Harmen1966
Using remote DP
Hi.
I have the following question we’ve setup an primary SCCM2012 server (C and D partition) and a DPsrv. On both partitions of the primsrv I copied the file no_sms_on_drive.sms. But now the package won’t be copied to the D-partition of the DPSrv.
When I remove the no_sms_on_drive.sms on the D partition on the Prisrv then the packages would copy to the DP server.
For some reason the packages must also be on the D-partition Primsrv partition and stay there before it can be copied to the special DP server which I want to use for this.
Maybe I’m wrong but I don’t see the benefit of using a remote DP server. (the files are now three times in my network, one original location, one on the Prisrv and one on the DP server). In my old SCCM2007 envoirment I used one Prisrv wich also was an DPsrv.
What should I do leave it this way or remove the special DPsrv and use the prisrv as an DPsrv as well?
Thanks,
Harmen
