gvlaarho
SCCM 2012 PXE Problem: Pending request ... Unknow Computers after deletion of object in SCCM
Already done and all is present; but i don't understand the goal of this manipulation as all works perfectly for all computers, except in case of problem described in this topic. No way to restage those type of computer ... strange behaviour
In your task sequence how are you naming your OSD computers??
Just out of curiosity..have you searched the all systems by typing in unknown?? Do this and there should be only the 2 built in unknown objects(x86 and x64)...if there are more then delete them...
There should be no reason why you cannot deploy over and over again to unknown once the system account has been deleted out of the SCCM DB..
I rename the computer with the variable OSDComputername trought a vbscript.
Unfortunately, there is no "unkown" computers in all systems and devices.
If i change the mac (vm) it's ok, when i return back to the original mac -> Pending request
Ok so it is a VM that this is occurring on..right?
Can you not just delete the virtual NIC and recreate another one for it?? This way it gets a different identity......maybe it's the current Virtual NIC that is corrupt.
