Harish.H.Y
Application Installation through SCCM Using AD Group
We are trying to install some 100 applications right after Windows 7 migration & we are planning to have Security Groups for each application & the Computer account moved into the required groups, so that the required applications are installed only for that particular computer.
Is there an option to install the applications right after the Window 7 is installed so that when the users login they should have the applications. The collection, set with Query AD takes time to discover the systems from the AD Group so the application installation takes time normally 24Hrs & there are 5000+ system accounts in the AD.
Is there a way to do this ?
2 answers to this question
