faravardeh
need help and advice
Dear Sir,
Nice to see you,.
I need your kind help and your advice .
I installed system configure manager 2012 sp1 as primary standalone site on Windows server 2012 datacenter edition and with standard SQL server,. Then I added Hyper-V role at same server and then added two VMs ( one windows seven and one windows 8) to test configure manager before I send all of my clients to my Environment,. Client Software pushed successfully on one windows seven and one windows 8 VMs,.
But I have some problems :
1.after installing Asset Intelligence role I found that Asset intelligence synchronization point status is not provisioned and I cannot find hardware and software inventories of my VMs,. I can see only hardware and software inventories for my SCCM 2012 Server .
2.in client check I found that my two VMS( one windows seven and one windows 8) that Client Software pushed successfully have not result .
3.I found in properties of device collection that power management tab is not active , so I cannot set power management settings.
I am looking forward for your kind reply and answers,.
Best Regards
AliReza FARAVARDEH.
