how can I create the System Management Container in Active Directory
Using Adsiedit Create a container in AD, CN=System called System Management by right clicking on CN=System and choose New Object, scroll down to container from the list, click next, give it a value of System Management.
In Active Directory Users and Computers expand the System container, and right click click on System Management
choose delegate control, click next, click add, click object types, add computers, click ok, advanced, find now.
highlight the SCCM servername and click ok.
click OK again, click Next in the Delagation of control Wizard page, choose 'create a custom task to delegate'
click next, make sure 'this folder, existing objects in this folder and creation of new objects in this folder is selected
click next, select the 3 permissions General, Property-Specific and Creation-deletion of specific child objects are selected then place a check mark in FULL CONTROL
and click next then Finish.
Failure to do the above will mean that the System Management Container in AD will NOT POPULATE with SCCM specific info and you will see many errors in SCCM site status
Once the permissions are granted correctly, it will look like this
done !
I have had this same issue and this has been my resolve for it.
In Active Directory after the "System Management" container is created right click on the container, go to properties, then click on the security tab. Make sure the server you are using has full control. After that click on advanced, find the server and click Edit. On the object tab make sure "Apply onto" is set to "This object and all child objects". I have found the default during the install to be "This object only". After this you will need to go into SCCM and right click on your site and select properties. On the properties page go to the Advanced tab. On the Advanced tab un-check all of the check boxes and click "Apply" the recheck the boxes and click "Apply" again. After a few minuets the correct information should be propigated to the "System management" container.
This has been done in a test environment and I hope this will help others that might be having the same issue.
I also found some of these videos to be helpful http://www.youtube.com/user/dodo3tt#p/search/1/coSRKb7hRkU
and followed Microsofts site http://technet.microsoft.com/en-us/library/bb632492.aspx
Bobtrie.
  On 7/14/2009 at 9:50 AM, anyweb said:
the container will populate itself if you followed the guide correctly, give it some time to do so.
the container is needed to store info in AD about where sccm site servers are located
here's some more info
Four actions need to be taken in order to successfully enable Configuration Manager Clients to query Active Directory Domain Services to locate site resources:
* Extend the Active Directory schema.
* Create the System Management container.
* Set security permissions on the System Management container.
* Enable Active Directory publishing for the Configuration Manager site.
one stupit question:
duering prerequisites check of installtion of sccm 2007 r2, i had to extend the AD schema otherwise it gave me error. Now i followed your guide to create system Management container but nothing appears, its empty (i followed it twice!), so the question is; should i extend the AD schema ONCE AGAIN?
Thanks!
Thanks in advance ,I have extended the schema for SCCM but while i trying to create System Management Container in Active Directory by using ADSIEDIT i am not found anything called
System Management under the CN=system
pleased to refer the img link
http://www.flickr.com/photos/srikanthsri/5729462738/in/photostream
did you try this ?
I have a parent/child domain setup. Everything is in the child domain except for a couple root domain controllers. Do I need to create the System Management contain in cn=system on the parent domain or the child domain?
