Ocelaris
SUP Migration from 2007 Problems
So I've gotten our new CM 2012 SUP environment set up and am working on migrating what I can from our old 2007 environment. During the migration phase, I'm getting a "Could not find the specified instance". It's particularly difficult to search on "SUP" because the 3 letter search (google site search didn't help much). A little background, our 2007 environment ponied up to a seperate WSUS server which served as our only SUP, now I have 2 SUPs with 2012 SP1. One is our Stand alone Primary server, and the other is our DMZ Internet facing IBCM server. Both point at a shared separate SQL server installed on the default instance (which worked quite well may I add after I added SP1).
Anyone have any experience with migrating the Approvals and groups? Our security engineer runs the software updates, so I'm not so knowledgeable about the inner workings of the SUP approval and collections process at this point (although I maintain the SCCM/CM infrastructure), so I'm basically just trying to not have the security guy reapprove all his updates. I assume the computers will be able to scan against the database. I had thought about trying the WSUTIL program, but I know CM doesn't like people messing directly with the WSUS DB...
