rob343
Is it possible
Hi
new here long time reader first time poster, still very new to SCCM 2007
What i want to know is it possible to create a OSD seq and NOT include. the sccm agent/hotfix.
The reason is i want to create a ref build to be used in our Citrix VDI environment and i don't want these takking back to the config server.
Rob
No it is not possible, I normally uninstall the client as the last step if the finished computer shouldn't have the agent.
You could also build the image in MDT and then use it in both VDI and SCCM that is probably how I would do it.
regards,
Jörgen
