KeithDib
Deploy Windows 7 using SCCM - Drive letter issue
Hi
I am deploying Windows 7 Pro SP1 from the standard install.wim through SCCM 2007 R3,
I have tried both in the TS to install to C:\ and also from within the unattend.xml, but it always seems to install to D:\.
Even when installing the install.win onscreen it says installing to C:\, so its like its changing after initial installation?
Anyone help
Keith
7 answers to this question
  Quote
the best practice is run a build and capture ts and use that image to deploy
  Quote
Why cant you just Deploy from the Install.wim from OS disk and get it to install to C: ?
It seems a lot of work to have to build and capture just to get it to C:
The easiest/quickest way is to create a capture media iso, not build and capture as this can be a slow process by times depending if successful or not.
Build your custom image on a VM and attach the iso capture image, punch in the required credentilas and the rest is all automated.. Then you will have a wim file that when deployed it will install on the C: partition.
the link below may help you unsderstand why it installs on the D: drive an not C:
http://blogs.technet.com/b/inside_osd/archive/2007/08/08/why-does-vista-end-up-on-the-d-drive.aspx
