I'm following the guide located here: http://www.windows-noob.com/forums/index.php?/topic/4468-using-sccm-2012-rc-in-a-lab-part-7-build-and-capture-windows-7-x64/ to create a build & capture task sequence and I've gotten all the way to the point where I PXE boot my virtual machine (using VMware Workstation 8.x) and the TS continually fails. I'm not able to glean much from the smsts.log file. It always fails at the step "applying operating system." I've attached my SMSTS.log file and a screen shot of the virtual machine as it sits at the failure notification.
Any insight the community could provide, I would be grateful for!
Thanks in advance!
-Ben
SMSTS.logFetching info...
