ogeccut
problems upgrading configuration manager...
I am trying to upgrade to SCCM SP1 and CAS server is build 7782. I am a bit stuck on "Step 10. Update your ConfigMgr client Package"
When i create a package do i need to point to source files "is so what is the location?" I not then there is 1 under programs and
Update distribution points is disabled. What did i miss? Thank you very much for your work and help.
http://www.niallbrad...ration-manager/
And one more question.
I upgraded CAS server to version 7782. P01 is till 7711. Upgrade is disabled when i select P01 site from the CAS server. Do i need to upgrade it manually? Only secondary site can upgraded from the console?
Thank you for the help.
hi there, i had to moderate your post as it was attached to a unrelated post about BitLocker provisioning, please raise new topics when you have problems and only reply to relevant threads
anyway, are you trying to upgrade your LAB or a production environment ? SP1 beta is NOT for use in production...
