BzowK
Help! - BIG Issue with Primary DP After Updating to SP1
OK -
Just got off the phone with Microsoft and think we found the issue... I'm now working!
I had my Site System Installation Account set to my service account (DA) which I use for most everything. We changed that back to "Use the site server's computer account to install the site system."
After doing that, I restarted the SMS_Executive services, updated my packages, and they worked!
Microsoft has now marked it as a "Known Bug"
Please try it out and let me know if this resolves your issues, too -
Thanks -
Thanks for the update, Ben...just as a side note to other users who might not know where this setting is at right away: you can find it under the Administration > Servers and Site System Roles> [site] > Site System Roles: Site System
  On 1/10/2013 at 10:42 AM, anyweb said:
hi Ben
did you use media from the VLMS site or from Technet/MSDN ?
did you uninstall the WAIK prior to installing the ADK ?
did you reboot your server(s) prior to running setup ?
did you review this ?
That technet article never mentions uninstalling WAIK before installing ADK. Was I supposed to do that?
My server behaves very strangley after upgrading to SP1 also, it's very sluggish. I get all kinds of errors in the Site Status and Component Status nodes. Last night I rebooted the server so it could install Windows updates, and when I logged in again the Component Status node contained only a few components, like 4-5. I got errors like these
I think basically every component or site system role has been in Warning or Critical status a few times since upgrading.
Installing applications during OSD sometimes fails also, with different error messages. Apps can sometimes not even be downloaded. I know I'm not being very specific or providing log files, but I can just _feel_ that something's wrong with the server.
Was I supposed to create a new ConfigMgr client package and distribute to the DP when I upgraded to SP1? Or was it enough to just update the package on the DP?
I should add that everything, apart from WSUS, looks totally fine on server right now. I did a site reset last night. OSD is still kind of shaky though.
Good Morning -
I finally found the issue after much research.
Thanks -
  On 1/14/2013 at 3:53 PM, BzowK said:
Good Morning -
Thanks -
also when you change WMI service account to Domain\administrator user. you can solve this problem.
