gvlaarho Posted September 11, 2012 Report post Posted September 11, 2012 Hi all, Is somebody has already use SCCM 2012 with SQL 2008 R2 SP2 ? CU1 ? Thanks Quote Share this post Link to post Share on other sites More sharing options...
anyweb Posted September 11, 2012 Report post Posted September 11, 2012 why do you ask ? Quote Share this post Link to post Share on other sites More sharing options...
gvlaarho Posted September 11, 2012 Report post Posted September 11, 2012 I have read that normally SQL 2008 R2 Sp2 is compatible with SCCM 2012. But some site relate about problems and CU1 for SP2 should be installed. Many people have problems installing this CU1. So, what is best (I am implementing sccm 2012) SP1 CU7 or SP2 CU1. Thanks Quote Share this post Link to post Share on other sites More sharing options...
blogi Posted September 12, 2012 Report post Posted September 12, 2012 On 9/11/2012 at 12:51 PM, gvlaarho said: I have read that normally SQL 2008 R2 Sp2 is compatible with SCCM 2012. But some site relate about problems and CU1 for SP2 should be installed. Many people have problems installing this CU1. So, what is best (I am implementing sccm 2012) SP1 CU7 or SP2 CU1. Thanks I installed sql 2008 r2 sp2 with my sccm primary site deployment locally on the box. No issues and everything reporting green. http://technet.microsoft.com/en-us/library/gg682077.aspx#BKMK_SupConfigSQLDBconfig it is a supported sql server version with no cup required. Quote Share this post Link to post Share on other sites More sharing options...
SiegmundB Posted September 13, 2012 Report post Posted September 13, 2012 yes, I can confirm that it works (it saved me a few minutes not having to apply a Cumulative update to the SP1 instead) Quote Share this post Link to post Share on other sites More sharing options...
gvlaarho Posted October 1, 2012 Report post Posted October 1, 2012 Yes, also i can cofirm that works perfectly but with CU1 Thanks you all Quote Share this post Link to post Share on other sites More sharing options...
