ampm24
Best Practice/Setup for a SUP on a DP?
I have a CAS, two Primary, two Secondary, and two DPs. I'm tring to setup the DPs with software updates and do client installs via the Update method. On my primary and secondary servers, this works fine with a GPO tellings those clients to look at their respective SCCM servers for WSUS. This is not working for the DPs. Do I need to tell the workstations at the DP sites to look at the Primary site? I want make sure they get the updates and install the client from the DP itself. Also, when I installed the SUP roll on the DP, it changed the active update point of the Primary server to the DPs server. I changed it back to keep my clients from tring to download updates from a remote site.
0 answers to this question
