marlonc1980 Posted March 12, 2013 Report post Posted March 12, 2013 I want to learn to use workflows to uninstall applications, is this possible? Clarified that are applications that were not installed from SCCM. Thanks to All Quote Share this post Link to post Share on other sites More sharing options...
Iroqouiz Posted March 13, 2013 Report post Posted March 13, 2013 Well, I guess you could find out what the uninstall commands/switches are for your unwanted applications, and then write a script which silently uninstalls them? Then create a package with the script file. Or create one package for every app uninstall. Then add those packages to a custom task sequence. Maybe there's a better way, but that's the way I'd do it. Quote Share this post Link to post Share on other sites More sharing options...
marlonc1980 Posted March 13, 2013 Report post Posted March 13, 2013 Thanks, have a link where you can document on task sequence Quote Share this post Link to post Share on other sites More sharing options...
