- 0
Sccm standalone key self expiration, following the guide exactly! What am I doing wrong? custom hook tsconfig .vbs file
Asked by
mcbroome
Asked by
mcbroome
following the instructions here:
http://blogs.technet.com/b/deploymentguys/archive/2012/02/15/expiring-outdated-stand-alone-media.aspx
my tsconfig is as follows:
[CustomHook]
CommandLine="cscript.exe X:\ExpiredUFDCheck.vbs"
CommandLine="wscript.exe X:\Deploy\Scripts\ZTIMediaHook.wsf"
The ORIGINAL vbs file is as follows, which will not function for me and just throw errors and the logic seems wrong so I corrected it, ( changes annotated).
On Error Resume Next
' // Find the environment variable %configpath% for location of UFD
'Set objShell = CreateObject("WScript.Shell")
'Set objExecObject = objShell.Exec("%comspec% /c echo %configpath%")
'configPath1 = objExecObject.StdOut.ReadAll()
'configPath = Mid(configPath1, 1, Len(configPath1) -2)
' // Find the environment variable %TEMP% for location of tool files (e.g. shutdown.exe)
Set objExecObject = objShell.Exec("%comspec% /c echo %temp%")
temp = objExecObject.StdOut.ReadAll()
tempdir = Mid(temp, 1, Len(temp) -2)
' // Find driver letter for UFD
Set FSO = CreateObject("Scripting.FileSystemObject")
Set Drives = FSO.Drives
For Each DiskDrive In Drives
If DiskDrive.DriveType = "1" Then
USBPath = DiskDrive.Path
End If
Next
' // Query WMI for creation date of the Policy.xml file on the UFD
strComputer = "."
Set objWMIService = GetObject("winmgmts:" & "{impersonationLevel=impersonate}!\\" & strComputer & "\root\cimv2")
' // Media Check - Policy.xml
Set colFiles = objWMIService.ExecQuery("Select * From CIM_DataFile Where Name = '" & USBPath & "\\SMS\\Data\\Policy.xml'")
' // Set the date 3 months ago from today
dt3MonthsAgo = DateAdd("m", -3, Now)
' // If the Policy.xml file creation date is less than the date 3 months ago from today, it is an expired UFD. <---------Shouldnt this be MORE?
For Each objFile in colFiles
dtCreationDate = WMIDateStringToDate(objFile.CreationDate)
dtEndDate = DateAdd("m", 3, dtCreationDate)
If dtCreationDate > dt3MonthsAgo then <--------------- I have changed "<" to ">"
Set WshShell = CreateObject("WScript.Shell")
Command = TEMPDIR & "\scripts\Shutdown.exe /s /t 0"
MsgBox "This USB Key expired on" & dtEndDate, vbMsgBoxSetForeground, "Expired USB Media"
Set oExec = WshShell.Exec(Command)
Else
'WScript.Quit(1) <------------------I have commented this out, ts fails every time, throwing a 4005 error
End If
Next
' // Converting the WMI date query response to a simple date format. (e.g. 09/21/2010)
Function WMIDateStringToDate(dtmInstallDate)
WMIDateStringToDate = CDate(Mid(dtmInstallDate, 5, 2) & "/" & Mid(dtmInstallDate, 7, 2) & "/" & Left(dtmInstallDate, 4) & " " & Mid(dtmInstallDate, 9, 2) & ":" & Mid(dtmInstallDate, 11, 2) & ":" & Mid(dtmInstallDate, 13, 2))
End Function
I"m going crazy trying to get this thing to work! No matter what date I set in the bios, i see the script kick off, but my task sequence keeps right on going
. Won't running this with the cscript command open an ugly to the end user cmd prompt box along with the notification box? Any help is appreciated!
