kemi
Problem with full unattend WDS deployment / also have prob with multicasting
Okey, the first problem is solved!
<Filename>win7.wim</Filename> was wrong, because the captured win7.wim getting renamed - when WDS adding install image - to win7install.wim
In this video you can see the setup asks me to press next at the select operation system stage.
How can i automate that?
http://www.youtube.com/watch?v=BcwJ-7baJRQ
virtual box 4.2.6
Win2k8r2
Install-wim from syspreped win7
boot.wim from win7 install cd
WDSunattend.xml
<?xml version="1.0" encoding="utf-8"?>
<unattend xmlns="urn:schemas-microsoft-com:unattend">
<settings pass="windowsPE">
<component name="Microsoft-Windows-International-Core-WinPE" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.micro...fig/2002/State" xmlns:xsi="http://www.w3.org/20...hema-instance">
<SetupUILanguage>
<UILanguage>hu-hu</UILanguage>
</SetupUILanguage>
<InputLocale>hu-hu</InputLocale>
<SystemLocale>hu-hu</SystemLocale>
<UILanguageFallback>hu-hu</UILanguageFallback>
<UserLocale>hu-hu</UserLocale>
</component>
<component name="Microsoft-Windows-Setup" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.micro...fig/2002/State" xmlns:xsi="http://www.w3.org/20...hema-instance">
<UserData>
<ProductKey>
<Key>XXXXX-XXXXX-XXXXX-XXXXX-XXXXX</Key>
<WillShowUI>onerror</WillShowUI>
</ProductKey>
<AcceptEula>true</AcceptEula>
</UserData>
<DiskConfiguration>
<Disk wcm:action="add">
<CreatePartitions>
<CreatePartition wcm:action="add">
<Extend>true</Extend>
<Order>1</Order>
<Type>Primary</Type>
</CreatePartition>
</CreatePartitions>
<ModifyPartitions>
<ModifyPartition wcm:action="add">
<Active>true</Active>
<Format>NTFS</Format>
<Order>1</Order>
<PartitionID>1</PartitionID>
<Label>Windows</Label>
<Letter>C</Letter>
</ModifyPartition>
</ModifyPartitions>
<DiskID>0</DiskID>
<WillWipeDisk>true</WillWipeDisk>
</Disk>
</DiskConfiguration>
<ImageInstall>
<OSImage>
<InstallTo>
</InstallTo>
</OSImage>
</ImageInstall>
<WindowsDeploymentServices>
<Login>
<Credentials>
<Domain>iroda.local</Domain>
<Password>********</Password>
<Username>Administrator</Username>
</Credentials>
</Login>
<ImageSelection>
<InstallTo>
<DiskID>0</DiskID>
</InstallTo>
<InstallImage>
<ImageGroup>OS</ImageGroup>
<ImageName>Windows7Ultimate</ImageName>
</InstallImage>
</ImageSelection>
</WindowsDeploymentServices>
</component>
</settings>
<settings pass="specialize">
<component name="Microsoft-Windows-Shell-Setup" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.micro...fig/2002/State" xmlns:xsi="http://www.w3.org/20...hema-instance">
<ComputerName>*</ComputerName>
<TimeZone>GTM+1</TimeZone>
</component>
</settings>
<settings pass="oobeSystem">
<component name="Microsoft-Windows-International-Core" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.micro...fig/2002/State" xmlns:xsi="http://www.w3.org/20...hema-instance">
</component>
<OOBE>
<HideEULAPage>true</HideEULAPage>
<HideWirelessSetupInOOBE>true</HideWirelessSetupInOOBE>
<NetworkLocation>Home</NetworkLocation>
<ProtectYourPC>1</ProtectYourPC>
</OOBE>
<UserAccounts>
<AdministratorPassword>
<Value>MQAyADMANAA1AEEAZABtAGkAbgBpAHMAdAByAGEAdABvAHIAUABhAHMAcwB3AG8AcgBkAA==</Value>
<PlainText>false</PlainText>
</AdministratorPassword>
<LocalAccounts>
<LocalAccount wcm:action="add">
<Password>
<Value>MQAyADMANAA1AFAAYQBzAHMAdwBvAHIAZAA=</Value>
</Password>
<DisplayName>Admin</DisplayName>
<Group>Administrators</Group>
<Name>Administrator</Name>
</LocalAccount>
</LocalAccounts>
</UserAccounts>
</component>
</settings>
<cpi:offlineImage cpi:source="catalog://vboxsvr/installcd/install_windows 7 ultimate.clg" xmlns:cpi="urn:schemas-microsoft-com:cpi" />
</unattend>
and here is the second answer file it works just file
</component>
<OOBE>
</OOBE>
<UserAccounts>
<LocalAccounts>
<Password>
<Value>MQAyADMAUABhAHMAcwB3AG8AcgBkAA==</Value>
</Password>
<Description>first admin user</Description>
<DisplayName>user</DisplayName>
<Group>administrators</Group>
<Name>user</Name>
</LocalAccount>
</LocalAccounts>
</UserAccounts>
<TimeZone>Central Europe Standard Time</TimeZone>
</component>
</settings>
<ProductKey>xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx</ProductKey>
</component>
<component name="Microsoft-Windows-UnattendedJoin" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.micro...fig/2002/State" xmlns:xsi="http://www.w3.org/20...hema-instance">
<Identification>
<Credentials>
</Credentials>
<JoinDomain>iroda.local</JoinDomain>
</Identification>
</component>
</settings>
<cpi:offlineImage cpi:source="catalog://kem-pc/cinstallcd/sources/install_windows 7 ultimate.clg" xmlns:cpi="urn:schemas-microsoft-com:cpi" />
</unattend>
I also have problem with multicasting. I am using VirtualBox to simulate deploying multiple windows7's.
When 2 clients are loaded and the setup ask me to press next at the select operation system stage as before it stops with "system can't find the hard disk to store temp install files".
If i close one client and press the next on the other one it will continue to install.
2 answers to this question
the first parth is solved, but i still got this error
the first one is failed, the second one is good
what is the problem?
okey, now it is solved too
i had to expand the virtual hard disk, i also reduced the amount of RAM per virtual machine
it is strange because i could install win7 to the smaller virtual disk before, but not with multicasting
First off, congrats on solving your deployment issue. However, when reading your two posts, I thought of another solution that you may find beneficial for deployment. In addition to using WDS and unattend files for automating your deployments, you might also want to checkout MDT, the Microsoft Deployment Toolkit, which is a free utility provided by Microsoft and can help automate all deployments from Windows XP, Windows Vista, Windows 7, Windows 8, Windows Server 2003, Windows Server 2008, Windows Server 2008 R2, and Windows Server 2012. Using MDT, you can create hardware independent images and add drivers as well as applications to a deployment share and then create a task sequence tailored to your deployment needs. Creating an unattend file and deploying a captured image using WDS is a great method but it couldn’t hurt to also see if MDT would also be able to meet your needs. Perhaps one of my favorite things about MDT is that it can even be used in conjunction with WDS.
To become more familiar with MDT as a stand-alone product as well as in conjunction with WDS, I recommend the following 3 videos from the Springboard Series page on TechNet:
· Deployment Day Session 1: Introduction to MDT 2012
· Deployment Day Session 2: MDT 2012 Advanced
· Deployment Day Session 3: Deployment using WDS
Anyway, again, I am glad you were able to get your deployment working in your virtual environment. Feel free to reach out with any questions.
Jessica
