towilson Posted November 12, 2012 Report post Posted November 12, 2012 Hi, I am hoping that somebody can help me with setting up a remote SUP/WSUS server. I have a SCCM primary site in network A that does not have internet access. I have another SCCM primary site in network B that does have an active SUP and currently pushes to windows updates to clients. I have been tasked with setting up a SUP for the primary site in network A (no internet connection). I installed the SUP role and tried to configure it to synchronize with the SCCM primary site in network B. That failed and I did some research and found out that I cannot synchronize 2 primary sites. I have been doing more research and it seems that I could install a remote WSUS and SUP role. I do not remember seeing an option to add another server and make it handle the SUP role. Can somebody help me out and help guide me in the right way? Thanks in advance. Quote Share this post Link to post Share on other sites More sharing options...
anyweb Posted November 12, 2012 Report post Posted November 12, 2012 this post was written for CM07 but it should give you the idea http://www.windows-noob.com/forums/index.php?/topic/812-install-a-sup-on-remote-server/ Quote Share this post Link to post Share on other sites More sharing options...
towilson Posted November 12, 2012 Report post Posted November 12, 2012 anyweb, thank you for the quick response! I will try the guide when I return to work. Quote Share this post Link to post Share on other sites More sharing options...
