Terence
OSD Task Sequence - Applications that require a drive letter
Hello
I have an OSD task sequence, there are around 20 applications that install along with the OS
Some are MSI, some are vbscript wappers
I normally have all the content download locally but i want to try and run the content from the DP(much faster).
my problem is the vbscript wrappers, they dont work from a UNC path.
Now in the program for each app you can set the drive mode to "requires a drive letter" which works when you deploy the application through a normal advert.
But doesn't work when i do it as part of the TS which is "accessing content directly from the dp"
It just maps the drive, in the log it looks like its running the script but just hangs till it times out
Any advice please
