DancingFerret
Patch compliance --- why a difference
Anyone know why the following patch compliance result is different??
If you create an Update list it shows compliance of all patches in that list.
If you select one patch and run a compliance report, it differs from the compliance % shown in the Update list. The difference is usually with "Unknown " . Compliance report shows more.
Does anyone know what the difference in the query is, that shows this different result??
DF
