marlonc1980
Add Attribute Class: Add/Remove Programs Collections
Hi I want to make a collection where I display all computers that are not running Office 2013, but I have not locate the class attributes Add or Remove Programs do not see, as active? see image.
I have sql 2012 sp1 sccm
Collection based on computers with a specific program in Add/Remove Programs
Criterion Value: Simple
Attribute: Display Name
Operator: is equal to / is like
Value: <Program Name>
select SMS_R_SYSTEM.ResourceID,SMS_R_SYSTEM.ResourceType,SMS_R_SYSTEM.Name,SMS_R_SYSTEM.SMSUniqueIdentifier,SMS_R_SYSTEM.ResourceDomainORWorkgroup,SMS_R_SYSTEM.Client from SMS_R_System inner join SMS_G_System_ADD_REMOVE_PROGRAMS as Software on Software.ResourceId = SMS_R_System.ResourceId where Software.DisplayName != "Software"
Just paste the above in the query language and change the Software section to suit your queried software i:e Microsoft Office professional Plus 2013
FYI only, This query will show every PC within your environment. Also this query will only show the 32bit versions. You need to use a subselect query for this.
  Quote
Hi Garth
I have this query fully tested in my environment. At The moment in one of my sites I have just started to roll out office 2013. In my head I had a rough estimate as to what I had already done which was around 10-13 machines out of a total of 3555
If I leave the != Microsoft Office Professional Plus 2013 then the query returns 3542 systems to the collection(which would be correct)
I change the syntax to just = Microsoft Office Professional Plus 2013 then the query returns 13 systems to the collection(which is also correct)
So that to me means that the query language is working, should it not be??
Here are a few blog posts on the subject.
http://smsug.ca/blogs/garth_jones/archive/2007/05/08/subset-query.aspx
http://smsug.ca/blogs/garth_jones/archive/2007/05/10/wql-subset-query.aspx
http://smsug.ca/blogs/garth_jones/archive/2007/05/09/sql-subset-query.aspx
Wish me luck, I'm just about to install Windows 8 on this laptop! Who know when I will be back online!
