Anakin
MpSetup; help please
I am installing a secondary site from the console and is achieved except install management point, I get critical error and validate and entire IIS, BITS enabled, remote differential Comprehension, the firewall is disabled, and I istalado other and this has not it wont let me, the installation user accounts as local administrators are on computers, the sql is installed on the server either, but the install fails mp. I have already several days searching and find nothing, all features are enabled als, here I leave the log of mp. secondary server.
MPSETUP.LOG
<09-27-2012 12:35:34> Found 2 Pre Reqs for Role SMSMP
<09-27-2012 12:35:34> Pre Req MSXML60 found.
<09-27-2012 12:35:34> No versions of MSXML60 are installed. Would install new MSXML60.
<09-27-2012 12:35:34> Enabling MSI logging. msxml6_x64.msi will log to C:\Program Files\Microsoft Configuration Manager\\logs\msxml6_x64MSI.log
<09-27-2012 12:35:34> Installing C:\Program Files\Microsoft Configuration Manager\\bin\x64\00000409\msxml6_x64.msi
<09-27-2012 12:35:35> msxml6_x64.msi exited with return code: 0
<09-27-2012 12:35:35> msxml6_x64.msi Installation was successful.
<09-27-2012 12:35:35> Pre Req SqlNativeClient found.
<09-27-2012 12:35:35> SqlNativeClient already installed (Product Code: {471AAD2C-9078-4DAC-BD43-FA10FB7C3FCE}). Would not install again.
<09-27-2012 12:35:35> Pre Req SqlNativeClient is already installed. Skipping it.
<09-27-2012 12:35:35> ======== Completed Installation of Pre Reqs for Role SMSMP ========
<09-27-2012 12:35:35> Installing the SMSMP
<09-27-2012 12:35:35> Passed OS version check.
<09-27-2012 12:35:35> IIS Service is installed.
<09-27-2012 12:35:35> No versions of SMSMP are installed. Installing new SMSMP.
<09-27-2012 12:35:35> Enabling MSI logging. mp.msi will log to C:\Program Files\Microsoft Configuration Manager\logs\mpMSI.log
<09-27-2012 12:35:35> Installing C:\Program Files\Microsoft Configuration Manager\bin\x64\mp.msi CCMINSTALLDIR="C:\Program Files\SMS_CCM" CCMSERVERDATAROOT="C:\Program Files\Microsoft Configuration Manager" USESMSPORTS=TRUE SMSPORTS=80 USESMSSSLPORTS=TRUE SMSSSLPORTS=443 USESMSSSL=TRUE SMSSSLSTATE=0 CCMENABLELOGGING=TRUE CCMLOGLEVEL=1 CCMLOGMAXSIZE=1000000 CCMLOGMAXHISTORY=1
<09-27-2012 12:35:41> mp.msi exited with return code: 1603
<09-27-2012 12:35:41> Backing up C:\Program Files\Microsoft Configuration Manager\logs\mpMSI.log to C:\Program Files\Microsoft Configuration Manager\logs\mpMSI.log.LastError
<09-27-2012 12:35:41> Fatal MSI Error - mp.msi could not be installed.
<09-27-2012 12:35:41> ~RoleSetup().
MPMSI.LOG
Property(S): UILevel = 2
Property(S): ACTION = INSTALL
Property(S): SMSCWSADSPATH = IIS://LocalHost/W3SVC/1
Property(S): CCMSHAREMODE = 1
Property(S): IISAnonymousUserAccount = IUSR
Property(S): ROOTDRIVE = C:\
Property(S): CostingComplete = 1
Property(S): OutOfDiskSpace = 0
Property(S): OutOfNoRbDiskSpace = 0
Property(S): PrimaryVolumeSpaceAvailable = 99265888
Property(S): PrimaryVolumeSpaceRequired = 45180
Property(S): PrimaryVolumeSpaceRemaining = 99220708
Property(S): INSTALLLEVEL = 1
Property(S): CcmAdministratorsGroupName = Administradores
Property(S): CcmUsersGroupName = Usuarios
Property(S): CcmCreatorOwnerAccountName = CREATOR OWNER
Property(S): PrimaryVolumePath = C:
Property(S): SOURCEDIR = C:\Program Files\Microsoft Configuration Manager\bin\x64\
Property(S): SourcedirProduct = {26ED0430-F99D-4A6B-89B6-90BC56EC40EE}
Property(S): CCMHTTPSPORT = 443
Property(S): ProductToBeRegistered = 1
Property(S): CCMHTTPPORT = 80
Property(S): CCMHTTPSSTATE = 0
MSI (s) (F4:B0) [12:35:41:170]: Note: 1: 1708
MSI (s) (F4:B0) [12:35:41:170]: Product: ConfigMgr Management Point -- Installation operation failed.
MSI (s) (F4:B0) [12:35:41:170]: Windows Installer instaló el producto. Nombre del producto: ConfigMgr Management Point. Versión del producto: 5.00.7711.0000. Idioma del producto: 1033. Fabricante: Microsoft Corporation. Resultado de la instalación: 1603.
MSI (s) (F4:B0) [12:35:41:217]: Deferring clean up of packages/files, if any exist
MSI (s) (F4:B0) [12:35:41:217]: MainEngineThread is returning 1603
MSI (s) (F4:98) [12:35:41:217]: RESTART MANAGER: Session closed.
MSI (s) (F4:98) [12:35:41:217]: No System Restore sequence number for this installation.
=== Logging stopped: 27/09/2012 12:35:41 ===
MSI (s) (F4:98) [12:35:41:217]: User policy value 'DisableRollback' is 0
MSI (s) (F4:98) [12:35:41:217]: Machine policy value 'DisableRollback' is 0
MSI (s) (F4:98) [12:35:41:217]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (F4:98) [12:35:41:217]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (F4:98) [12:35:41:232]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (s) (F4:98) [12:35:41:232]: Restoring environment variables
MSI (s) (F4:98) [12:35:41:232]: Destroying RemoteAPI object.
MSI (s) (F4:AC) [12:35:41:232]: Custom Action Manager thread ending.
MSI © (78:E0) [12:35:41:248]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI © (78:E0) [12:35:41:248]: MainEngineThread is returning 1603
=== Verbose logging stopped: 27/09/2012 12:35:41 ===
0 answers to this question
