MP/.sms_pol?DEP-HOM2000C-HOM00014-6F6BCC28.1_00.]LOG]!><time="13:37:19.997-60/a"]HTTP://<MP>/SMS_MP/.SMS_POL?DEP-HOM2000C-HOM00014-6F6BCC28.1_00]LOG]!><time="13:37:20.012-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="libsmsmessaging.cpp:4806">
<![LOG[Response ID: DEP-HOM2000C-HOM00014-6F6BCC28]LOG]!><time="13:37:20.012-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="libsmsmessaging.cpp:4807">
<![LOG[Reading Policy Body.]LOG]!><time="13:37:20.012-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:2023">
<![LOG[Parsing Policy Body.]LOG]!><time="13:37:20.012-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:2030">
<![LOG[Getting content hash value for reference package HOM00014 from policy]LOG]!><time="13:37:20.012-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="tspolicy.cpp:2455">
<![LOG[successfully resolved policy for HOM00014.]LOG]!><time="13:37:20.012-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:2510">
<![LOG[Resolving content location for HOM00014]LOG]!><time="13:37:20.012-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:2527">
<![LOG[Getting network access account.]LOG]!><time="13:37:20.012-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:1788">
<![LOG[Found NetworkAccessUsername/NetworkAccessPassword from NAAConfig CCM_NetworkAccessAccount]LOG]!><time="13:37:20.012-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="tspolicy.cpp:1702">
<![LOG[Network Access Account has a non-empty value]LOG]!><time="13:37:20.012-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="tspolicy.cpp:1734">
<![LOG[Getting local network information.]LOG]!><time="13:37:20.012-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="resolvesource.cpp:1988">
<![LOG[DHCP entry points already initialized.]LOG]!><time="13:37:20.012-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="ccmiputil.cpp:75">
<![LOG[begin checking Alternate Network Configuration]LOG]!><time="13:37:20.012-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="ccmiputil.cpp:1069">
<![LOG[spNamespace.Open(sNamespacePath), HRESULT=8004100e (e:\nts_sccm_release\sms\framework\ccmutillib\ccmiputil.cpp,1083)]LOG]!><time="13:37:20.028-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="ccmiputil.cpp:1083">
<![LOG[Finished checking Alternate Network Configuration]LOG]!><time="13:37:20.028-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="ccmiputil.cpp:1146">
<![LOG[Adapter {5020B3E0-A910-43FA-965B-14BC01B0DD9C} is DHCP enabled. Checking quarantine status.]LOG]!><time="13:37:20.028-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="ccmiputil.cpp:416">
<![LOG[Content location request:]LOG]!><time="13:37:20.028-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="resolvesource.cpp:1993">
<![LOG[ Package : HOM00014.1]LOG]!><time="13:37:20.028-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="resolvesource.cpp:1994">
<![LOG[ Client : GUID:0E35F46D-665F-444C-9AB2-DE329D1540A7]LOG]!><time="13:37:20.028-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="resolvesource.cpp:1995">
<![LOG[ Local : 1]LOG]!><time="13:37:20.028-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="resolvesource.cpp:1996">
<![LOG[ Remote : 0]LOG]!><time="13:37:20.028-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="resolvesource.cpp:1997">
<![LOG[ Internet: 0]LOG]!><time="13:37:20.028-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="resolvesource.cpp:1998">
<![LOG[sending RequestContentLocations for HOM00014]LOG]!><time="13:37:20.028-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="libsmsmessaging.cpp:3459">
<![LOG[setting message signatures.]LOG]!><time="13:37:20.044-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="libsmsmessaging.cpp:1292">
<![LOG[setting the authenticator.]LOG]!><time="13:37:20.044-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="libsmsmessaging.cpp:1322">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: ECH-SCCM-01.HOME.COM:80 CCM_POST /ccm_system/request]LOG]!><time="13:37:20.044-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="libsmsmessaging.cpp:8422">
<![LOG[Request was succesful.]LOG]!><time="13:37:20.075-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="libsmsmessaging.cpp:8758">
<![LOG[Decompressing reply body.]LOG]!><time="13:37:20.075-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="libsmsmessaging.cpp:2361">
<![LOG[::DecompressBuffer(65536)]LOG]!><time="13:37:20.075-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="ccmzlib.cpp:736">
<![LOG[Decompression (zlib) succeeded: original size 527, uncompressed size 1612.]LOG]!><time="13:37:20.075-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="ccmzlib.cpp:647">
<![LOG[Location Reply: <ContentLocationReply SchemaVersion=1.00"><ContentInfo PackageFlags="0"/><Sites><Site><MPSite SiteCode="HOM" MasterSiteCode="HOM" SiteLocality="LOCAL" IISPreferedPort="80" IISSSLPreferedPort="443"/><LocationRecords><LocationRecord><URL Name="http://ECH-SCCM-01.HOME.COM/SMS_DP_SMSPKG$/HOM00014" Signature="http://ECH-SCCM-01.HOME.COM/SMS_DP_SMSPKG$/HOM00014]LOG]!><time="13:37:20.075-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="resolvesource.cpp:2114">
<![LOG[Prioritized locations:]LOG]!><time="13:37:20.075-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="resolvesource.cpp:2143">
<![LOG[ LOG]!><time="13:37:20.075-60"http://ECH-SCCM-01.HOME.COM/SMS_DP_SMSPKG$/HOM00014]LOG]!><time="13:37:20.075-60/a"]http://ECH-SCCM-01.HOME.COM/SMS_DP_SMSPKG$/HOM00014]LOG]!><time="13:37:20.075-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:2612">
<![LOG[No need to register providers]LOG]!><time="13:37:20.075-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="tsmbootstraputil.cpp:954">
<![LOG[Registering the Progress UI.]LOG]!><time="13:37:20.075-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tsmediawizardcontrol.cpp:1678">
<![LOG[Command line for extension .exe is "%1" %*]LOG]!><time="13:37:20.075-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="commandline.cpp:228">
<![LOG[set command line: "X:\sms\bin\x64\TsProgressUI.exe" /Register:WinPE]LOG]!><time="13:37:20.075-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="commandline.cpp:705">
<![LOG[Executing command line: "X:\sms\bin\x64\TsProgressUI.exe" /Register:WinPE]LOG]!><time="13:37:20.075-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="commandline.cpp:801">
<![LOG[==========[ TsProgressUI started in process 204 ]==========]LOG]!><time="13:37:20.106-60" date="06-16-2012" component="TsProgressUI" context="" type="1" thread="252" file="winmain.cpp:329">
<![LOG[Command line: "X:\sms\bin\x64\TsProgressUI.exe" /Register:WinPE]LOG]!><time="13:37:20.106-60" date="06-16-2012" component="TsProgressUI" context="" type="0" thread="252" file="winmain.cpp:332">
<![LOG[Registering COM classes]LOG]!><time="13:37:20.106-60" date="06-16-2012" component="TsProgressUI" context="" type="1" thread="252" file="winmain.cpp:187">
<![LOG[sbModulePath = X:\sms\bin\x64\TsProgressUI.exe]LOG]!><time="13:37:20.106-60" date="06-16-2012" component="TsProgressUI" context="" type="1" thread="252" file="tsprogressuiclass.cpp:625">
<![LOG[unregistering class objects]LOG]!><time="13:37:20.122-60" date="06-16-2012" component="TsProgressUI" context="" type="1" thread="252" file="winmain.cpp:495">
<![LOG[shutdown complete.]LOG]!><time="13:37:20.122-60" date="06-16-2012" component="TsProgressUI" context="" type="1" thread="252" file="winmain.cpp:512">
<![LOG[Process completed with exit code 0]LOG]!><time="13:37:20.122-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="commandline.cpp:1098">
<![LOG[successfully registered TS Progress UI.]LOG]!><time="13:37:20.122-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="utils.cpp:2034">
<![LOG[Creating the Task Sequencing Environment.]LOG]!><time="13:37:20.122-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tsmediawizardcontrol.cpp:1685">
<![LOG[setting Media Variables in Task Sequencing Environment.]LOG]!><time="13:37:20.122-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tsmediawizardcontrol.cpp:1691">
<![LOG[setting WinPE Flag in the Task Sequencing Environment.]LOG]!><time="13:37:20.122-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tsmediawizardcontrol.cpp:1715">
<![LOG[setting Media Type Flag in the Task Sequencing Environment.]LOG]!><time="13:37:20.122-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tsmediawizardcontrol.cpp:1721">
<![LOG[setting Local Computer Name in the Task Sequencing Environment.]LOG]!><time="13:37:20.122-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tsmediawizardcontrol.cpp:1727">
<![LOG[setting Selected Task Sequence Information Task Sequencing Environment.]LOG]!><time="13:37:20.122-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tsmediawizardcontrol.cpp:1734">
<![LOG[setting selected task sequence information in the environment.]LOG]!><time="13:37:20.122-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="tspolicy.cpp:3401">
<![LOG[::CompressBuffer(65536,-1)]LOG]!><time="13:37:20.137-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="ccmzlib.cpp:696">
<![LOG[Compression (zlib) succeeded: original size 21778, compressed size 2671.]LOG]!><time="13:37:20.137-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="ccmzlib.cpp:485">
<![LOG[setting source for HOM00004 to ]LOG]!><time="13:37:20.137-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="resolvesource.cpp:3665">
<![LOG[setting _SMSTSHTTPHOM00004 to LOG]!><time="13:37:20.137-60"http://ECH-SCCM-01.HOME.COM/SMS_DP_SMSPKG$/HOM00004]LOG]!><time="13:37:20.137-60/a"]http://ECH-SCCM-01.HOME.COM/SMS_DP_SMSPKG$/HOM0000C]LOG]!><time="13:37:20.137-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="tspolicy.cpp:3540">
<![LOG[setting _SMSTSPKGFLAGSHOM0000C to 16777216]LOG]!><time="13:37:20.137-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="tspolicy.cpp:3564">
<![LOG[Compression (zlib) succeeded: original size 21914, compressed size 2697.]LOG]!><time="13:37:20.137-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="ccmzlib.cpp:485">
<![LOG[setting source for HOM00014 to ]LOG]!><time="13:37:20.137-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="resolvesource.cpp:3665">
<![LOG[setting _SMSTSHTTPHOM00014 to LOG]!><time="13:37:20.137-60"http://ECH-SCCM-01.HOME.COM/SMS_DP_SMSPKG$/HOM00014]LOG]!><time="13:37:20.137-60/a"]http://<mp>/SMS_MP/.sms_pol?{5ae4de1b-de35-40eb-a214-f061d8a3d0a2}.2_00.]LOG]!><time="13:37:20.184-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:1998">
<![LOG[Executing Policy Body Request.]LOG]!><time="13:37:20.184-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:2015">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: ECH-SCCM-01.HOME.COM:80 GET /SMS_MP/.sms_pol?{5ae4de1b-de35-40eb-a214-f061d8a3d0a2}.2_00]LOG]!><time="13:37:20.184-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="libsmsmessaging.cpp:8422">
<![LOG[Request was succesful.]LOG]!><time="13:37:20.184-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="libsmsmessaging.cpp:8758">
<![LOG[Hash computed from CSP: Microsoft Enhanced RSA and AES Cryptographic Provider, AlgID: 32772, HashSize: 20 ]LOG]!><time="13:37:20.184-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="libcrypt.cpp:481">
<![LOG[Expected Hash size: 20, Computed Hash size: 20 ]LOG]!><time="13:37:20.184-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="libcrypt.cpp:528">
<![LOG[Request location: LOG]!><time="13:37:20.184-60"HTTP://<MP>/SMS_MP/.SMS_POL?{5AE4DE1B-DE35-40EB-A214-F061D8A3D0A2}.2_00]LOG]!><time="13:37:20.184-60/a"]http://<mp>/SMS_MP/.sms_pol?{469f0815-74cc-46e3-9abe-bc53714f71ab}.1_00.]LOG]!><time="13:37:20.200-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:1998">
<![LOG[Executing Policy Body Request.]LOG]!><time="13:37:20.200-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:2015">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: ECH-SCCM-01.HOME.COM:80 GET /SMS_MP/.sms_pol?{469f0815-74cc-46e3-9abe-bc53714f71ab}.1_00]LOG]!><time="13:37:20.200-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="libsmsmessaging.cpp:8422">
<![LOG[Request was succesful.]LOG]!><time="13:37:20.200-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="libsmsmessaging.cpp:8758">
<![LOG[Hash computed from CSP: Microsoft Enhanced RSA and AES Cryptographic Provider, AlgID: 32772, HashSize: 20 ]LOG]!><time="13:37:20.200-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="libcrypt.cpp:481">
<![LOG[Expected Hash size: 20, Computed Hash size: 20 ]LOG]!><time="13:37:20.200-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="libcrypt.cpp:528">
<![LOG[Request location: LOG]!><time="13:37:20.200-60"HTTP://<MP>/SMS_MP/.SMS_POL?{469F0815-74CC-46E3-9ABE-BC53714F71AB}.1_00]LOG]!><time="13:37:20.200-60/a"]http://<mp>/SMS_MP/.sms_pol?{8c892d8b-71e8-43fa-b7e0-459f78aa57a8}.1_00.]LOG]!><time="13:37:20.200-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:1998">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: ECH-SCCM-01.HOME.COM:80 GET /SMS_MP/.sms_pol?{8c892d8b-71e8-43fa-b7e0-459f78aa57a8}.1_00]LOG]!><time="13:37:20.215-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="libsmsmessaging.cpp:8422">
<![LOG[Request was succesful.]LOG]!><time="13:37:20.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="libsmsmessaging.cpp:8758">
<![LOG[Hash computed from CSP: Microsoft Enhanced RSA and AES Cryptographic Provider, AlgID: 32772, HashSize: 20 ]LOG]!><time="13:37:20.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="libcrypt.cpp:481">
<![LOG[Expected Hash size: 20, Computed Hash size: 20 ]LOG]!><time="13:37:20.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="libcrypt.cpp:528">
<![LOG[Request location: LOG]!><time="13:37:20.215-60"HTTP://<MP>/SMS_MP/.SMS_POL?{8C892D8B-71E8-43FA-B7E0-459F78AA57A8}.1_00]LOG]!><time="13:37:20.215-60/a"]http://<mp>/SMS_MP/.sms_pol?{581841f2-9727-4d91-bdb2-818d49f2c88f}.1_00.]LOG]!><time="13:37:20.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:1998">
<![LOG[Executing Policy Body Request.]LOG]!><time="13:37:20.215-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:2015">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: ECH-SCCM-01.HOME.COM:80 GET /SMS_MP/.sms_pol?{581841f2-9727-4d91-bdb2-818d49f2c88f}.1_00]LOG]!><time="13:37:20.231-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="libsmsmessaging.cpp:8422">
<![LOG[Request was succesful.]LOG]!><time="13:37:20.231-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="libsmsmessaging.cpp:8758">
<![LOG[Hash computed from CSP: Microsoft Enhanced RSA and AES Cryptographic Provider, AlgID: 32772, HashSize: 20 ]LOG]!><time="13:37:20.231-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="libcrypt.cpp:481">
<![LOG[Expected Hash size: 20, Computed Hash size: 20 ]LOG]!><time="13:37:20.231-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="libcrypt.cpp:528">
<![LOG[Request location: LOG]!><time="13:37:20.231-60"HTTP://<MP>/SMS_MP/.SMS_POL?{581841F2-9727-4D91-BDB2-818D49F2C88F}.1_00]LOG]!><time="13:37:20.231-60/a"]http://<mp>/SMS_MP/.sms_pol?{4289019d-a692-4c19-b677-c8c50e31a712}.1_00.]LOG]!><time="13:37:20.247-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:1998">
<![LOG[Executing Policy Body Request.]LOG]!><time="13:37:20.247-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:2015">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: ECH-SCCM-01.HOME.COM:80 GET /SMS_MP/.sms_pol?{4289019d-a692-4c19-b677-c8c50e31a712}.1_00]LOG]!><time="13:37:20.247-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="libsmsmessaging.cpp:8422">
<![LOG[Request was succesful.]LOG]!><time="13:37:20.247-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="libsmsmessaging.cpp:8758">
<![LOG[Hash computed from CSP: Microsoft Enhanced RSA and AES Cryptographic Provider, AlgID: 32772, HashSize: 20 ]LOG]!><time="13:37:20.247-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="libcrypt.cpp:481">
<![LOG[Expected Hash size: 20, Computed Hash size: 20 ]LOG]!><time="13:37:20.247-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="libcrypt.cpp:528">
<![LOG[Request location: LOG]!><time="13:37:20.247-60"HTTP://<MP>/SMS_MP/.SMS_POL?{4289019D-A692-4C19-B677-C8C50E31A712}.1_00]LOG]!><time="13:37:20.247-60/a"]http://<mp>/SMS_MP/.sms_pol?{ef8caf4a-1171-47e6-bff3-871dc012009d}.1_00.]LOG]!><time="13:37:20.247-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:1998">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: ECH-SCCM-01.HOME.COM:80 GET /SMS_MP/.sms_pol?{ef8caf4a-1171-47e6-bff3-871dc012009d}.1_00]LOG]!><time="13:37:20.262-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="libsmsmessaging.cpp:8422">
<![LOG[Request was succesful.]LOG]!><time="13:37:20.262-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="libsmsmessaging.cpp:8758">
<![LOG[Hash computed from CSP: Microsoft Enhanced RSA and AES Cryptographic Provider, AlgID: 32772, HashSize: 20 ]LOG]!><time="13:37:20.262-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="libcrypt.cpp:481">
<![LOG[Expected Hash size: 20, Computed Hash size: 20 ]LOG]!><time="13:37:20.262-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="libcrypt.cpp:528">
<![LOG[Request location: LOG]!><time="13:37:20.262-60"HTTP://<MP>/SMS_MP/.SMS_POL?{EF8CAF4A-1171-47E6-BFF3-871DC012009D}.1_00]LOG]!><time="13:37:20.262-60/a"]http://<mp>/SMS_MP/.sms_pol?Windows/All_Windows_Client_Server/VI/VS.SHA256:2D646F6A67F56E7A13A7EBF26C6488EA4BB7D9C2AA83447DFC3B3647B9015243.]LOG]!><time="13:37:20.262-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:1998">
<![LOG[Executing Policy Body Request.]LOG]!><time="13:37:20.262-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:2015">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: ECH-SCCM-01.HOME.COM:80 GET /SMS_MP/.sms_pol?Windows/All_Windows_Client_Server/VI/VS.SHA256:2D646F6A67F56E7A13A7EBF26C6488EA4BB7D9C2AA83447DFC3B3647B9015243]LOG]!><time="13:37:20.278-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="libsmsmessaging.cpp:8422">
<![LOG[Request was succesful.]LOG]!><time="13:37:20.278-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="libsmsmessaging.cpp:8758">
<![LOG[::DecompressBuffer(65536)]LOG]!><time="13:37:20.278-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="ccmzlib.cpp:736">
<![LOG[Decompression (zlib) succeeded: original size 542, uncompressed size 1906.]LOG]!><time="13:37:20.278-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="ccmzlib.cpp:647">
<![LOG[Hash computed from CSP: Microsoft Enhanced RSA and AES Cryptographic Provider, AlgID: 32780, HashSize: 32 ]LOG]!><time="13:37:20.278-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="libcrypt.cpp:481">
<![LOG[Expected Hash size: 32, Computed Hash size: 32 ]LOG]!><time="13:37:20.278-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="libcrypt.cpp:528">
<![LOG[Request location: LOG]!><time="13:37:20.278-60"HTTP://<MP>/SMS_MP/.SMS_POL?WINDOWS/ALL_WINDOWS_CLIENT_SERVER/VI/VS.SHA256:2D646F6A67F56E7A13A7EBF26C6488EA4BB7D9C2AA83447DFC3B3647B9015243]LOG]!><time="13:37:20.278-60/a"]http://<mp>/SMS_MP/.sms_pol?ScopeId_3F53CAEB-4131-41AD-B755-929FA7F36C7D/RequiredApplication_fe94a94c-8c5a-41b8-98d8-29191741eab3/VI/VS.SHA256:49A39A6EB6A2B581EC40793A17F886B3F6788E5CBADF3E69433026B3FC148221.]LOG]!><time="13:37:20.278-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:1998">
<![LOG[Executing Policy Body Request.]LOG]!><time="13:37:20.278-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:2015">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: ECH-SCCM-01.HOME.COM:80 GET /SMS_MP/.sms_pol?ScopeId_3F53CAEB-4131-41AD-B755-929FA7F36C7D/RequiredApplication_fe94a94c-8c5a-41b8-98d8-29191741eab3/VI/VS.SHA256:49A39A6EB6A2B581EC40793A17F886B3F6788E5CBADF3E69433026B3FC148221]LOG]!><time="13:37:20.278-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="libsmsmessaging.cpp:8422">
<![LOG[Request was succesful.]LOG]!><time="13:37:20.294-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="libsmsmessaging.cpp:8758">
<![LOG[::DecompressBuffer(65536)]LOG]!><time="13:37:20.294-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="ccmzlib.cpp:736">
<![LOG[Decompression (zlib) succeeded: original size 1226, uncompressed size 7014.]LOG]!><time="13:37:20.294-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="ccmzlib.cpp:647">
<![LOG[Hash computed from CSP: Microsoft Enhanced RSA and AES Cryptographic Provider, AlgID: 32780, HashSize: 32 ]LOG]!><time="13:37:20.294-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="libcrypt.cpp:481">
<![LOG[Expected Hash size: 32, Computed Hash size: 32 ]LOG]!><time="13:37:20.294-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="libcrypt.cpp:528">
<![LOG[Request location: LOG]!><time="13:37:20.294-60"HTTP://<MP>/SMS_MP/.SMS_POL?SCOPEID_3F53CAEB-4131-41AD-B755-929FA7F36C7D/REQUIREDAPPLICATION_FE94A94C-8C5A-41B8-98D8-29191741EAB3/VI/VS.SHA256:49A39A6EB6A2B581EC40793A17F886B3F6788E5CBADF3E69433026B3FC148221]LOG]!><time="13:37:20.294-60/a"]http://<mp>/SMS_MP/.sms_pol?ScopeId_3F53CAEB-4131-41AD-B755-929FA7F36C7D/RequiredApplication_3e76083b-679e-42f1-abaa-32df1fa6c3fe/VI/VS.SHA256:087DE31D46341AC86B58F05FBE9E7A724EDBDBA577424152B1503B449F54C8EB.]LOG]!><time="13:37:20.294-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:1998">
<![LOG[Executing Policy Body Request.]LOG]!><time="13:37:20.294-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:2015">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: ECH-SCCM-01.HOME.COM:80 GET /SMS_MP/.sms_pol?ScopeId_3F53CAEB-4131-41AD-B755-929FA7F36C7D/RequiredApplication_3e76083b-679e-42f1-abaa-32df1fa6c3fe/VI/VS.SHA256:087DE31D46341AC86B58F05FBE9E7A724EDBDBA577424152B1503B449F54C8EB]LOG]!><time="13:37:20.294-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="libsmsmessaging.cpp:8422">
<![LOG[Decompression (zlib) succeeded: original size 1230, uncompressed size 7014.]LOG]!><time="13:37:20.294-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="ccmzlib.cpp:647">
<![LOG[Request location: LOG]!><time="13:37:20.294-60"HTTP://<MP>/SMS_MP/.SMS_POL?SCOPEID_3F53CAEB-4131-41AD-B755-929FA7F36C7D/REQUIREDAPPLICATION_3E76083B-679E-42F1-ABAA-32DF1FA6C3FE/VI/VS.SHA256:087DE31D46341AC86B58F05FBE9E7A724EDBDBA577424152B1503B449F54C8EB]LOG]!><time="13:37:20.294-60/a"]http://<mp>/SMS_MP/.sms_pol?{3cf0bb33-ec6c-457a-ac2a-0776b53a5565}.1_00.]LOG]!><time="13:37:20.309-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:1998">
<![LOG[Executing Policy Body Request.]LOG]!><time="13:37:20.309-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="tspolicy.cpp:2015">
<![LOG[CLibSMSMessageWinHttpTransport::Send: URL: ECH-SCCM-01.HOME.COM:80 GET /SMS_MP/.sms_pol?{3cf0bb33-ec6c-457a-ac2a-0776b53a5565}.1_00]LOG]!><time="13:37:20.309-60" date="06-16-2012" component="TSPxe" context="" type="1" thread="196" file="libsmsmessaging.cpp:8422">
<![LOG[Request was succesful.]LOG]!><time="13:37:20.309-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="libsmsmessaging.cpp:8758">
<![LOG[Hash computed from CSP: Microsoft Enhanced RSA and AES Cryptographic Provider, AlgID: 32772, HashSize: 20 ]LOG]!><time="13:37:20.309-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="libcrypt.cpp:481">
<![LOG[Expected Hash size: 20, Computed Hash size: 20 ]LOG]!><time="13:37:20.309-60" date="06-16-2012" component="TSPxe" context="" type="0" thread="196" file="libcrypt.cpp:528">
Hi
Sorry i think the following log file may be more useful. Please ignore the previous log file.
<p><![LOG[ Directory: LOG]!><time="13:37:45.794-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/en-us/_default/startere]LOG]!><time="13:37:45.794-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/en-us/_default/startere/license.rtf]LOG]!><time="13:37:45.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:45.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/en-us/_default/startern]LOG]!><time="13:37:45.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/en-us/_default/startern/license.rtf]LOG]!><time="13:37:45.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:45.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/en-us/_default/ultimate]LOG]!><time="13:37:45.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/en-us/_default/ultimate/license.rtf]LOG]!><time="13:37:45.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:45.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/en-us/_default/ultimatee]LOG]!><time="13:37:45.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/en-us/_default/ultimatee/license.rtf]LOG]!><time="13:37:45.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:45.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/en-us/_default/ultimaten]LOG]!><time="13:37:45.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/en-us/_default/ultimaten/license.rtf]LOG]!><time="13:37:45.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:45.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default]LOG]!><time="13:37:45.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/eval]LOG]!><time="13:37:45.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:508">
<![LOG[ Directory: LOG]!><time="13:37:45.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/eval/enterprise]LOG]!><time="13:37:45.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/eval/enterprise/license.rtf]LOG]!><time="13:37:45.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:45.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/eval/enterprisee]LOG]!><time="13:37:45.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/eval/enterprisee/license.rtf]LOG]!><time="13:37:45.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:45.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/eval/enterprisen]LOG]!><time="13:37:45.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/eval/enterprisen/license.rtf]LOG]!><time="13:37:46.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:46.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/eval/homebasic]LOG]!><time="13:37:46.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/eval/homebasic/license.rtf]LOG]!><time="13:37:46.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:46.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/eval/homebasice]LOG]!><time="13:37:46.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/eval/homebasice/license.rtf]LOG]!><time="13:37:46.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:46.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/eval/homebasicn]LOG]!><time="13:37:46.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/eval/homebasicn/license.rtf]LOG]!><time="13:37:46.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:46.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/eval/homepremium]LOG]!><time="13:37:46.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/eval/homepremium/license.rtf]LOG]!><time="13:37:46.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:46.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/eval/homepremiume]LOG]!><time="13:37:46.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/eval/homepremiume/license.rtf]LOG]!><time="13:37:46.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:46.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/eval/homepremiumn]LOG]!><time="13:37:46.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/eval/homepremiumn/license.rtf]LOG]!><time="13:37:46.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:46.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/eval/professional]LOG]!><time="13:37:46.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/eval/professional/license.rtf]LOG]!><time="13:37:46.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:46.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/eval/professionale]LOG]!><time="13:37:46.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/eval/professionale/license.rtf]LOG]!><time="13:37:46.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:46.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/eval/professionaln]LOG]!><time="13:37:46.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/eval/professionaln/license.rtf]LOG]!><time="13:37:46.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:46.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/eval/starter]LOG]!><time="13:37:46.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/eval/starter/license.rtf]LOG]!><time="13:37:46.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:46.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/eval/startere]LOG]!><time="13:37:46.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/eval/startere/license.rtf]LOG]!><time="13:37:46.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:46.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/eval/startern]LOG]!><time="13:37:46.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/eval/startern/license.rtf]LOG]!><time="13:37:46.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:46.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/eval/ultimate]LOG]!><time="13:37:46.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/eval/ultimate/license.rtf]LOG]!><time="13:37:46.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:46.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/eval/ultimatee]LOG]!><time="13:37:46.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/eval/ultimatee/license.rtf]LOG]!><time="13:37:46.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:46.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/eval/ultimaten]LOG]!><time="13:37:46.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/eval/ultimaten/license.rtf]LOG]!><time="13:37:46.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:46.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/oem]LOG]!><time="13:37:46.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/oem/enterprise]LOG]!><time="13:37:46.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:508">
<![LOG[ File: LOG]!><time="13:37:46.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/oem/enterprise/license.rtf]LOG]!><time="13:37:46.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/oem/enterprisee]LOG]!><time="13:37:46.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:508">
<![LOG[ File: LOG]!><time="13:37:46.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/oem/enterprisee/license.rtf]LOG]!><time="13:37:46.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/oem/enterprisen]LOG]!><time="13:37:46.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:508">
<![LOG[ File: LOG]!><time="13:37:46.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/oem/enterprisen/license.rtf]LOG]!><time="13:37:46.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/oem/homebasic]LOG]!><time="13:37:46.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:508">
<![LOG[ File: LOG]!><time="13:37:46.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/oem/homebasic/license.rtf]LOG]!><time="13:37:46.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/oem/homebasice]LOG]!><time="13:37:46.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:508">
<![LOG[ File: LOG]!><time="13:37:46.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/oem/homebasice/license.rtf]LOG]!><time="13:37:46.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/oem/homebasicn]LOG]!><time="13:37:46.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:508">
<![LOG[ File: LOG]!><time="13:37:46.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/oem/homebasicn/license.rtf]LOG]!><time="13:37:46.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/oem/homepremium]LOG]!><time="13:37:46.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:508">
<![LOG[ File: LOG]!><time="13:37:46.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/oem/homepremium/license.rtf]LOG]!><time="13:37:46.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/oem/homepremiume]LOG]!><time="13:37:46.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:508">
<![LOG[ File: LOG]!><time="13:37:46.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/oem/homepremiume/license.rtf]LOG]!><time="13:37:46.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/oem/homepremiumn]LOG]!><time="13:37:46.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:508">
<![LOG[ File: LOG]!><time="13:37:46.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/oem/homepremiumn/license.rtf]LOG]!><time="13:37:46.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/oem/professional]LOG]!><time="13:37:46.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:508">
<![LOG[ File: LOG]!><time="13:37:46.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/oem/professional/license.rtf]LOG]!><time="13:37:46.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/oem/professionale]LOG]!><time="13:37:46.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:508">
<![LOG[ File: LOG]!><time="13:37:46.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/oem/professionale/license.rtf]LOG]!><time="13:37:46.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/oem/professionaln]LOG]!><time="13:37:46.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:508">
<![LOG[ File: LOG]!><time="13:37:46.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/oem/professionaln/license.rtf]LOG]!><time="13:37:46.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/oem/starter]LOG]!><time="13:37:46.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:508">
<![LOG[ File: LOG]!><time="13:37:46.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/oem/starter/license.rtf]LOG]!><time="13:37:46.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/oem/startere]LOG]!><time="13:37:46.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:508">
<![LOG[ File: LOG]!><time="13:37:46.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/oem/startere/license.rtf]LOG]!><time="13:37:46.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/oem/startern]LOG]!><time="13:37:46.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:508">
<![LOG[ File: LOG]!><time="13:37:46.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/oem/startern/license.rtf]LOG]!><time="13:37:46.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/oem/ultimate]LOG]!><time="13:37:46.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:508">
<![LOG[ File: LOG]!><time="13:37:46.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/oem/ultimate/license.rtf]LOG]!><time="13:37:46.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/oem/ultimatee]LOG]!><time="13:37:46.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:508">
<![LOG[ File: LOG]!><time="13:37:46.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/oem/ultimatee/license.rtf]LOG]!><time="13:37:46.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/oem/ultimaten]LOG]!><time="13:37:46.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:508">
<![LOG[ File: LOG]!><time="13:37:46.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/oem/ultimaten/license.rtf]LOG]!><time="13:37:46.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/_default]LOG]!><time="13:37:46.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:508">
<![LOG[ Directory: LOG]!><time="13:37:46.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/_default/enterprise]LOG]!><time="13:37:46.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/_default/enterprise/license.rtf]LOG]!><time="13:37:46.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:47.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/_default/enterprisee]LOG]!><time="13:37:47.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/_default/enterprisee/license.rtf]LOG]!><time="13:37:47.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:47.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/_default/enterprisen]LOG]!><time="13:37:47.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/_default/enterprisen/license.rtf]LOG]!><time="13:37:47.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:47.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/_default/homebasic]LOG]!><time="13:37:47.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/_default/homebasic/license.rtf]LOG]!><time="13:37:47.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:47.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/_default/homebasice]LOG]!><time="13:37:47.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/_default/homebasice/license.rtf]LOG]!><time="13:37:47.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:47.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/_default/homebasicn]LOG]!><time="13:37:47.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/_default/homebasicn/license.rtf]LOG]!><time="13:37:47.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:47.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/_default/homepremium]LOG]!><time="13:37:47.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/_default/homepremium/license.rtf]LOG]!><time="13:37:47.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:47.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/_default/homepremiume]LOG]!><time="13:37:47.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/_default/homepremiume/license.rtf]LOG]!><time="13:37:47.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:47.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/_default/homepremiumn]LOG]!><time="13:37:47.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/_default/homepremiumn/license.rtf]LOG]!><time="13:37:47.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:47.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/_default/lipeula.rtf]LOG]!><time="13:37:47.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/_default/lpeula.rtf]LOG]!><time="13:37:47.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:47.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/_default/professional]LOG]!><time="13:37:47.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/_default/professional/license.rtf]LOG]!><time="13:37:47.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:47.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/_default/professionale]LOG]!><time="13:37:47.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/_default/professionale/license.rtf]LOG]!><time="13:37:47.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:47.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/_default/professionaln]LOG]!><time="13:37:47.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/_default/professionaln/license.rtf]LOG]!><time="13:37:47.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:47.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/_default/starter]LOG]!><time="13:37:47.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/_default/starter/license.rtf]LOG]!><time="13:37:47.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:47.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/_default/startere]LOG]!><time="13:37:47.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/_default/startere/license.rtf]LOG]!><time="13:37:47.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:47.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/_default/startern]LOG]!><time="13:37:47.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/_default/startern/license.rtf]LOG]!><time="13:37:47.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:47.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/_default/ultimate]LOG]!><time="13:37:47.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/_default/ultimate/license.rtf]LOG]!><time="13:37:47.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:47.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/_default/ultimatee]LOG]!><time="13:37:47.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/_default/ultimatee/license.rtf]LOG]!><time="13:37:47.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:47.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/_default/ultimaten]LOG]!><time="13:37:47.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/license/_default/_default/ultimaten/license.rtf]LOG]!><time="13:37:47.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:47.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/locale.nls]LOG]!><time="13:37:47.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/locdrv.dll]LOG]!><time="13:37:47.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:47.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/logprovider.dll]LOG]!><time="13:37:47.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/migisol.dll]LOG]!><time="13:37:47.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:47.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/migtestplugin.dll]LOG]!><time="13:37:47.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/mofd.dll]LOG]!><time="13:37:47.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:47.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/mofinstall.dll]LOG]!><time="13:37:47.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/msdelta.dll]LOG]!><time="13:37:47.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:47.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/msftedit.dll]LOG]!><time="13:37:47.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/mspatcha.dll]LOG]!><time="13:37:47.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:47.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/msxml6.dll]LOG]!><time="13:37:47.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/msxml6r.dll]LOG]!><time="13:37:47.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:47.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/ndiscompl.dll]LOG]!><time="13:37:47.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/nlsbres.dll]LOG]!><time="13:37:47.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:47.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/ntdsupg.dll]LOG]!><time="13:37:47.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/ntfrsupg.dll]LOG]!><time="13:37:47.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:47.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/oemhelpins.dll]LOG]!><time="13:37:47.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/offline.xml]LOG]!><time="13:37:47.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:47.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/oscomps.xml]LOG]!><time="13:37:47.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/osfilter.inf]LOG]!><time="13:37:47.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:47.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/pidgenx.dll]LOG]!><time="13:37:47.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/pkeyconfig.xrm-ms]LOG]!><time="13:37:47.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:47.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/pnpibs.dll]LOG]!><time="13:37:47.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/product.ini]LOG]!><time="13:37:47.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:47.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/readme.rtf]LOG]!><time="13:37:47.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/repdrvfs.dll]LOG]!><time="13:37:47.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:47.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests]LOG]!><time="13:37:47.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/activedirectory-webservices-replacement.man]LOG]!><time="13:37:47.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:47.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/application-experience-program-compatibility-assistant-replacement.man]LOG]!><time="13:37:47.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/audiommecore-other-migration-replacement.man]LOG]!><time="13:37:47.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:47.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/authui-migration-replacement.man]LOG]!><time="13:37:47.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/bthmig-replacement.man]LOG]!><time="13:37:47.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:47.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/capi2_certs-repl.man]LOG]!><time="13:37:47.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/dhcpclientdll-repl.man]LOG]!><time="13:37:47.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:47.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/dhcpservermigplugin-rep.man]LOG]!><time="13:37:47.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/ehome-reg-inf_repl.man]LOG]!><time="13:37:47.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:47.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/en-us]LOG]!><time="13:37:47.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/eudcedit-replacement.man]LOG]!><time="13:37:47.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:48.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/extensibleauthenticationprotocolhostservice-rep.man]LOG]!><time="13:37:48.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/failovercluster-core-wow64-rm.man]LOG]!><time="13:37:48.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:48.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/fonts-type1-replacement.man]LOG]!><time="13:37:48.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/fundisc-replacement.man]LOG]!><time="13:37:48.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:48.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/gameuxmig-replacement.man]LOG]!><time="13:37:48.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/iis-ftpextensibility-rm.man]LOG]!><time="13:37:48.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:48.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/iis-ftpsvc-rm.man]LOG]!><time="13:37:48.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/iis-powershellprovider-rm.man]LOG]!><time="13:37:48.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:48.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/iis-sharedlibraries-rm.man]LOG]!><time="13:37:48.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/iis-webdav-rm.man]LOG]!><time="13:37:48.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:48.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/international-core-replacement.man]LOG]!><time="13:37:48.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/ipv4ipv6coexistencemigration-replacement.man]LOG]!><time="13:37:48.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:48.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/microsoft-activedirectory-webservices]LOG]!><time="13:37:48.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/microsoft-activedirectory-webservices/adwsmigrate.dll]LOG]!><time="13:37:48.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:48.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/microsoft-hyper-v]LOG]!><time="13:37:48.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/microsoft-hyper-v/vmswitchmigrationplugin.dll]LOG]!><time="13:37:48.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:48.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/microsoft-hyper-v-client-migration-replacement.man]LOG]!><time="13:37:48.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/microsoft-hyper-v-drivers-migration-replacement.man]LOG]!><time="13:37:48.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:48.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/microsoft-hyper-v-migration-replacement.man]LOG]!><time="13:37:48.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/microsoft-international-core]LOG]!><time="13:37:48.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:508">
<![LOG[ File: LOG]!><time="13:37:48.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/microsoft-international-core/nlscoremig.dll]LOG]!><time="13:37:48.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/microsoft-windows-audio-mmecore-other]LOG]!><time="13:37:48.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:508">
<![LOG[ File: LOG]!><time="13:37:48.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/microsoft-windows-audio-mmecore-other/audmigplugin.dll]LOG]!><time="13:37:48.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/microsoft-windows-bth-user]LOG]!><time="13:37:48.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:508">
<![LOG[ File: LOG]!><time="13:37:48.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/microsoft-windows-bth-user/bthmigplugin.dll]LOG]!><time="13:37:48.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/microsoft-windows-fax-service-replacement.man]LOG]!><time="13:37:48.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:48.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/microsoft-windows-gameuxmig]LOG]!><time="13:37:48.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/microsoft-windows-gameuxmig/gameuxmig.dll]LOG]!><time="13:37:48.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:48.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/microsoft-windows-ie-adminkitbranding-repl.man]LOG]!><time="13:37:48.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/microsoft-windows-ie-internetexplorer-repl.man]LOG]!><time="13:37:48.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:48.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/microsoft-windows-iis-rm]LOG]!><time="13:37:48.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/microsoft-windows-iis-rm/iismig.dll]LOG]!><time="13:37:48.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:48.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/microsoft-windows-ndis]LOG]!><time="13:37:48.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/microsoft-windows-ndis/ndismigplugin.dll]LOG]!><time="13:37:48.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:48.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/microsoft-windows-netfx35cdfcomp-replacement.man]LOG]!><time="13:37:48.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/microsoft-windows-netfxcorecomp-repl.man]LOG]!><time="13:37:48.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:48.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/microsoft-windows-offlinefiles-core]LOG]!><time="13:37:48.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/microsoft-windows-offlinefiles-core/cscmig.dll]LOG]!><time="13:37:48.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:48.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/microsoft-windows-offlinefiles-core/en-us]LOG]!><time="13:37:48.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/microsoft-windows-offlinefiles-core/en-us/cscmig.dll.mui]LOG]!><time="13:37:48.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:48.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/microsoft-windows-offlinefiles-replacement.man]LOG]!><time="13:37:48.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/microsoft-windows-power-policy]LOG]!><time="13:37:48.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:508">
<![LOG[ File: LOG]!><time="13:37:48.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/microsoft-windows-power-policy/powermigplugin.dll]LOG]!><time="13:37:48.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/microsoft-windows-securestartup-filterdriver-replacement.man]LOG]!><time="13:37:48.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:48.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/microsoft-windows-shmig]LOG]!><time="13:37:48.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/microsoft-windows-shmig/shmig.dll]LOG]!><time="13:37:48.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:48.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/microsoft-windows-terminalservices-appserver-licensing]LOG]!><time="13:37:48.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/microsoft-windows-terminalservices-appserver-licensing/tsmigplugin.dll]LOG]!><time="13:37:48.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:48.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/microsoft-windows-terminalservices-licenseserver]LOG]!><time="13:37:48.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/microsoft-windows-terminalservices-licenseserver/tlsrepplugin.dll]LOG]!><time="13:37:48.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:48.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/microsoft-windows-wcfcorecomp-replacement.man]LOG]!><time="13:37:48.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/microsoft.windows.servermanager-non_msil-replacement.man]LOG]!><time="13:37:48.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:48.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/mmsys-migration-replacement.man]LOG]!><time="13:37:48.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/ndis-repl.man]LOG]!><time="13:37:48.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:48.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/nfs-admincore-repl.man]LOG]!><time="13:37:48.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/nfs-clientcore-repl.man]LOG]!><time="13:37:48.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:48.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/nfs-servercore-repl.man]LOG]!><time="13:37:48.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/powermanagement-powerpolicy-definitions-replacement.man]LOG]!><time="13:37:48.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:48.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/powermanagement-powerpolicy-migration-replacement.man]LOG]!><time="13:37:48.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/printing-localprinting-replacement.man]LOG]!><time="13:37:48.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:48.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/printing-servercore-wow64-rm.man]LOG]!><time="13:37:48.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/propsys-replacement.man]LOG]!><time="13:37:49.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:49.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/provsvc-replacement.man]LOG]!><time="13:37:49.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/rasapi-repl.man]LOG]!><time="13:37:49.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:49.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/rasmanservice-repl.man]LOG]!><time="13:37:49.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/rasppp-repl.man]LOG]!><time="13:37:49.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:49.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/rights-management-client-v1-api-replacement.man]LOG]!><time="13:37:49.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/servercore-ea-ime-wow64-rm.man]LOG]!><time="13:37:49.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:49.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/servercore-wow64-rm.man]LOG]!><time="13:37:49.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/shmig-replacement.man]LOG]!><time="13:37:49.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:49.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/sounds-migration-replacement.man]LOG]!><time="13:37:49.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/srm-datascrndriver-repl.man]LOG]!><time="13:37:49.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:49.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/srm-quotadriver-repl.man]LOG]!><time="13:37:49.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/srm-service-repl.man]LOG]!><time="13:37:49.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:49.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/srm-service-reports-repl.man]LOG]!><time="13:37:49.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/srm-ui-repl.man]LOG]!><time="13:37:49.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:49.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/stickynotes-replacement.man]LOG]!><time="13:37:49.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/suacore-wow64-rm.man]LOG]!><time="13:37:49.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:49.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/sysdm-replacement.man]LOG]!><time="13:37:49.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/sysmain-replacement.man]LOG]!><time="13:37:49.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:49.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/tabletpc-uihub-replacement.man]LOG]!><time="13:37:49.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/tabletpcplatforminput-core-replacement.man]LOG]!><time="13:37:49.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:49.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/tabletpcstickynotes-replacement.man]LOG]!><time="13:37:49.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/tcpip-replacement.man]LOG]!><time="13:37:49.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:49.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/terminalservices-appserver-licensing-replacement.man]LOG]!><time="13:37:49.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/terminalservices-licenseserver-replacement.man]LOG]!><time="13:37:49.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:49.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/terminalservices-manager-snapin-replacement.man]LOG]!><time="13:37:49.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/terminalservices-rapwebpart-replacement.man]LOG]!><time="13:37:49.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:49.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/terminalservices-sbmgr-snapin-non_msil-replacement.man]LOG]!><time="13:37:49.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/usb]LOG]!><time="13:37:49.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:508">
<![LOG[ File: LOG]!><time="13:37:49.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/usb/usbmigplugin.dll]LOG]!><time="13:37:49.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/usbmigplugin-replacement.man]LOG]!><time="13:37:49.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:49.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/virtualdiskservice-repl.man]LOG]!><time="13:37:49.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/vssservice-repl.man]LOG]!><time="13:37:49.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:49.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/vsssystemprovider-replacement.man]LOG]!><time="13:37:49.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/wcf-http-activation-replacement.man]LOG]!><time="13:37:49.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:49.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/wcf-nonhttp-activation-replacement.man]LOG]!><time="13:37:49.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/windows-markettheme-mctadmin-component-replacement.man]LOG]!><time="13:37:49.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:49.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/windowssearchengine]LOG]!><time="13:37:49.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/windowssearchengine/wsearchmigplugin.dll]LOG]!><time="13:37:49.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:49.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/windowssearchengine-replacement.man]LOG]!><time="13:37:49.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/wmdmigration-replacement.man]LOG]!><time="13:37:49.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:49.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/wmi-core-replacement.man]LOG]!><time="13:37:49.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/replacementmanifests/wsrm-service-replacement.man]LOG]!><time="13:37:49.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:49.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/rmsupg.dll]LOG]!><time="13:37:49.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/rollback.exe]LOG]!><time="13:37:49.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:49.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/schema.dat]LOG]!><time="13:37:49.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/sdbapiu.dll]LOG]!><time="13:37:49.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:49.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/segoeui.ttf]LOG]!><time="13:37:49.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/servicing]LOG]!><time="13:37:49.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:508">
<![LOG[ Directory: LOG]!><time="13:37:49.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/servicing/0.0.0.1]LOG]!><time="13:37:49.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/servicing/0.0.0.1/xmllite.dll]LOG]!><time="13:37:49.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:49.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/servicingstackmisc]LOG]!><time="13:37:49.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/servicingstackmisc/apds.dll]LOG]!><time="13:37:49.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:49.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/servicingstackmisc/apircl.dll]LOG]!><time="13:37:49.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/servicingstackmisc/apss.dll]LOG]!><time="13:37:49.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:49.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/setup.exe]LOG]!><time="13:37:49.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/sfcn.dat]LOG]!><time="13:37:49.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:49.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/sflcid.dat]LOG]!><time="13:37:49.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/sflistlh.dat]LOG]!><time="13:37:49.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:49.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/sflistw7.dat]LOG]!><time="13:37:49.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/sflistxp.dat]LOG]!><time="13:37:49.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:49.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/sfpat.inf]LOG]!><time="13:37:49.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/sfpatlh.inf]LOG]!><time="13:37:49.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:49.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/sfpatpg.inf]LOG]!><time="13:37:49.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/sfpatw7.inf]LOG]!><time="13:37:49.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:49.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/sfpatxp.inf]LOG]!><time="13:37:49.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/smiengine.dll]LOG]!><time="13:37:49.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:49.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/smipi.dll]LOG]!><time="13:37:49.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/sperr32.exe]LOG]!><time="13:37:49.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:49.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/spflvrnt.dll]LOG]!><time="13:37:49.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/spprgrss.dll]LOG]!><time="13:37:49.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:49.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/spwizeng.dll]LOG]!><time="13:37:49.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/spwizimg.dll]LOG]!><time="13:37:49.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:49.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/spwizres.dll]LOG]!><time="13:37:49.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/sqmapi.dll]LOG]!><time="13:37:50.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:50.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/ssshim.dll]LOG]!><time="13:37:50.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/sysmain.sdb]LOG]!><time="13:37:50.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:50.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/sysmain32.sdb]LOG]!><time="13:37:50.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/uddicomp.dll]LOG]!><time="13:37:50.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:50.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/unattend.dll]LOG]!><time="13:37:50.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/unbcl.dll]LOG]!><time="13:37:50.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:50.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/upgcmi2migxml.dll]LOG]!><time="13:37:50.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/upgcompat.inf]LOG]!><time="13:37:50.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:50.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/upgcore.dll]LOG]!><time="13:37:50.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/upgcsiagent.dll]LOG]!><time="13:37:50.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:50.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/upgdriver.dll]LOG]!><time="13:37:50.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/upghost.exe]LOG]!><time="13:37:50.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:50.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/upgloader.dll]LOG]!><time="13:37:50.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/upgmxeagent.dll]LOG]!><time="13:37:50.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:50.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/upgradeagent.dll]LOG]!><time="13:37:50.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/upgradeagent.xml]LOG]!><time="13:37:50.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:50.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/upgrade_bulk.xml]LOG]!><time="13:37:50.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/upgreport.dll]LOG]!><time="13:37:50.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:50.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/upgres.dll]LOG]!><time="13:37:50.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/upgwow_bulk.xml]LOG]!><time="13:37:50.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:50.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/uxlib.dll]LOG]!><time="13:37:50.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/uxlibres.dll]LOG]!><time="13:37:50.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:50.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/vofflps.rtf]LOG]!><time="13:37:50.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/w32uiimg.dll]LOG]!><time="13:37:50.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:50.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/w32uires.dll]LOG]!><time="13:37:50.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/warning.gif]LOG]!><time="13:37:50.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:50.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/wbemcomn.dll]LOG]!><time="13:37:50.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/wbemcore.dll]LOG]!><time="13:37:50.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:50.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/wbemprox.dll]LOG]!><time="13:37:50.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/wcmtypes.xsd]LOG]!><time="13:37:50.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:50.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/wcp.dll]LOG]!><time="13:37:50.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/wdsclient.dll]LOG]!><time="13:37:50.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:50.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/wdsclientapi.dll]LOG]!><time="13:37:50.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/wdscore.dll]LOG]!><time="13:37:50.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:50.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/wdscsl.dll]LOG]!><time="13:37:50.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/wdsimage.dll]LOG]!><time="13:37:50.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:50.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/wdstptc.dll]LOG]!><time="13:37:50.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/wdsupgcompl.dll]LOG]!><time="13:37:50.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:50.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/wdsutil.dll]LOG]!><time="13:37:50.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/win32ui.dll]LOG]!><time="13:37:50.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:50.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/winsetup.dll]LOG]!><time="13:37:50.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/wmicmiplugin.dll]LOG]!><time="13:37:50.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:50.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/wmiutils.dll]LOG]!><time="13:37:50.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/wmi_tracing.mof]LOG]!><time="13:37:50.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:50.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/sources/xmllite.dll]LOG]!><time="13:37:50.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support]LOG]!><time="13:37:50.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:508">
<![LOG[ Directory: LOG]!><time="13:37:50.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/logging]LOG]!><time="13:37:50.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/logging/actionqueueetw.dll]LOG]!><time="13:37:50.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:50.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/logging/auditetw.dll]LOG]!><time="13:37:50.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/logging/cmisetupetw.dll]LOG]!><time="13:37:50.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:50.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/logging/en-us]LOG]!><time="13:37:50.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/logging/en-us/actionqueueetw.dll.mui]LOG]!><time="13:37:50.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:50.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/logging/en-us/auditetw.dll.mui]LOG]!><time="13:37:50.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/logging/en-us/cmisetupetw.dll.mui]LOG]!><time="13:37:50.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:50.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/logging/en-us/oobeldretw.dll.mui]LOG]!><time="13:37:50.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/logging/en-us/setupcletw.dll.mui]LOG]!><time="13:37:50.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:50.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/logging/en-us/setupetw.dll.mui]LOG]!><time="13:37:50.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/logging/en-us/setupugcetw.dll.mui]LOG]!><time="13:37:50.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:50.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/logging/en-us/sysprepetw.dll.mui]LOG]!><time="13:37:50.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/logging/en-us/windeployetw.dll.mui]LOG]!><time="13:37:50.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:50.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/logging/en-us/winsetupetw.dll.mui]LOG]!><time="13:37:50.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/logging/etwproviderinstall.vbs]LOG]!><time="13:37:50.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:50.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/logging/microsoft-windows-actionqueue-instrumentation.man]LOG]!><time="13:37:50.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/logging/microsoft-windows-audit-instrumentation.man]LOG]!><time="13:37:50.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:50.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/logging/microsoft-windows-cmisetup-instrumentation.man]LOG]!><time="13:37:50.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/logging/microsoft-windows-oobeldr-instrumentation.man]LOG]!><time="13:37:50.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:50.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/logging/microsoft-windows-setup-events.man]LOG]!><time="13:37:50.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/logging/microsoft-windows-setup-instrumentation.man]LOG]!><time="13:37:50.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:50.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/logging/microsoft-windows-setupcl-instrumentation.man]LOG]!><time="13:37:50.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/logging/microsoft-windows-setupugc-instrumentation.man]LOG]!><time="13:37:50.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:50.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/logging/microsoft-windows-sysprep-instrumentation.man]LOG]!><time="13:37:50.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/logging/microsoft-windows-windeploy-instrumentation.man]LOG]!><time="13:37:50.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:50.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/logging/oobeldretw.dll]LOG]!><time="13:37:50.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/logging/setupcletw.dll]LOG]!><time="13:37:50.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:50.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/logging/setupetw.dll]LOG]!><time="13:37:50.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/logging/setupugcetw.dll]LOG]!><time="13:37:50.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:50.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/logging/sysprepetw.dll]LOG]!><time="13:37:50.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/logging/windeployetw.dll]LOG]!><time="13:37:50.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:50.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/logging/winsetupetw.dll]LOG]!><time="13:37:50.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz]LOG]!><time="13:37:50.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:508">
<![LOG[ Directory: LOG]!><time="13:37:50.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/cable]LOG]!><time="13:37:50.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/cable/cableinst.exe]LOG]!><time="13:37:50.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:51.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/cmi2migxml.dll]LOG]!><time="13:37:51.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/csiagent.dll]LOG]!><time="13:37:51.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:51.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/en-us]LOG]!><time="13:37:51.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/en-us/input.dll.mui]LOG]!><time="13:37:51.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:51.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/en-us/migautoplay.exe.mui]LOG]!><time="13:37:51.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/en-us/migres.dll.mui]LOG]!><time="13:37:51.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:51.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/en-us/migsetup.exe.mui]LOG]!><time="13:37:51.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/en-us/migwiz.exe.mui]LOG]!><time="13:37:51.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:51.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/en-us/postmig.exe.mui]LOG]!><time="13:37:51.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/en-us/svrmig.dll.mui]LOG]!><time="13:37:51.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:51.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/en-us/wet.dll.mui]LOG]!><time="13:37:51.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/imjpmig.dll]LOG]!><time="13:37:51.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:51.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/imkrmig.dll]LOG]!><time="13:37:51.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/imscmig.dll]LOG]!><time="13:37:51.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:51.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/imtcmig.dll]LOG]!><time="13:37:51.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/input.dll]LOG]!><time="13:37:51.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:51.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/installsvrmig.cmd]LOG]!><time="13:37:51.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/migapp.xml]LOG]!><time="13:37:51.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:51.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/migautoplay.exe]LOG]!><time="13:37:51.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/migcore.dll]LOG]!><time="13:37:51.059-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:51.059-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/migfiles.dat]LOG]!><time="13:37:51.059-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/mighost.exe]LOG]!><time="13:37:51.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:51.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/migisol.dll]LOG]!><time="13:37:51.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/migres.dll]LOG]!><time="13:37:51.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:51.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/migsetup.exe]LOG]!><time="13:37:51.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/migstore.dll]LOG]!><time="13:37:51.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:51.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/migsys.dll]LOG]!><time="13:37:51.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/migwiz.exe]LOG]!><time="13:37:51.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:51.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/msctfmig.dll]LOG]!><time="13:37:51.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/mxeagent.dll]LOG]!><time="13:37:51.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:51.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/postmig.exe]LOG]!><time="13:37:51.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/postmigres]LOG]!><time="13:37:51.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:508">
<![LOG[ Directory: LOG]!><time="13:37:51.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/postmigres/data]LOG]!><time="13:37:51.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/postmigres/data/hardwarevendors.xml]LOG]!><time="13:37:51.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ Directory: LOG]!><time="13:37:51.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/postmigres/web]LOG]!><time="13:37:51.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/postmigres/web/base_images]LOG]!><time="13:37:51.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:508">
<![LOG[ File: LOG]!><time="13:37:51.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/postmigres/web/base_images/appinstalled.gif]LOG]!><time="13:37:51.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/postmigres/web/base_images/clickdownexpanded.gif]LOG]!><time="13:37:51.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:51.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/postmigres/web/base_images/clickdownnormal.gif]LOG]!><time="13:37:51.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/postmigres/web/base_images/column.bmp]LOG]!><time="13:37:51.309-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:51.309-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/postmigres/web/base_images/documents.gif]LOG]!><time="13:37:51.309-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/postmigres/web/base_images/failure.gif]LOG]!><time="13:37:51.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:51.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/postmigres/web/base_images/programs.gif]LOG]!><time="13:37:51.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/postmigres/web/base_images/system.gif]LOG]!><time="13:37:51.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:51.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/postmigres/web/base_images/users.gif]LOG]!><time="13:37:51.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/postmigres/web/base_images/windowsmail.bmp]LOG]!><time="13:37:51.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:51.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/postmigres/web/base_images/windowsmoviemaker.bmp]LOG]!><time="13:37:51.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/postmigres/web/base_images/windowsoutlookexpress.bmp]LOG]!><time="13:37:51.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:51.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/postmigres/web/base_images/windowsphotogallery.bmp]LOG]!><time="13:37:51.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/postmigres/web/reportapi.js]LOG]!><time="13:37:51.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:51.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/segoeui.ttf]LOG]!><time="13:37:51.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/sfcn.dat]LOG]!><time="13:37:51.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:51.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/sflcid.dat]LOG]!><time="13:37:51.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/sflistlh.dat]LOG]!><time="13:37:51.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:51.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/sflistw7.dat]LOG]!><time="13:37:51.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/sflistxp.dat]LOG]!><time="13:37:51.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:51.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/sfpat.inf]LOG]!><time="13:37:51.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/sfpatlh.inf]LOG]!><time="13:37:51.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:51.559-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/sfpatpg.inf]LOG]!><time="13:37:51.559-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/sfpatw7.inf]LOG]!><time="13:37:51.559-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:51.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/sfpatxp.inf]LOG]!><time="13:37:51.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/svrmig.dll]LOG]!><time="13:37:51.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:51.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/svrmigtest.dll]LOG]!><time="13:37:51.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/tabletextservicemig.dll]LOG]!><time="13:37:51.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:51.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/unbcl.dll]LOG]!><time="13:37:51.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/wdscore.dll]LOG]!><time="13:37:51.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:51.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/migwiz/wet.dll]LOG]!><time="13:37:51.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/tools]LOG]!><time="13:37:51.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:508">
<![LOG[ File: LOG]!><time="13:37:51.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/support/tools/gbunicnv.exe]LOG]!><time="13:37:51.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/upgrade]LOG]!><time="13:37:51.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:508">
<![LOG[ Directory: LOG]!><time="13:37:51.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/upgrade/netfx]LOG]!><time="13:37:51.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/upgrade/netfx/netfx.msi]LOG]!><time="13:37:51.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File: LOG]!><time="13:37:51.809-60"http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/upgrade/netfx/netfx.msp]LOG]!><time="13:37:51.809-60/a"]http://ECH-SCCM-01.HOME.COM:80/SMS_DP_SMSPKG$/HOM0000C/sccm?/upgrade/netfx/netfx1.cab]LOG]!><time="13:37:51.809-60" date="06-16-2012" component="ApplyOperatingSystem" context="" type="1" thread="1384" file="downloadcontent.cpp:473">
<![LOG[ File:
I ran into this exact error. It was caused by a bad image copy to the server. The MD5 did not check out between the file that I downloaded from MS and the one that was on the server was different. I re-downloaded the Win7x64 w/ sp1 from the volume license site onto the server, and re-created the installer files and voila.. it worked. 3 weeks of messing around with it off and on.. and I finally found out that it was a bad image.
