gsankowsky Posted November 19, 2012 Report post Posted November 19, 2012 Hi All, I have a bit of a problem in that I have some Applications that work fine, they deploy where they are meant to and everything is good. However - I cannot select them in "Install Application" in a Task Sequence. Pic 1.jpg shows it in "Application Management" - in this case "Adobe CS6.0 Base Package (64-bit)" *there are other missing programs too Pic 2.jpg show's me trying to select it in a TS "Install Application" - it just doesn't exist! For some time I have been a little bit suspect of our DB........is there anything I can do for a full check? Is anyone able to explain why this could be happening? Regards Greg Quote Share this post Link to post Share on other sites More sharing options...
gsankowsky Posted November 19, 2012 Report post Posted November 19, 2012 Solved...........will try to delete this post Quote Share this post Link to post Share on other sites More sharing options...
Peter van der Woude Posted November 19, 2012 Report post Posted November 19, 2012 Please update the post with the solution. In this case it was probably the checkbox Allow this application to be installed from the Install Application task sequence action without being deployed. Quote Share this post Link to post Share on other sites More sharing options...
gsankowsky Posted November 20, 2012 Report post Posted November 20, 2012 My apologies, Thats what was puzzling, I did have the "Allow this application to be installed from the Install Application task sequence action without being deployed." checked. However in "Deployment Types" under "User experience" I had Install for System with a logon requirement of Only when a user is logged on. This needs to be changed to Whether or not a user is logged on. This had the side-effect of making it not appear at all when selecting a program for a task sequence. 1 Quote Share this post Link to post Share on other sites More sharing options...
Peter van der Woude Posted November 20, 2012 Report post Posted November 20, 2012 Thanks for the update. Quote Share this post Link to post Share on other sites More sharing options...
