I am very limited in my scripting abilities. I need a script that will change proxy settings per location. Example: Setting at this location the IP of the machine is 172.xx.xxx.xx (DHCP) and the proxy setting is 192.xxx.xxx.xxx port xxxx.
I travel to another location the IP of the machine is 164.xx.xxx.xx (DHCP) and the proxy setting is 192.xxx.xxx.xxx port xxx.
The proxy servers and the ports are different. Right now when someone travels to the offsite location we have to move them from one OU to another in order for the proxy to be set correctly. Could anyone be of help or point in the right direction. Thanks in advance.
Kathy
