Hi, I have been trying to create a package for vs2008 pro on sccm, but after creating a package i have tested on few pc's and its gets failed, i have created unattend install.ini and tranform.mst file for silent installation still i am facing the same problem. the wonder is that when i checked in event viwer it show vs2008 pro has been installed successfully and doesnt happend anything i dont see application in all program list. can you please help me with it. i am really frustated with this..trying to finish this package..but its driving me nuts and i am not able to reach to root cause.. Thanks a lot in advance..
Hi, I have been trying to create a package for vs2008 pro on sccm, but after creating a package i have tested on few pc's and its gets failed, i have created unattend install.ini and tranform.mst file for silent installation still i am facing the same problem. the wonder is that when i checked in event viwer it show vs2008 pro has been installed successfully and doesnt happend anything i dont see application in all program list. can you please help me with it. i am really frustated with this..trying to finish this package..but its driving me nuts and i am not able to reach to root cause.. Thanks a lot in advance..![:)](https://www.windows-noob.com/forums/uploads/emoticons/default_smile.png)
