fastford
Clients not downloading Package
I have created a package in SCCM 2007 to deploy a software update. I have the package complete, updated distribution point, advertisement is working as it should to the clients. When the clients choose to install the program they error out and it says download is not available. I searched some logs and found an error code (error 0x800700ce)..Only thing i could find online was it had to do with the specified path is to long. And a fix offered...runing it from the server vs download and run locally did nothing. Please help. I need to get this software update deployed.
Erik
4 answers to this question
Double-check your data source path. It could be too many characters especially if you have lots of subdirectories and the name of the file to be installed is long. I don't recall the exact length, but I've seen that error with an application package in my environment. We had to move the package to a different folder structure to shorten it.
Hello Erik,
We'll need a lot more information than just that to help you out. That being said, the error number that you posted (0x800700CE) translates into this message: "The filename or extension is too long."
Given this, you might want to try checking the logs on the client to see the length of the URL it's trying to access. Also, examine the IIS logs on the BITS-enabled distribution point.
Cheers,
Trevor Sullivan
http://trevorsullivan.net
http://twitter.com/pcgeek86
This was from the CAS.log
Download location found 0 - \\SCCSCCM01.XXXXXXXXXXXXXX.COM\SMSPKGC$\LPC000D3
Download failed for content LPC000D3.1 under context S-1-5-21-4234435504-1500553131-2518409970-4689, error 0x800700ce
Download failed for download request {054A3652-5948-47E2-A77E-C93762DFB5EC}
Raising event:
[sMS_CodePage(437), SMS_LocaleID(1033)]
instance of SoftDistDownloadFailedEvent
ClientID = "GUID:1E533D6B-0CE7-4B4E-81BA-A17336173D15";
DateTime = "20120806130451.531000+000";
MachineName = "SCCXXXXX01";
PackageId = "LPC000D3";
PackageName = "LPC000D3";
PackageVersion = "1";
ProcessID = 1776;
SiteCode = "LPC";
ThreadID = 2884;
From the execmgr.log
OnContentAvailable program NX 8.0.2 32bit Update NOT available, 0x800700ce
Raising event:
instance of SoftDistAdvertDownloadFailedMomEvent
AdvertisementId = "LPC20073";
DateTime = "20120806130700.656000+000";
ProcessID = 1776;
ProgramName = "NX 8.0.2 32bit Update";
SiteCode = "LPC";
ThreadID = 2884;
Win32ErrorCode = 2147942606;
From the DataTransferService.log
DTSJob {FD4F3F4E-0148-4C39-9BF5-E3847A3FB3AA} created to download from 'file:\\SCCSCCM01.xxxxxxxxxxxxxx.com\SMSPKGC$\LPC000D3' to 'C:\WINDOWS\system32\CCM\Cache\LPC000D3.1.S-1-5-21-4234435504-1500553131-2518409970-4689'.
DTSJob {FD4F3F4E-0148-4C39-9BF5-E3847A3FB3AA} in state 'DownloadingManifest'.
Job {FD4F3F4E-0148-4C39-9BF5-E3847A3FB3AA} impersonating logged on user.
Job {FD4F3F4E-0148-4C39-9BF5-E3847A3FB3AA} reverted impersonation.
DTSJob {FD4F3F4E-0148-4C39-9BF5-E3847A3FB3AA} in state 'RetrievedManifest'.
DTSJob {FD4F3F4E-0148-4C39-9BF5-E3847A3FB3AA} in state 'PendingDownload'.
DTSJob {FD4F3F4E-0148-4C39-9BF5-E3847A3FB3AA} in state 'DownloadingData'.
DTSJob {FD4F3F4E-0148-4C39-9BF5-E3847A3FB3AA} in state 'Cancelled'.
DTSJob {FD4F3F4E-0148-4C39-9BF5-E3847A3FB3AA} cancelled by client.
