doctora
deploy and capture vs capture and deploy.
I am new to this and I am a bit confused. If I have a blank machine and I do a delpoy and capture and use it as my base image it works perfectly. I have a nice shiny new windows 7 pc.
Now if I want to add office, .Net framework, virtual client and a couple other features that I know all my machines will need and then create a new WIM file from that and deply it works fine except that it installs on D.
I have read through the blogs and I have seen advice to use deploy and capture but how would I get some of the other stuff in the image. There might be a guide or post out there that I missed but I have spent the last two weeks looking through the guides and posts and I can't seem to find anything that works.
If the only option is to add the other stuff as packages and include them during the install then I will do that but I was under the impression that it could be done as a single image.
Thanks in advance
Mark
From my initial deploy and capture build I installed a base Windows 7 system. I then added my components and used a Capture Media Disk to capture the machine.
Task Sequence
1) Install an existing image package
2) Task sequence name - "Test build" : Description - "Test Build Description" : Boot image - 64bit
3) Image package - The one I built : Image "All Images" : No product key : Disable local administrator
4) Join a workgroup "WORKGROUP" : No other oprions selected.
5) Select the Client.
6) Deselect all State Migration.
7) Do not install updates.(I did this on the original Base image)
8) No added Applications.
I did not mess with rightclick -> edit Task sequence.
Thanks for helping with this.
Mark
