AlaimoD
Replication Failing on Primary Site and stays in Maintenance Mode
My System has been running fine until last night when a replication for the Configuration Data kicked off on our primary site. The site status is now in Maintenance Mode and will not return to the Active state causing the site to be in READ Only Mode.
ERROR: Replication group "Configuration Data" has failed to initialize for subscribing site CMP, setting link state to Error.
SMS_REPLICATION_CONFIGURATION_MONITOR 11/15/2012 10:24:00 AM 2148 (0x0864)
Processing replication pattern site. SMS_REPLICATION_CONFIGURATION_MONITOR
Summarizing all replication links for monitoring UI.
The current site status: ReplicationMaintenance. SMS_REPLICATION_CONFIGURATION_MONITOR 11/15/2012 10:24:00 AM
2148 (0x0864)
Retry for process replication is requested. SMS_REPLICATION_CONFIGURATION_MONITOR 11/15/2012 10:24:00 AM
2148 (0x0864)
Rcm control is waiting for file change notification or timeout after 60 seconds.
SMS_REPLICATION_CONFIGURATION_MONITOR 11/15/2012 10:24:01 AM 2148 (0x0864)
DRS change application started. SMS_REPLICATION_CONFIGURATION_MONITOR
11/15/2012 10:24:17 AM 3088 (0x0C10)
Site is NOT active, so not calling the DrsActivation procedures.
SMS_REPLICATION_CONFIGURATION_MONITOR 11/15/2012 10:24:17 AM 3088 (0x0C10)
There are 0 Drs Activations sprocs running. SMS_REPLICATION_CONFIGURATION_MONITOR 11/15/2012 10:24:17 AM
3088 (0x0C10)
The Replication Link Analyzer says "Failed to apply Replication Package from site to site" and has nothing helpful in the output logs
Please Help!
