Hi anyweb,
Yes I am booting my noteboot in the same network area and it the network as my Configuration Manager PXE enabled distribution point.
My step for that are:
1) in the bios I put the boot option on "Network LAN"
2) booting the notebook , I see this dos message
With MAC ADDR 8C:73:6E:08:76:57 GUID ####################. But I see while the booting notebook a other GUID number as in sccm2012. I am goging to "Asset and Compliance"-->Devices-->choose my notebook---properties--General, here I see a different GUID number. Is it the the problem?
  Quote
Posted Yesterday, 04:42 PM
after much head scratching it dawned on me that having SP1 in my test lab might be confusing the issue. Sure enough, the OSD has changed slightly 'by design'
https://connect.micr...e-task-sequence
Looking forward to some SP1 guides :D
there are SP1 guides already if you look here (look at the Windows 8 posts, UEFI, pre-provision BitLocker and more), but for this series of guides I will stick with the RTM release until SP1 is released to manufacturing.
Hi anyweb again me,
I have changed my Notebook and set up with desktop machine. Now I dont get any error message, but it tries to get a IP-Address from DHCP but I see only ....................................
I happend nothing. If I got smspxe.log file , I see there two points:
1) Set media certificate in transport
2) Set authenticator in trasnport
I see to reply both points
Any Idea?
did you enable PXE ability on both boot images, did you enable it on the DP, did you enable it on the task sequence deployment ?
what does the SMSPXE.log file tell you
Hi Anyweb,
I did enalbe follow:
1) "Deploy this boot image from the PXE service point" on both boot images
2) "Make available to boot media and PXE,
I dont know what do you mean with that "did you enable it on the DP" Where can I do that?
Here the log file
Client boot action reply: <ClientIDReply><Identification Unknown="0" ItemKey="16777225" ServerName="" ServerRemoteName=""><Machine><ClientID/><NetbiosName/></Machine></Identification><PXEBootAction LastPXEAdvertisementID="" LastPXEAdvertisementTime="" OfferID="" OfferIDTime="" PkgID="" PackageVersion="" PackagePath="" BootImageID="" Mandatory=""/></ClientIDReply>
SMSPXE 09.10.2012 14:54:46 2988 (0x0BAC)
Client Identity: cd1ded9f-ff30-4350-a59d-d6381c8b00b4 SMSPXE 09.10.2012 14:54:46 2988 (0x0BAC)
Set media certificate in transport SMSPXE 09.10.2012 14:54:46 2988 (0x0BAC)
Set authenticator in transport SMSPXE 09.10.2012 14:54:46 2988 (0x0BAC)
PXE::CBootImageManager::FindMatchingArchitectureBootImage SMSPXE 09.10.2012 14:54:48 2988 (0x0BAC)
Getting boot action for unknown machine: item key: 2046820352 SMSPXE 09.10.2012 16:54:02 2980 (0x0BA4)
Set media certificate in transport SMSPXE 09.10.2012 14:54:48 2988 (0x0BAC)
Set authenticator in transport SMSPXE 09.10.2012 14:54:48 2988 (0x0BAC)
Client Identity: cd1ded9f-ff30-4350-a59d-d6381c8b00b4 SMSPXE 09.10.2012 14:54:48 2988 (0x0BAC)
Set media certificate in transport SMSPXE 09.10.2012 14:54:49 2988 (0x0BAC)
Set authenticator in transport SMSPXE 09.10.2012 14:54:49 2988 (0x0BAC)
and so go on
Tell me please that in Part
using SCCM 2012 RC in a LAB - Part 7. Build and Capture Windows 7 X64
You wrote that
This post has been superseded by the following post for Configuration Manager 2012 RTM.
That means you dont should to use this part? If I am going to "followin post" ,
they link me to http://community.inv...-in-wordpress/.
How can I access to the new post?
Now I can boot my machine with PXE, but It reboot by the point
Preparing Network connections.......
1) Windows is loading files (IP :my sccm2012 server: File: \SMSboot\boot.sdi)
(IP :my sccm2012 server: File: \SMSImages\dig\boot.dig2002.wim
2) Windows is starting up.........
3)Preparing Network connections.......
Here reboot my machine again
I did hit F8 and check smsts.log and ipconfig.By typing ipconfig, it display "Windows IP Configuration"
In the smsts.log I see follow Error message:
Failed to download pxe variable file. Code(0x00000001)
PxeGetPxeData failed with 0x80004005
Is it a driver problem or what?
How can I add a new WINPE driver for NIC?
