trhg
Problem with device drivers during OSD
To troubleshoot, remove any WMI queries in case that's the issue, and just have it run unconditionally. You also ought to double check the PCI Device ID to verify that it is indeed the correct driver, Open up the .inf file and look for the line that says something like this:
"PCI\VEN_8086&DEV_2A42&SUBSYS_30DB103C"
compare that to device manager, hardware IDs... to confirm at LEAST VEN_####&DEV_#### match.
Also checking ""Do Attended installaiton of unsigned drivers on versions of Windows where this is allowed" helps a lot.
The solution was to download the Dell System Management Tools & Documentation DVD. Then extract out the drivers for my OS and server. Now it works,
I Used my old drivers form my old SCCM 2007 environment and i thought it would work...
Thanks for your time guys : )!
