sdunham818
SCCM 2007 R3 Inventory/Management point problem
Having an issue with my single primary site/Management point, case is currently opened with Microsoft. It starts like this...
Recently I noticed clients have not been reporting in to the site. This include hardware, software inventories, etc. BITS crashed my console and threw errors, the documented fix was to uninstall BITS, reboot and re-install on the server- done. Then noticed ALL SQL logins have been removed with the exception of a SMSremoteusers read only account!! Microsoft suggested re installing db. - done.
A side note is we have a SCCM 2012 VM Test environment - segregated from our production environment by VLAN and ACOLS. Test environment has own DC, etc. But I don't see any type of interference. Hope someone can help!
PROD Server
SQL 2008
IIS 7
SCCM R3
Management Point
Reporting Point
Distribution Point
Deployment Service
Windows Server Standard SP2 64bit - Physicial Box
8GB RAM
2 Processors 2.66GHz
MPcontrol.log
Successfully performed Management Point availability check against local computer. SMS_MP_CONTROL_MANAGER 11/3/2012 10:27:20 AM 5288 (0x14A8)
Call to HttpSendRequestSync failed for port 80 with status code 404, text: Not Found SMS_MP_CONTROL_MANAGER 11/3/2012 10:32:20 AM 5288 (0x14A8)
Http test request failed, status code is 404, 'Not Found'. SMS_MP_CONTROL_MANAGER 11/3/2012 10:32:20 AM 5288 (0x14A8)
MP_Status.log
Mp Status: processing event: SMS_PolicyAgent_BitsPolicyDownloadFailed, for machine: machinename MP_StatusManager 11/3/2012 11:02:04 AM 9492 (0x2514)
MP Status: SVF file written successfully to "E:\Program Files (x86)\Microsoft Configuration Manager\inboxes\statmgr.box\statmsgs\KQODD45Q.SVF" MP_StatusManager 11/3/2012 11:02:04 AM 9492 (0x2514)
MP_Policy.log
CPolicyManagerHandler::HandleMessage(): SetComplete(DISCARD) called. MP_PolicyManager 11/2/2012 9:56:52 PM 8592 (0x2190)
CMPDBConnection::Init(): IDBInitialize::Initialize() failed with 0x80004005 MP_PolicyManager 11/2/2012 9:56:54 PM 8592 (0x2190)
======================================= MP_PolicyManager 11/2/2012 9:56:54 PM 8592 (0x2190)
MPDB ERROR - CONNECTION PARAMETERS
SQL Server Name : SERVER
SQL Database Name : SMS NAME
Integrated Auth : True
MPDB ERROR - EXTENDED INFORMATION
MPDB Method : Init()
MPDB Method HRESULT : 0x80004005
Error Description : Login failed for user 'NT AUTHORITY\SYSTEM'. Reason: Server is in single user mode. Only one administrator can connect at this time.
OLEDB IID : {}
ProgID : Microsoft OLE DB Provider for SQL Server
MPDB ERROR - INFORMATION FROM DRIVER
Native Error no. : 18461
Error State : 1
Class (Severity) : 14
Line number in SP : 1
MP_Location.log
OLEDB IID : {}
Error State : 1
MP_LocationManager 11/2/2012 9:56:53 PM 8592 (0x2190)
CHandleLocationRequest::CreateReply failed with error (80004005). MP_LocationManager 11/2/2012 9:56:53 PM 8592 (0x2190)
MP LM: Message discarded MP_LocationManager 11/2/2012 9:56:53 PM 8592 (0x2190)
CMPDBConnection::Init(): IDBInitialize::Initialize() failed with 0x80004005 MP_LocationManager 11/2/2012 9:56:53 PM 8592 (0x2190)
======================================= MP_LocationManager 11/2/2012 9:56:53 PM 8592 (0x2190)
IIS W3SVC1/uex121103.log
2012-11-03 16:16:18 10.x.xx.x CCM_POST /ccm_system/request - 80 - 10.x.xx.xxx ccmhttp 200 0 0 3
2012-11-03 16:16:18 10.x.xx.xx BITS_POST /CCM_Incoming/{9F78C7C0-35E7-40F8-9A07-5EF9A8767F31} (bits_error:,501,0x80070005) 80 - xx.xx.xx.xxx Microsoft+BITS/7.5 501 0 0 3
2012-11-03 16:16:18 10.x.xx.xx BITS_POST /CCM_Incoming/{22206B66-F87F-45DE-B174-CD3DC447E3CD} (bits_error:,501,0x80070005) 80 - 10.1.xx.xxx Microsoft+BITS/6.7 501 0 0 1
2012-11-03 16:16:18 10.x.xx.xx HEAD /SMS_MP/.sms_pol {45b5690e-6732-4c9e-8930-85dd3fdd85c0}.14_00 80 - 10.x.xx.xx Microsoft+BITS/7.5 404 0 2 208
2012-11-03 16:16:18 10.x.xx.xx CCM_POST /ccm_system/request - 80 - 10.x.xx.xx ccmhttp 200 0 0 3
UPDATE:
Recovered SQL db logins - MP/BITS still having issues.
MP_Status.log
MP Status: SVF file written successfully to "E:\Program Files (x86)\Microsoft Configuration Manager\inboxes\statmgr.box\statmsgs\KQODD45Q.SVF" MP_StatusManager 11/5/2012 7:02:04 AM 9492 (0x2514)
I hate to say this but if you are working with CSS, you should continue working with them to resolve all of your issues. The main reason for this is that anything that we say or tell you to do. I might step on what the CSS team are trying to do and therefore it might take longer to get things fixed. Plus the CSS team will likely be faster at fixing your issues then the forums.
