midiman
Client installed on workstation but not showing as installed on SCCM
I'm failrly new to SCCM.
I have installed SCCM on my Server and deployed a client to a workstation.
I used the push installation method.
When I check on the workstation I see that the CCMExec process is running. And the Configuration Manager tab is in the Control Panel.
Everything appears to be ok on the workstation.
But when I look under the devices node on the SCCM Server. The Client status is set to NO.
It appears that everything has installed ok, but they can't communicate.
I can't see any error messages, and the client install shows as complete.
What could be going on here?
