I really just need a place to start with the errors we found. Long story short, we were looking into why one of our servers isn't showing in the console and found this. The DDM component is showing errors about every minute. Now everything appears to be working fine with pushing patches etc. However, we did have issues trying to delete old items from the console so we turned on the features for removing inactive clients.
I have attached the screen shots of the errors in the txt doc.
It appears to be an access issue to a SQL database. Rough guess is when SCCM is trying to retire data, it is denied access to that database and cannot remove the information. This install has been going for 9 months and appears to be going fine for what we use it for (Patching/Endpoint Protection/Reporting).
I just don't know where to look when checking the access rights. It would help if there was a database listed when the failures show up in the SQL log. Any help would be greatly appreciated.
From the SMS Discovery Data Manager Error Log:
Severity Type Site code Date / Time System Component Message ID Description
Error Milestone P01 2/5/2013 2:46:20 PM SERVER NAME SMS_DISCOVERY_DATA_MANAGER 2636 Discovery Data Manager failed to process the discovery data record (DDR) "D:\Program Files\Microsoft Configuration Manager\inboxes\auth\ddm.box\regreq\R2LI5F68.RDR", because it cannot update the data source. Possible cause: On a Primary site, it is probably a SQL Server problem. Solution: 1. Review the immediately preceding status messages from this component about SQL Server errors. 2. Verify that this computer can reach the SQL Server computer. 3. Verify that SQL Server services are running. 4. Verify that the site can access the site database. 5. Verify that the site database, transaction log, and tempdb are not full. 6. Verify that there are at least 50 SQL Server user connections, plus 5 for each Configuration Manager Console. If the problem persists, check the SQL Server error logs. Possible cause: On a secondary site, Discovery Data Manager probably cannot write to a file on the site server, so check for low disk space on the site server. Solution: Make more space available on the site server.
Error Milestone P01 2/5/2013 2:46:20 PM SERVER NAME SMS_DISCOVERY_DATA_MANAGER 620 Microsoft SQL Server reported SQL message 8144, severity 16: [42000][8144][Microsoft][sql Server Native Client 10.0]
Procedure or function spSystemDecommission has too many arguments specified. : spSystemDecommission Please refer to your Configuration Manager documentation, SQL Server documentation, or the Microsoft Knowledge Base for further troubleshooting information.
*** [42000][8144][Microsoft][sql Server Native Client 10.0][sql Server]Procedure or function spSystemDecommission has too many arguments specified. : spSystemDecommission SMS_DISCOVERY_DATA_MANAGER 2/5/2013 2:44:15 PM 1732 (0x06C4)
2013-02-05 13:55:29.02 Logon Login failed for user 'NT AUTHORITY\SYSTEM'. Reason: Failed to open the explicitly specified database. [CLIENT: <local machine>]
2013-02-05 13:55:29.04 Logon Login failed for user 'PROLIANCE\service1'. Reason: Failed to open the explicitly specified database. [CLIENT: 172.16.1.15]
2013-02-05 13:55:29.10 Logon Login failed for user 'NT AUTHORITY\NETWORK SERVICE'. Reason: Failed to open the explicitly specified database. [CLIENT: fe80::b5a1:988b:8420:6ca%13]
2013-02-05 13:55:29.11 Logon Login failed for user 'NT AUTHORITY\SYSTEM'. Reason: Failed to open the explicitly specified database. [CLIENT: 172.16.1.15]
2013-02-05 13:55:29.18 Logon Login failed for user 'NT AUTHORITY\SYSTEM'. Reason: Failed to open the explicitly specified database. [CLIENT: fe80::b5a1:988b:8420:6ca%13]
2013-02-05 13:55:29.25 Logon Login failed for user 'NT AUTHORITY\NETWORK SERVICE'. Reason: Failed to open the explicitly specified database. [CLIENT: 172.16.1.15]
2013-02-05 13:55:29.25 Logon Login failed for user 'NT AUTHORITY\NETWORK SERVICE'. Reason: Failed to open the explicitly specified database. [CLIENT: fe80::b5a1:988b:8420:6ca%13]
2013-02-05 13:55:29.45 Logon Login failed for user 'NT AUTHORITY\NETWORK SERVICE'. Reason: Failed to open the explicitly specified database. [CLIENT: fe80::b5a1:988b:8420:6ca%13]
2013-02-05 13:55:30.11 Logon Login failed for user 'NT AUTHORITY\SYSTEM'. Reason: Failed to open the explicitly specified database. [CLIENT: 172.16.1.15]
2013-02-05 13:55:32.03 spid18s A new instance of the full-text filter daemon host process has been successfully started.
Hello and thanks for reading.
ID Description
From the DDM log file
Client registration updated. SMS_DISCOVERY_DATA_MANAGER 2/5/2013 2:44:14 PM 1732 (0x06C4)
*** exec dbo.spSystemDecommission 2097152234, false,
false,true SMS_DISCOVERY_DATA_MANAGER 2/5/2013 2:44:15 PM 1732 (0x06C4)
CDiscoverySource_SQL::DecommissionDiscoveryItem - Error
decommissioning resource data. SMS_DISCOVERY_DATA_MANAGER 2/5/2013 2:44:15 PM 1732 (0x06C4)
CDiscoverDataManager::ProcessDDRs - Unable to update data
source SMS_DISCOVERY_DATA_MANAGER 2/5/2013 2:44:15 PM 1732 (0x06C4)
SQL server log file
2013-02-05 13:55:29.02 Logon Error: 18456, Severity: 14, State: 38.
2013-02-05 13:55:29.04 Logon Error: 18456, Severity: 14, State: 38.
2013-02-05 13:55:29.10 Logon Error: 18456, Severity: 14, State: 38.
2013-02-05 13:55:29.11 Logon Error: 18456, Severity: 14, State: 38.
2013-02-05 13:55:29.18 Logon Error: 18456, Severity: 14, State: 38.
2013-02-05 13:55:29.25 Logon Error: 18456, Severity: 14, State: 38.
2013-02-05 13:55:29.45 Logon Error: 18456, Severity: 14, State: 38.
2013-02-05 13:55:30.11 Logon Error: 18456, Severity: 14, State: 38.
2013-02-05 13:55:32.05 Logon Error: 18456, Severity: 14, State: 38.
Errors.docFetching info...
