KSSGTS
Failures during Deploy and Capture of Reference Machine
I am currently having some issues with one of our Task Squences for Deploying and Capturing a Reference machine. We have not change anything in the TS except for the former SCCM Admin had his personal account not a service account capturing the system. This is the only thing we have changed. This TS is ran every month to keep our Baseline Image updated and patched. Help with locating the route of the problem or starting point I havn't thought of would be great. I have checked the package and the source files and access and have found no issues so far.
Any HELP would be great!!!
TS Errors:
1) 2/11/2013 1:06:21 PM Running The task sequence execution engine failed executing an action 11135 832990
2) 2/11/2013 1:06:21 PM Failed The task sequence execution engine failed execution of a task sequence 11141 832991
3) 2/11/2013 1:16:30 PM Failed The task sequence manager could not successfully complete execution of the task sequence 11170 832992
Details for each error above:
1) Message Details
Timestamp: 2/11/2013 1:06:21 PM Message Type: Milestone
Site Code: U54 Message ID: 11135
System: NURCSWKSGIMAGE1 Process ID: 288
Source: SMS Client Thread ID: 1328
Component: Task Sequence Engine Severity: Error
Description
The task sequence execution engine failed executing the action (Install Software - Classify 12.1.35) in the group (Baseline Software Install) with the error code 2147944039 Action output: 6F-762D-4DB4-B535-CDEC095B2691}' Waiting for installation job to complete.. CompleteExecution received Received job completion notification from Execution Manager Installation completed with exit code 0x80070667 Setting TSEnv variable 'SMSTSInstallSoftwareJobID_U540002A_U5420058_32bit and 64bit Install'='' CompleteExecution processed GetExecRequestMgrInterface successful Releasing job request, jobID='{BFE2216F-762D-4DB4-B535-CDEC095B2691}' Releasing of Job Request successful CompleteJob successful Entering ReleaseSource() for C:\_SMSTaskSequence\Packages吀02A reference count 1 for the source C:\_SMSTaskSequence\Packages吀02A before releasing Delete source directory C:\_SMSTaskSequence\Packages吀02A Released the resolved source C:\_SMSTaskSequence\Packages吀02A pInstall->Install(sPackageID, sProgramName), HRESULT=80070667 (e:\nts_sms_fre\sms\client\osdeployment\installsoftware\main.cpp,374) Installation failed with error (0x80070667) Install Software failed, hr=0x80070667. The operating system reported error -2147023257: Invalid command line argument. Consult the Windows Installer SDK for detailed command line help.
Properties
Package ID U5400024
Advertisement ID U5420058
Client SMS Unique ID GUID:67B2D6C2-D83E-4AAB-8C5D-FA748CAA8C5F
Unknown Machine 0
MAC Addresses 00:50:56:25:D4:64
SMBIOS ID 05D24D56-A85A-2694-FF84-C2BEB034C320
2) Message Details
Site Code: U54 Message ID: 11141
Description
The task sequence execution engine failed execution of a task sequence. The operating system reported error -2147023257: Invalid command line argument. Consult the Windows Installer SDK for detailed command line help.
Properties
Package ID U5400024
Unknown Machine 0
3) Message Details
Timestamp: 2/11/2013 1:16:30 PM Message Type: Milestone
Site Code: U54 Message ID: 11170
Component: Task Sequence Manager Severity: Error
Description
The task sequence manager could not successfully complete execution of the task sequence. A failure exit code of 16389 was returned. The operating system reported error 16389:
Properties
Package ID U5400024
0 answers to this question
