mjruotolo
SCCM client register problem
Her is my situation. I work for a university. We want to put the sccm client with the scep client on all machines joined or un joined.
There is a imaging process that happens with these machines. We are using mdt for imaging.
1. I have tested this command line ccmsetup.exe SMSSLP=server.edu SMSSITECODE=XXX FSP=server.edu
The install of the client will work but will only register if the client is connect to our network during the install.
Our problem is that our network for imaging is not connect to our network it is a standalone network. So the computer will not register.
If I then take i from the mdt network and hook it to our network I have to manually type in the site code to get it to register
I need it to register automatically when moved to the network.
Thoughts??
