Adminoob Posted July 23, 2012 Report post Posted July 23, 2012 Hello, I have a build and capture TS that works great for creating my thin-image, however, I would like to somehow interrupt the build and capture at some point and force it to boot into audit mode so I can install some apps that cannot be repackaged or otherwise scripted. Can this be done? Thanks! Quote Share this post Link to post Share on other sites More sharing options...
Jorgen Nilsson Posted July 23, 2012 Report post Posted July 23, 2012 Hi, The easiest way would be to remove the capture step from the TS and capture the image using the Capture Media instead, then you can install the software and make the changes you need.. Regards, Jörgen Quote Share this post Link to post Share on other sites More sharing options...
Adminoob Posted November 30, 2012 Report post Posted November 30, 2012 Hi, The easiest way would be to remove the capture step from the TS and capture the image using the Capture Media instead, then you can install the software and make the changes you need.. Regards, Jörgen Thanks Jorgen (a bit late, sorry!) I did manage to simply add an unattend.xml to the B&C TS, and this worked fine, but I found out the hard way that you MUST remove that file prior to running the capture process, otherwise it just continues to boot into audit mode (the sysprep process should remove that file, but it doesn't , not sure why that is.) T Quote Share this post Link to post Share on other sites More sharing options...
