Prajwal Desai Posted August 14, 2012 Report post Posted August 14, 2012 Yes, the Virtual Machine Servicing Tool 2012 is now available for download. Virtual Machine Servicing Tool 2012 is designed to work with System Center 2012 -Virtual Machine Manager (VMM), System Center 2012 Configuration Manager and Windows Server Update Services (WSUS) 3.0 SP2. VMST 2012 helps you reduce IT costs by making it easier to update your offline virtual machines, templates, and virtual hard disks with the latest operating system and application patches without introducing vulnerabilities into your IT infrastructure. Offline machines, templates, and virtual hard disks do not automatically receive operating system, antivirus, or application updates that would keep them compliant with current IT policy. An out-of-date virtual machine may pose a risk to the IT environment. To ensure that offline virtual machines, templates, and virtual hard disks remain up-to-date and compliant one can make use of Virtual Machine Servicing Tool 2012. Using VMST 2012, you can now service: 1) Offline virtual machines in a SCVMM library. 2) Stopped and saved state virtual machines on a host. 3) Virtual machine templates. 4) Offline virtual hard disks in a SCVMM library by injecting update packages. VSMT2012 can be downloaded at : http://www.microsoft....aspx?id=30470 The Virtual Machine Servicing Tool 2012 includes the following components: Virtual Machine Servicing Tool (msi) Virtual Machine Servicing Tool: Getting Started Guide Virtual Machine Servicing Tool: Release Notes System requirements : Supported operating systems: Windows 7, Windows Server 2008 R2 Microsoft System Center 2012 - Virtual Machine Manager Microsoft Word or Microsoft Word Viewer 2003 (available as a free download) can be used to view Word documents Microsoft Office Compatibility Pack for Word, Excel, and PowerPoint File Formats (available as a free download) can be used to open, edit, and save documents, workbooks, and presentations in the file formats new to Microsoft Office. VSMT 2012 Workflow -via Technet > http://technet.micro...y/jj149757.aspx Share this post Link to post Share on other sites More sharing options...
