Harvey
Unattend.xml and SCCM 2007 OSD
If I specify the unattend.xml in the "Apply Operating System Image" do I need to sysprep the system using the /unattend switch to the location where SCCM copies it too?
It copies it to the c:\windows\panther\unattend\ from teh smstslogs and before capture, that's folder doesn't exist.
Thanks!
Are you talking about using one during OS deployment, or during some sort of image capture process? When you capture an image, you should be allowing SCCM to sysprep it for you. So you typically just need to use an unattend.xml file during OS deployment and don't need to do anything when capturing the image...
