Fiorst of all I must congratulate you anyweb for your site, and specially for all the guides you've posted on it.
I've followed every step of your "how to setup sccm 2007 sp1 in window server 2008". I' doing this on virtual machines, so I can backup the good configuration and delete the bad one. Also this is my thesis to graduate from my univeristy, which have restricted me the use of its servers. That's why I've decided to do it virtually.
Anyway and getting into the topic, would you can explain me how to setup the support to unknown coputers in SCCM 2007 R2!?
Maybe you will say to check the box when you're setting the PXE service to suppoirt unknown machines, but that's just useless.
Evry time I try to boot an unknown machine is says something like this:
"sms_ucb\abortpxe.com
PXE aborted"
So would you can explain me how to make it work...and then how to Build and Capture a WinXP SP3 from that bare-metal and unknown computer!?
PXE aborted"
See ya!
David Ulises
