dgriffin Posted February 26, 2013 Report post Posted February 26, 2013 Hi All, My test lab is ran on VMware with 1 AD server and a memeber server with SCCM 2012, and SQL installed. Everything else within SCCM works fine but when it comes to deploying an OS, the task sequence fails. Here's the full error: Task Sequence Failed - An error occurred while retreiving policy of this computer. I've searched high and low for a fix but what I had tried doesn't work. Some suggest that the bios time/date is the issue, or pki certs are needed. Tried both methods with no success. Any input would be great. Thanks Quote Share this post Link to post Share on other sites More sharing options...
Config Mangler Posted February 27, 2013 Report post Posted February 27, 2013 Is the computer record ok in SCCM? Double click the computer and check if its obsolete or the background is grey. There's also a hot fix for SCCM sp1 which may apply here. I'll post a link later. Quote Share this post Link to post Share on other sites More sharing options...
dgriffin Posted February 27, 2013 Report post Posted February 27, 2013 Hi, Thanks for replying. I will have to check this later on. Quote Share this post Link to post Share on other sites More sharing options...
Oneone Posted February 27, 2013 Report post Posted February 27, 2013 Sounds like boundarys , check them and that the computer is a member there. Also post smstslog so we can have a look Quote Share this post Link to post Share on other sites More sharing options...
dgriffin Posted March 5, 2013 Report post Posted March 5, 2013 Hi, I've been searching all over for the location for the smtslog. Do you know where it is located? Quote Share this post Link to post Share on other sites More sharing options...
Iroqouiz Posted March 6, 2013 Report post Posted March 6, 2013 Like Oneone says, it sounds like you haven't created the correct boundaries, or that your boundaries are not a member of a boundary group. Quote Share this post Link to post Share on other sites More sharing options...
dgriffin Posted March 13, 2013 Report post Posted March 13, 2013 I have all of the correct boundaries listed in SCCM, I also upgrade to SP1. Still does the same thing. If I could get this portion of SCCM working, all should be fine. Anyone have any other suggestions? Thanks alot for all of your comments! Quote Share this post Link to post Share on other sites More sharing options...
dgriffin Posted March 13, 2013 Report post Posted March 13, 2013 One more thing, I don't know where the smtslog is located. There's a folder called logs under the SCCM folder on C: but it doesn't contain that file. Quote Share this post Link to post Share on other sites More sharing options...
almababy Posted March 13, 2013 Report post Posted March 13, 2013 I have a similar issue with the same Task Sequence Error. Imported new Dell drivers and getting task sequence errror below. Image works great with my other workstations. <![LOG[Error Task Sequence Manager failed to execute task sequence. Code 0x80004005]LOG]!><time="18:58:02.303+300" date="03-12-2013" component="TSManager" context="" type="3" thread="1560" file="tsmanager.cpp:671"><![LOG[sending error status message]LOG]!><time="18:58:02.303+300" date="03-12-2013" component="TSManager" context="" type="1" thread="1560" file="tsmanager.cpp:672"> <![LOG[MP server http://DAPRODSMS02.ocm.ORIXUSA.CORP. Ports 80,443. CRL=false.]LOG]!><time="18:58:02.303+300" date="03-12-2013" component="TSManager" context="" type="1" thread="1560" file="utils.cpp:4855"><![LOG[setting authenticator]LOG]!><time="18:58:02.319+300" date="03-12-2013" component="TSManager" context="" type="1" thread="1560" file="utils.cpp:4877"> <![LOG[set authenticator in transport]LOG]!><time="18:58:02.319+300" date="03-12-2013" component="TSManager" context="" type="1" thread="1560" file="libsmsmessaging.cpp:7592"> <![LOG[sending StatusMessage]LOG]!><time="18:58:02.319+300" date="03-12-2013" component="TSManager" context="" type="1" thread="1560" file="libsmsmessaging.cpp:4020"> <![LOG[setting message signatures.]LOG]!><time="18:58:02.319+300" date="03-12-2013" component="TSManager" context="" type="0" thread="1560" file="libsmsmessaging.cpp:1292"> <![LOG[setting the authenticator.]LOG]!><time="18:58:02.319+300" date="03-12-2013" component="TSManager" context="" type="0" thread="1560" file="libsmsmessaging.cpp:1322"> <![LOG[CLibSMSMessageWinHttpTransport::Send: URL: DAPRODSMS02.ocm.ORIXUSA.CORP:80 CCM_POST /ccm_system/request]LOG]!><time="18:58:02.319+300" date="03-12-2013" component="TSManager" context="" type="1" thread="1560" file="libsmsmessaging.cpp:8422"> <![LOG[Error. Received 0x80072ee7 from WinHttpSendRequest.]LOG]!><time="18:58:02.319+300" date="03-12-2013" component="TSManager" context="" type="1" thread="1560" file="libsmsmessaging.cpp:8689"> <![LOG[unknown host (gethostbyname failed)]LOG]!><time="18:58:02.319+300" date="03-12-2013" component="TSManager" context="" type="3" thread="1560" file="libsmsmessaging.cpp:692"> <![LOG[hr, HRESULT=80072ee7 (e:\nts_sccm_release\sms\framework\osdmessaging\libsmsmessaging.cpp,8738)]LOG]!><time="18:58:02.334+300" date="03-12-2013" component="TSManager" context="" type="0" thread="1560" file="libsmsmessaging.cpp:8738"> <![LOG[sending with winhttp failed; 80072ee7]LOG]!><time="18:58:02.334+300" date="03-12-2013" component="TSManager" context="" type="3" thread="1560" file="libsmsmessaging.cpp:8738"> <![LOG[Will retry in 4 second(s)]LOG]!><time="18:58:02.334+300" date="03-12-2013" component="TSManager" context="" type="2" thread="1560" file="libsmsmessaging.cpp:1830"> <![LOG[Retrying...]LOG]!><time="18:58:07.046+300" date="03-12-2013" component="TSManager" context="" type="2" thread="1560" file="libsmsmessaging.cpp:1834"> <![LOG[CLibSMSMessageWinHttpTransport::Send: URL: DAPRODSMS02.ocm.ORIXUSA.CORP:80 CCM_POST /ccm_system/request]LOG]!><time="18:58:07.046+300" date="03-12-2013" component="TSManager" context="" type="1" thread="1560" file="libsmsmessaging.cpp:8422"> <![LOG[Error. Received 0x80072ee7 from WinHttpSendRequest.]LOG]!><time="18:58:07.046+300" date="03-12-2013" component="TSManager" context="" type="1" thread="1560" file="libsmsmessaging.cpp:8689"> Any help will be most appreciative..... Quote Share this post Link to post Share on other sites More sharing options...
dgriffin Posted March 13, 2013 Report post Posted March 13, 2013 @almababy Where was the log located? Can't seem to find mine. Before upgrading to Sp1, I tried importing the vmware drivers and that didn't work either. I'll have to try again. Quote Share this post Link to post Share on other sites More sharing options...
