RonR
Get IP Subnet info from SMS 2003 Advanced Client
I'm trying to build a script to check the assigned subnet of a PC for a software deployment. I know we can create subnet-based collections for deployments, but that's not an option in this case because of some other business rules regarding this deployment. Does anyone here know if there's a way to get the IP Subnet property from the System Management applet with VBScript, AutoIT, or something similar?
Thanks.
Guess I just needed a little more time. :) . For anyone who's curious, this bit of code will get the SMS IPSubnet property with AutoIT:
$oCPAppletMgr = ObjCreate ("CPApplet.CPAppletMgr")
$oProps = $oCPAppletMgr.getClientProperties
$objSubnet = ''
For $oProp In $oProps
If $oProp.name = "IPSubnet" Then
$objSubnet = $oProp.value
MsgBox(0,"Properties",$objSubnet)
EndIf
Next
A VBScript equivalent can be found on TechNet: http://technet.micro...y/cc180278.aspx
