Special Ed
Inplace upgrade with Hard drive swap
SCCM 2007 with an SMP.
I want to do an inplace upgrade. Current machine is WinXP. The idea is to run a USMT Capture, replace the hard drive, then run an OSD on the new drive, and a restore.
The problem is, because I'm swapping drives, I can't really create a computer association for the SMP, so I can't restore the data. The inplace association doesn't work because it's a new SCCM Client/Guid and a side by side association can't be created because the MAC address is already in use by the old Comp object.
How can I do this? Anyone with any ideas?
Thanks!
0 answers to this question
