mjeds Posted March 5, 2013 Report post Posted March 5, 2013 ok so I have been this forums installation guide and on Part 5. Adding WSUS, Adding the SUP role, deploying the Configuration Manager Client Agent, I started having issues. currently the package fails on all clients. I have the following errors in the CM Status Message Viewer: SMS_MP_CONTROL MANAGER - MP Control Manager detected management point is not responding to HTTP requests. The HTTP status code and text is 500, Internal Server Error. SMS_DISTRIBUTION_MANAGER - Distribution Manager failed to process package "Configuration Manager Client Upgrade Package" (package ID = LGI00003). SMS_DISTRIBUTION_MANAGER - Distribution Manager is waiting for package LGI00002 content to be prestaged on the distribution point ["Display=\\SCCM.mydomain.local\"]MSWNET:["SMS_SITE=LGI"]\\SCCM.mydomain.local\. You must manually prestage the package LGI00002 on the distribution point before the content will be available. SMS_DISTRIBUTION_MANAGER - Failed to create virtual directory on the defined share or volume on distribution point "["Display=\\SCCM.mydomain.local\"]MSWNET:["SMS_SITE=LGI"]\\SCCM.mydomain.local\". ok so I have been this forums installation guide and on Part 5. Adding WSUS, Adding the SUP role, deploying the Configuration Manager Client Agent, I started having issues. currently the package fails on all clients. I have the following errors in the CM Status Message Viewer: SMS_MP_CONTROL MANAGER - MP Control Manager detected management point is not responding to HTTP requests. The HTTP status code and text is 500, Internal Server Error. SMS_DISTRIBUTION_MANAGER - Distribution Manager failed to process package "Configuration Manager Client Upgrade Package" (package ID = LGI00003). SMS_DISTRIBUTION_MANAGER - Distribution Manager is waiting for package LGI00002 content to be prestaged on the distribution point ["Display=\\SCCM.mydomain.local\"]MSWNET:["SMS_SITE=LGI"]\\SCCM.mydomain.local\. You must manually prestage the package LGI00002 on the distribution point before the content will be available. SMS_DISTRIBUTION_MANAGER - Failed to create virtual directory on the defined share or volume on distribution point "["Display=\\SCCM.mydomain.local\"]MSWNET:["SMS_SITE=LGI"]\\SCCM.mydomain.local\". Quote Share this post Link to post Share on other sites More sharing options...
mjeds Posted March 5, 2013 Report post Posted March 5, 2013 Also this started after a reboot (due to updates installed) of the Remote SQL server: Microsoft SQL Server reported SQL message 50000, severity 16: 42000 50000 Microsoft SQL Server Native Client 11.0 SQL Server ERROR 6527, Level 16, State 1, Procedure sp_SetupCI, Line 56, Message: .NET Framework runtime has been stopped. : spRethrowError Please refer to your Configuration Manager documentation, SQL Server documentation, or the Microsoft Knowledge Base for further troubleshooting information. ----- CCMSETUP Errors from ccmsetup.log on the clients: Current AD site of machine is Default-First-Site-Name LocationServices 3/4/2013 17:17:22 10204 (0x27DC) DHCP entry points already initialized. LocationServices 3/4/2013 17:17:22 10204 (0x27DC) Begin checking Alternate Network Configuration LocationServices 3/4/2013 17:17:22 10204 (0x27DC) Finished checking Alternate Network Configuration LocationServices 3/4/2013 17:17:22 10204 (0x27DC) Sending message body '<ContentLocationRequest SchemaVersion="1.00"> <AssignedSite SiteCode="LGI"/> <ClientPackage/> <ClientLocationInfo LocationType="SMSPACKAGE" DistributeOnDemand="0" UseProtected="0" AllowCaching="0" BranchDPFlags="0" AllowHTTP="1" AllowSMB="0" AllowMulticast="0" UseInternetDP="0"> <ADSite Name="Default-First-Site-Name"/> <Forest Name="mydomain.local"/> <Domain Name="mydomain.local"/> <IPAddresses> <IPAddress SubnetAddress="192.168.9.0" Address="192.168.9.99"/> </IPAddresses> </ClientLocationInfo> </ContentLocationRequest> ' ccmsetup 3/4/2013 17:17:22 10204 (0x27DC) Sending message header '<Msg SchemaVersion="1.1"><ID>{F21C6276-91D0-4EEF-A65F-7721229CFF1C}</ID><SourceHost>IT-MANAGER</SourceHost><TargetAddress>mp:[http]MP_LocationManager</TargetAddress><ReplyTo>direct:IT-MANAGER:LS_ReplyLocations</ReplyTo><Priority>3</Priority><Timeout>600</Timeout><ReqVersion>5931</ReqVersion><TargetHost>http://SCCM.mydomain.local</TargetHost><TargetEndpoint>MP_LocationManager</TargetEndpoint><ReplyMode>Sync</ReplyMode><Protocol>http</Protocol><SentTime>2013-03-05T01:17:22Z</SentTime><Body Type="ByteRange" Offset="0" Length="1122"/><Hooks><Hook3 Name="zlib-compress"/></Hooks><Payload Type="inline"/></Msg>' ccmsetup 3/4/2013 17:17:22 10204 (0x27DC) CCM_POST 'http://SCCM.mydomain.local/ccm_system/request' ccmsetup 3/4/2013 17:17:22 10204 (0x27DC) Content boundary is '--aAbBcCdDv1234567890VxXyYzZ' ccmsetup 3/4/2013 17:17:22 10204 (0x27DC) Received header '<Msg SchemaVersion="1.1"> <ID>{01615E20-6BC3-43FB-9D23-F46D36418DE3}</ID> <SourceID>GUID:D8795CBE-1917-42B7-BCED-B40EF849B2E1</SourceID> <SourceHost>SCCM</SourceHost> <TargetAddress>direct:IT-MANAGER:LS_ReplyLocations</TargetAddress> <ReplyTo>MP_LocationManager</ReplyTo> <CorrelationID>{00000000-0000-0000-0000-000000000000}</CorrelationID> <Priority>3</Priority> <Timeout>600</Timeout> <TargetHost>IT-MANAGER</TargetHost><TargetEndpoint>LS_ReplyLocations</TargetEndpoint><ReplyMode>Sync</ReplyMode><Protocol>http</Protocol><SentTime>2013-03-05T01:20:35Z</SentTime><Body Type="ByteRange" Offset="0" Length="1254"/><Hooks><Hook3 Name="zlib-compress"/><Hook Name="authenticate"><Property Name="Signature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roperty><Property Name="AuthSenderMachine">SCCM;SCCM.mydomain.local;</Property><Property Name="MPSiteCode">LGI</Property></Hook></Hooks><Payload Type="inline"/></Msg>' ccmsetup 3/4/2013 17:17:22 10204 (0x27DC) Received reply body '<ContentLocationReply SchemaVersion="1.00"><ContentInfo PackageFlags=""><ContentHashValues/></ContentInfo><Sites><Site><MPSite SiteCode="LGI" MasterSiteCode="LGI" SiteLocality="LOCAL" IISPreferedPort="" IISSSLPreferedPort=""/><LocationRecords/></Site></Sites><ClientPackage FullPackageID="LGI00002" FullPackageVersion="1" FullPackageHash="5EF3A189C48F3469440A83026EC8ECD36EAD6EAF3B5D35663F8201BDE175413C" MinimumClientVersion="5.00.7804.1000" RandomizeMaxDays="7" ProgramEnabled="false" LastModifiedTime="30283434;1919425536" SiteVersionMatch="true" SiteVersion="5.00.7804.1000" EnablePeerCache="true"/></ContentLocationReply>' ccmsetup 3/4/2013 17:17:22 10204 (0x27DC) Failed to get DP locations as the expected version from MP 'http://SCCM.mydomain.local'. Error 0x87d00215 ccmsetup 3/4/2013 17:17:22 10204 (0x27DC) MP 'http://SCCM.mydomain.local' didn't return DP locations for client package with the expected version. Retrying in 30 minutes. ccmsetup 3/4/2013 17:17:22 10204 (0x27DC) Next retry in 30 minute(s)... ccmsetup 3/4/2013 17:17:22 10204 (0x27DC) -------------------- I followed parts 1-4 to the letter.. Got to Part 5 and everything fell apart.. WSUS seems to be working correctly, but I cannot get CCMSETUP to install.. Quote Share this post Link to post Share on other sites More sharing options...
mjeds Posted March 5, 2013 Report post Posted March 5, 2013 ok well I have cleared all the errors out. not really sure what caused them, but after spending hours searching on Google, I came to the conclusion that removing the MP, App Cat Web Service, and App Cat Website roles, Rebooting and reapplying those roles should correct the errors and it did. I was able to successful push the ccmsetup to 1 client, currently waiting on the GPO schedule for Auto Updates to push out the rest. Quote Share this post Link to post Share on other sites More sharing options...
mjeds Posted March 5, 2013 Report post Posted March 5, 2013 ugh.. well I guess all is not well. it shows in windows update on several machines that the install is successful, but review of the log files indicate this: No version of the client is currently detected. ccmsetup 3/5/2013 10:45:31 AM 3544 (0x0DD8)Logon installation has detected an existing version of the Configuration Manager Client. ccmsetup 3/5/2013 10:45:31 AM 3544 (0x0DD8)CcmSetup is exiting with return code 0 ccmsetup 3/5/2013 10:45:31 AM 3544 (0x0DD8) so first it says there is no version detected, then it says there is and won't install.. Quote Share this post Link to post Share on other sites More sharing options...
mjeds Posted March 5, 2013 Report post Posted March 5, 2013 40 odd views and no responses.. that's nice. Quote Share this post Link to post Share on other sites More sharing options...
