oloughran Posted March 8, 2013 Report post Posted March 8, 2013 Hi folks, I'm having a bit of a problem with pxe booting, it had been working fine as far as I was aware, then I was informed its now not working. if I pxe boot from a client the client gets an ip address as normal, on the screen it displays the following: downloaded WDSNBP from "Server ip address" WDSNBP started using DHCP Referral. Contacting Server: "Server IP Address" (Gateway: "IP Address") No response from Windows Deployment Services Server. Launching pxeboot.com Press F12 for network service boot. if I push F12 I get an error message, that I can upload if it would help just let me know. I have uninstalled/reinstalled pxe/wds numerous times but I still get the same thing, has anyone come across this problem before that can help me out? many thanks Owen. Quote Share this post Link to post Share on other sites More sharing options...
Iroqouiz Posted March 8, 2013 Report post Posted March 8, 2013 You should upload the pic with the error message. Quote Share this post Link to post Share on other sites More sharing options...
oloughran Posted March 8, 2013 Report post Posted March 8, 2013 see attached error message I get when I push f12. Quote Share this post Link to post Share on other sites More sharing options...
Iroqouiz Posted March 10, 2013 Report post Posted March 10, 2013 Did you let SCCM install WDS for you or did you do it manually? I've had problems when installing manually. Quote Share this post Link to post Share on other sites More sharing options...
Oneone Posted March 10, 2013 Report post Posted March 10, 2013 Check is the WDS Service is started, under services. Quote Share this post Link to post Share on other sites More sharing options...
oloughran Posted March 11, 2013 Report post Posted March 11, 2013 I let sccm install wds for me, also yes the service is running. Quote Share this post Link to post Share on other sites More sharing options...
