at first it looks like the network is ok
<![LOG[Found network adapter "Intel® PRO/1000 MT Network Connection" with IP Address 192.168.1.146.]LOG]!><time="19:39:10.825+480" date="11
but then theres loads of dns failures like this
  Quote
<![LOG[unknown host (gethostbyname failed)]LOG]!><time="19:39:11.870+480" date="11-11-2013" component="TSPxe" context="" type="3" thread="808" file="libsmsmessaging.cpp:692">
<![LOG[hr, HRESULT=80072ee7 (e:\nts_sccm_release\sms\framework\osdmessaging\libsmsmessaging.cpp,8738)]LOG]!><time="19:39:11.870+480" date="11-11-2013" component="TSPxe" context="" type="0" thread="808" file="libsmsmessaging.cpp:8738">
<![LOG[sending with winhttp failed; 80072ee7]LOG]!><time="19:39:11.870+480" date="11-11-2013" component="TSPxe" context="" type="3" thread="808" file="libsmsmessaging.cpp:8738">
<![LOG[m_pHttpTransport->Send (0, 0, pServerReply, nReplySize), HRESULT=80072ee7 (e:\nts_sccm_release\sms\framework\osdmessaging\libsmsmessaging.cpp,5151)]LOG]!><time="19:39:11.870+480" date="11-11-2013" component="TSPxe" context="" type="0" thread="808" file="libsmsmessaging.cpp:5151">
<![LOG[MPKeyInformation.RequestMPKeyInformation(szTrustedRootKey), HRESULT=80072ee7 (e:\nts_sccm_release\sms\framework\osdmessaging\libsmsmessaging.cpp,9229)]LOG]!><time="19:39:11.870+480" date="11-11-2013" component="TSPxe" context="" type="0" thread="808" file="libsmsmessaging.cpp:9229">
<![LOG[Failed to get information for MP: http://P01.SERVER2008R2.local. 80072ee7.]LOG]!><time="19:39:11.870+480" date="11-11-2013" component="TSPxe" context="" type="3" thread="808" file="tsmbootstraputil.cpp:1429">
<![LOG[sMP.length() > 0, HRESULT=80004005 (e:\nts_sccm_release\sms\client\tasksequence\tsmbootstrap\tsmbootstraputil.cpp,1437)]LOG]!><time="19:39:11.870+480" date="11-11-2013" component="TSPxe" context="" type="0" thread="808" file="tsmbootstraputil.cpp:1437">
<![LOG[TSMBootstrapUtil::SelectMP ( sSMSTSMP.c_str(), sMediaPfx.c_str(), sMediaGuid.c_str(), sAuthenticator.c_str(), sEnterpriseCert.c_str(), sServerCerts.c_str(), nHttpPort, nHttpsPort, bUseCRL, sSiteCode, sAssignedSiteCode, sMP, sCertificates, sX86UnknownMachineGUID, sX64UnknownMachineGUID), HRESULT=80004005 (e:\nts_sccm_release\sms\client\tasksequence\tsmbootstrap\tsmediawizardcontrol.cpp,871)]LOG]!><time="19:39:11.870+480" date="11-11-2013" component="TSPxe" context="" type="0" thread="808" file="tsmediawizardcontrol.cpp:871">
<![LOG[Exiting TSMediaWizardControl::GetPolicy.]LOG]!><time="19:39:11.870+480" date="11-11-2013" component="TSPxe" context="" type="0" thr
so either you have DNS issues or its dropping the ip address, can you ping the FQDN of your mp after it fails ?
Behold :| the Holy Grail ! I found out I hadn't set a DNS server address in my router for DHCP, changed this and everything goes as suspected, win7 got installed and I found a nice WIM file in de share where it was expected, Thank you for your analyses and for pointing me in the right direction
I'm going to take a chane by posting it, although it isn't relevant - it sort of is...
I've followed this post (excellent!) and configured my build and cap which is working fine if I don't deploy applications.
I know you state you don't do this until later in the series but I'd like to deploy Office 2013 and capture it in my reference build to try and keep the overall subsequent client build time down.
If I disable the app or "continue on error" it works but I'm getting the following error every time (see attached image). I've specified my SMSMP in the conifg manager installation properties as I'm aware this machine is currently in a workgroup - makes sense - but unfortunatly this didn't work.
I know I can install Office as a package instead but I'm a stickler for making things work as they should, so my SCCM OCD wants this to work properly.
Any ideas anyone?
Rgds
Chris.
Hello Niall,
Thank you for this nice blog about SCCM 2012 whereas at the moment i have used your guide to deploy a SCCM 2012 R2 CAS and 2 Primary site servers. After the PXE blog you highlighted that an upcoming blog was about how to capture a customized image whereas i could not find it as the blog stopped after the monthly update cycle.
have you posted this blog somewhere else and could you post a link to it as after a successful install of Windows 2012 R2 i would like to customize it based on the standard building block design i created for another tutorial and use this to deploy new instances required. In the process had a nice crash of my VMware environment (5.5) as it seems that there is a know bug in VMware when imaging with Windows 2012 R2 PXE; in this case governed by SCCM.
Regards,
Martin
  On 12/18/2013 at 5:34 PM, anyweb said:
can you attach the smsts.log
Hi Niall,
Of course - log now attached...
Thanks in advance... I've just broken the wall I was banging my head against...
Incidentally I've been trying to take a step back from the fact that the App won't install during OSD - more to the point it won't install when the client is in a workgroup. I've tried deploying the App to a domain joined client and it works fine. I can't help thinking it's permissions/communication with the MP.
I've added a step to my B&C TS specifying a TS Variable of SMSMP and the value of <our MP FQDN> - I was quite hopeful that this would sort it but when I got to my desk this AM I saw that the VM had failed (my reference machine is on HyperV)...
Just going to try and fix the wall...
smsts.logFetching info...
smsts-20131218-161321.logFetching info...
here's your problem
<![LOG[Failed to run the action: Install Microsoft Office 2013 ProPlus.
Download failed (
Error: 87D00267; Source: CCM)]LOG]!><time="16:13:50.800+00" date="12-18-2013" component="TSManager" context="" type="3" thread="3036" file="instruction.cxx:895">
is it on the dp ? are you specifying any MP in the setup windows and configmgr step ?
  On 12/19/2013 at 6:51 PM, anyweb said:
here's your problem
Download failed (Error: 87D00267; Source: CCM)]LOG]!><time="16:13:50.800+00" date="12-18-2013" component="TSManager" context="" type="3" thread="3036" file="instruction.cxx:895">
Hi Niall,
Yes and Yes - It's on our DP and I've checked and validated and removed and re-distributed.... And I'm specifying the MP in the TS as I mentioned above SMSMP=<FQDNofDP>
Hi, I have a problem with step 5. when trying to add operating system installer package.
When I try to select path to operating system files I get error: "the specified path does not contain a valid operating system or you don't have permission to access it. Specify a valid path."
I have windows 7 64bit sp1 source files extracted locally from ISO and have full permission to the folder.
Has anyone seen this before, help is greatly appreciated
thanks
ht
