bigbirddk Posted August 20, 2012 Report post Posted August 20, 2012 Hey Office 2010 pro plus, visio and project is giving me one h... of a fight here... I can easily deploy all other software, but these 3 is a bit tricky. I need to deploy them on Windows 7 x64, and all the office products are x86. The way Im installing Office 2010 ProPlus, is that I have created the MSP files, and placed it in the updates directory, and then created an "application" in SCCM that just start setup.exe, and everything works great here. BUT... I need to deploy Office 2010 ProPlus, visio and project from a task sequence with Windows 7 deployment. It installs Office 2010 ProPlus, but then hauls at the next application (Visio or Project). If I try to deploy Office 2010 proplus to an already installed client, it installs as expected. But I can ONLY deploy ONE more Office product, either Visio or Project. Not both..... What am I missing ? Is it that Visio and Project "forgets" to tell SCCM that the installation has been completed ? I have also create MSP files for each and placed in the "updates" directories. Quote Share this post Link to post Share on other sites More sharing options...
Peter van der Woude Posted August 20, 2012 Report post Posted August 20, 2012 Isn't Visio and/ or Project a separate installation??? If you have an installation of Office 2010 and you want to add, for example, Access then you need to use a Config.xml to add that component. You can only use a msp once. Quote Share this post Link to post Share on other sites More sharing options...
tmiller_hockey Posted August 20, 2012 Report post Posted August 20, 2012 Yes they are separate installs, Professional Plus doesn't include them. Quote Share this post Link to post Share on other sites More sharing options...
bigbirddk Posted August 20, 2012 Report post Posted August 20, 2012 Correct, those are seperate installations / software products. And I have an "application" for each of them. For each one I have created the msp file, using the setup.exe /admin. But somethings is preventing me from installing ? I can install them seperatly, but not no more that office and of the product per client ... ?? Quote Share this post Link to post Share on other sites More sharing options...
