Serial Posted February 26, 2013 Report post Posted February 26, 2013 Shall I add the SCCM Client on the standard image or push it later to the collection through SCCM server? Will there be any issue if I add the SCCM client to the standard OS image? Please advise. Quote Share this post Link to post Share on other sites More sharing options...
Deano Posted February 26, 2013 Report post Posted February 26, 2013 I put my client in the image like you suggest. There should not be any problem, as old client versions will be automatically upgraded once the client checks in 1 Quote Share this post Link to post Share on other sites More sharing options...
Serial Posted February 26, 2013 Report post Posted February 26, 2013 Thanks, I was wondering if this would generate duplicate sid issue like Symantec does. Quote Share this post Link to post Share on other sites More sharing options...
Peter van der Woude Posted February 26, 2013 Report post Posted February 26, 2013 It does use GUIDs. The only way you should add the SCCM client to an image is to either use the Build and Capture task sequence, or follow these guidelines: http://technet.microsoft.com/en-us/library/bb694095.aspx Quote Share this post Link to post Share on other sites More sharing options...
Deano Posted February 26, 2013 Report post Posted February 26, 2013 I have never gone through that process with my clients. I sysprep my image before deployment and never seen any issues on 1000+ client's Quote Share this post Link to post Share on other sites More sharing options...
Serial Posted February 28, 2013 Report post Posted February 28, 2013 Thanks both. I am now planning to install it through TS instead. If you have better opinion, please do share. Quote Share this post Link to post Share on other sites More sharing options...
