Zden Posted September 17, 2012 Report post Posted September 17, 2012 Hi I am trying to create installation media from my Configmgr 2012 infra to deploy computers to one of our antennas that will not have access to our internal network. The ISO creation runs fine, but when I try to boot from them, it loop reboots. With the command prompt of WinPE, I was able to extract the smsts.log (attached) Can you help me find what's wrong ? Thanks smsts.log Quote Share this post Link to post Share on other sites More sharing options...
anyweb Posted September 17, 2012 Report post Posted September 17, 2012 how much ram is in that computer ? Quote Share this post Link to post Share on other sites More sharing options...
Zden Posted September 17, 2012 Report post Posted September 17, 2012 One has 3GB, and the other 4GB. Quote Share this post Link to post Share on other sites More sharing options...
anyweb Posted September 17, 2012 Report post Posted September 17, 2012 and what is a standard task sequence or MDT integrated ? more info please about how you created it etc.... Quote Share this post Link to post Share on other sites More sharing options...
Zden Posted September 17, 2012 Report post Posted September 17, 2012 It is just a simple task sequence I created from scratch. No MDT integration. I don't really understand what's wrong, because it works perfectly from PXE. But from DVD or USB stick, it's a no-go The steps after "Setting up SCCM2012 Client" are all "Install application" steps, which install several apps each. Thanks Quote Share this post Link to post Share on other sites More sharing options...
